Author Topic: Sorcerer and Atchison, Topeka and Santa Fe to be restored  (Read 540861 times)
Offline kmb69
Re: Sorcerer and Atchison, Topeka and Santa Fe to be restored
« Reply #2975 on: January 01, 2018, 11:20:59 AM »
Another more obscure one:
George
I am unable to view or download these first 2.
Offline gschuld
« Reply #2976 on: January 01, 2018, 12:06:58 PM »
George
I’ve had a bit of trouble uploading images in the last hour or so.  Had to try a few times.
I deleted them and tried again.  It opens when I try it anyway...  let me know if it doesn’t come through for you this time.
Sorry, I’m only a nerd in the sense of interest, not technical digital skills.
George
« Reply #2977 on: January 01, 2018, 12:15:33 PM »
I was referring to the last double the sort of V8, I think Russ is restoring it.
 Maybe I only dreamt that.
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #2978 on: January 01, 2018, 12:17:47 PM »
They all showed up for me. Thank you for sharing
Offline kmb69
« Reply #2979 on: January 01, 2018, 12:34:31 PM »
All working now.
Thanks
Offline gschuld
« Reply #2980 on: January 01, 2018, 12:53:01 PM »
You are referring to the Sorcerer?  Yes, that one is currently receiving some attention as well.
George
Offline NickO
« Reply #2981 on: January 01, 2018, 03:04:20 PM »
Are those "long" cranks modified or brand-new special parts?
Online MRieck
« Reply #2982 on: January 01, 2018, 03:05:57 PM »
Modified
Offline NickO
« Reply #2983 on: January 01, 2018, 03:22:32 PM »
Happy New Year Mike, (our very much stalled CB750 project is still alive BTW)!
What is the engineering process to elongate the crank like that?
Online MRieck
« Reply #2984 on: January 01, 2018, 05:18:38 PM »
 A piece of steel round stock is cut to length and bored for a large, long Allen head bolt. A channel is cut into it for for a Woodruff type key to hold a pulley for the toothed belt. Pulley also uses set screws (to lock in)  once the pulley is lined up with the receiving pulley The original crank snout is cut down and..I imagine ....some of the snout is left for the bolt to screw into and to stabilize/center the extension. The extension end which butts against the crank would have to be machined for this.The bolt is tightened, the extension trued and the bolt head is welded to the end of the extension.
 I do not know if this is the exact process but it is the best I can think of after looking at the cranks.
  • Moderator
« Reply #2985 on: January 02, 2018, 03:19:38 AM »
Hi Mike and a HNY to all.
After looking at some of the pictures that have been posted, it looks like you have a nice collection of parts there but have you any idea of when they might resemble CB750 motors again ?
Sam. ;)
Online MRieck
« Reply #2986 on: January 02, 2018, 04:21:19 AM »
Sam. ;)
As soon as the cranks are OK'd following crack testing
  • Moderator
« Reply #2987 on: January 02, 2018, 05:54:53 AM »
Awesome my friend, have you any idea who is doing the testing ?
Online MRieck
« Reply #2988 on: January 02, 2018, 07:23:16 AM »
Lindskog Balancing in Boxborough MA. Cranks are there now
« Reply #2989 on: January 02, 2018, 09:05:26 AM »
Lindskog is a Swedish surname! ;)
  • Moderator
« Reply #2990 on: January 02, 2018, 09:19:31 AM »
OMG.
Harley Davidson Engine Balancing
Lindskog Balancing specializes in Harley Davidson engine balancing. From Flatheads, Knuckleheads, Panheads, and Shovelheads, to today’s EVO engines, Harley owners have relied on Lindskog to take even the worst shaker and create a smooth running, dependable engine. Custom stroker engines and big bore kits benefit greatly from precision dynamic balancing. Performance enhancements altering the rev range of Harley Davidson engines respond favorably to precision dynamic balancing. At Lindskog Balancing, we strive to provide the Harley Davidson enthusiast with a level of detail exceeding that of the factory yet remaining factory correct.
Only joking guys ;D ;D ;D ;D ;D ;D ;D
http://www.lindskog.com/automotive-balancing/
« Reply #2991 on: January 02, 2018, 09:36:41 AM »
 They were an often heard name in custom bike building,  in the mid Seventies already..
Offline Bill/BentON Racing
    • BentON Racing
« Reply #2992 on: January 03, 2018, 07:47:37 AM »
Mike, what was the outcome on the 7 Golden rods Jr. got in
Valdosta?Thanks, Bill
BentON Racing Website
BentON Racing Facebook
  • Moderator
« Reply #2993 on: January 03, 2018, 02:21:55 PM »
Hey Murphy, what was the guys name that did the crank in the Auto, did he work for  Lindskog ?
He did a great job, smooth as silk.
« Last Edit: January 03, 2018, 02:59:22 PM by Sam Green Racing »
« Reply #2994 on: January 03, 2018, 06:25:38 PM »
 So anyone know which cams in the Sorcerer?
« Reply #2995 on: January 03, 2018, 08:38:45 PM »
Can I assume there will be a bearing to support the outside end of the crank extension?
  • Moderator
« Reply #2996 on: January 04, 2018, 02:44:26 AM »
Here you go Scott, even I'm behind the times but you need to keep up mate, hahahaha.
« Reply #2997 on: January 07, 2018, 05:43:56 PM »
 I was thinking someone said RC327 cams once.
Online MRieck
« Reply #2998 on: January 18, 2018, 08:50:33 AM »
Sorry for the late reply Sam. Yes....Zint balanced the auto crank. You met him when we had  that little party for you at my house. Zint is now chilling in Hawaii with a high school sweetheart he met at his 50th high school reunion if you can believe that.
Online MRieck
« Reply #2999 on: January 18, 2018, 08:51:15 AM »
 Cranks checked out OK.....big relief.
