Author Topic: Finished oil tank cb750  (Read 27807 times)
Offline 750resurrection
Re: Finished oil tank cb750
« Reply #50 on: October 17, 2012, 01:50:26 PM »
If anybody decides to fab these I definitely in for at least one.
still nobodys throwin out a ball park for what theyd pay for these...
 That's $119.99 for the oil tank lowball.
 $139.99 with some stickers or some stupid etch logo.
Offline beach bum
« Reply #51 on: November 09, 2012, 10:55:20 AM »
Is this project tank still in play, either in cadd as diy or finished product.  I think it is worth much more than the previous suggestion, at least to me .
Offline R1gg5
« Reply #52 on: January 17, 2013, 11:51:59 AM »
Would love to see cleaner images and a final status of VTEC's tank. Looks great.
1975 CB750 Cafe Racer (finished)
1971,2,4 CB750 Frankenbike Project
1969 CT70 (Trail 70)
2015 Ducati Scrambler Classic (with minor mods to make her mine)
Offline Free Booter
  • My Build: CB750k5
  • Meh.
« Reply #53 on: March 02, 2013, 06:30:14 PM »
I'm still waiting for another person on the forum to make me one to fit the rear plastic fender area, but I'd easily go $150 for one.
Offline ncstatecamp
« Reply #54 on: March 02, 2013, 06:34:32 PM »
If your really that interested I'm in the middle of fabing one up. Pm me if you want more details
Offline lucky
Re: How much oil fits in original oil tank?
« Reply #55 on: May 01, 2013, 01:35:03 PM »
3.5 qts?
When I change oil, I put three qts in the tank, run for short time then top off with forth quart.  Been doing that since I bought it in 1974, never any problems.
+1.
"It's Baltimore, gentlemen. The gods will not save you." Ervin Burrell"
Good one!
Offline Reganator
  • Just another guy with a CB750 kinda cafe.
Re: Can i plug this?
« Reply #56 on: May 01, 2013, 07:31:19 PM »
VTEC, you can plug the rear crankcase fitting, but only if your custom oil tank has a means to vent. The oil tank cutaway pictured in your post does not show a vented design, this means that excess oil can only be relieved from the oil tank overflow to the rear crankcase fitting.
The crankcase is designed to flow from the rear crankcase oil fitting then up to the valve cover which vents vapors and blow-by to the atmosphere. This is easily checked by blowing air into the rear crankcase fitting.
Wait...  You're tellin me that the little nubbin on the top is to atmosphere and the one on the bottom goes to the oil tank?  What if someone were to hook that up in reverse?  Just want to confirm that this picture is right.  When I got my bike that line ran from the oil tank to that top fitting.  I left it there, none the wiser.
Frankenbike CB750:
71 K1 Frame
72 K2 Engine
75 F0 Carbs:
     #40 slow jets
     #105 Main Jets
     Stock needle and settings.
My-neighbors-love-me-Kerker 4 into 1
Stock airbox
The best way to make a small fortune on the stock market is to start out with a large fortune.  Trust me, I'm an actuary.
« Reply #57 on: May 02, 2013, 05:12:08 AM »
Hooking the top one to the tank is wrong but won't hurt anything. It goes from eng to atmosphere, or to the airbox in later models.
The bottom one serves 2 purposes. It is a smaller dia tube and runs to its mat on the lower part of the oil tank. ITs a vent frm the eng to tank. ITs a fefed for the chain oiler from tank to eng.
If it is left to the atmosphere where is the lower tank spigot? Its too small to tightly hold the one from the cam cover.
If it is left to atmosphere it wil puke oil on the swingarm and rr tire.
IF the lower tank spigot is to atmosphere, it too will puke oil.
Offline wbradshaw6
« Reply #58 on: September 22, 2013, 01:13:13 AM »
I want to bump this because this oil tank is amazing and someone really needs to start fabing these! I found one online that mounts on the other side of the triangle, it bolts on to where the rear fender would bolt, but it sells for $330.
http://www.benjiescaferacer.com/oil-tank.php
I can't decide which placement is better. The one from this forum looks really good where it is and I also like how it allows people to see through to the rear tire. But the one mounted on the other side might do a better job cooling the oil because it is further from the engine and would probably get more air rushing against it. It would also double as the inner portion of the rear fender helping keep debris away from the engine. I guess it is personal preference. Anyway, someone please start making these and sell me one for less than $330, I think that is a little too steep.
Offline ncstatecamp
« Reply #59 on: September 22, 2013, 01:47:36 AM »
As I mentioned to Bradshaw in a pm I was able to make half a prototype then my equipment source ran out. My design fits perfect between the tabs build in for the low front half of the rear fender (the plastic bit). Is the same volume and acts as a new fender, all while behind hidden behind the posts.
I wasn't able to finish it before my source for tools went away. Fully finished with time and effort I'd say a reasonable price would be around 250 shipped.
This one is made from 18 gauge steel and would take just about anything thrown at it.
Offline sixthwisconsin
« Reply #60 on: September 22, 2013, 04:44:21 AM »
I am very close to needing one for my 750 build and have lined up a fabricator. I have a couple of friends that have been club racing for decades and know this guy. I have a cardboard prototype but just waiting for chain & sprockets to arrive before final fitment. I'll post here when I have progress.
