Author Topic: Vintage sidecar rebuild - new video  (Read 184558 times)
Offline Tintop
Re: Vintage sidecar rebuild
« Reply #150 on: June 25, 2012, 07:35:03 PM »
I've thought & looked into doing something like that scotty.  The only place to mount it would be behind the shifter.  That would be OK as far as weight distribution (more on the back wheel), but the rules & my passenger would want it covered.  To much fab work, and would require long cables (+ & -), plus some other rewiring.  This option is a bolt-on, and removes / solves any charging / ignition issues, plus let's me go to an accurate electronic tach.  Time isn't on my side, as I would still like to get it on a dyno before the next race mid July.
'edit' Besides I have a weight advantage, adding more weight is like losing HP. ;)
« Last Edit: June 25, 2012, 07:37:12 PM by Tintop »
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #151 on: June 25, 2012, 07:54:09 PM »
How much does the PM rotor weigh? (also adds to rotating weight, so double whammy.) How much does the stator weigh? I'm a tight bastard; $200 better save me a bunch of weight. ;)
« Reply #152 on: June 26, 2012, 01:22:02 AM »
Sounds like you only need a wee little push to pull the trigger................ ;)
OK, so I'm ready to jump. ;) :)  Two choices - The SPARX unit, or the one from the source that RR supplied the link for.  I'm leaning towards the SPARX (found it for $369US) mainly because it's more compack / sealed / and adds less rotational weight.  Only issue seems to be if it has timing marks.  The kit from 650central does, but its priced @ $510US. :o
SPARX for XS650- http://www.sevensinschoppers.com/PhotoGallery.asp?ProductCode=SPARX3PKIT%2DXS650%2D17%2D130
Hugh's Handbuilt - http://1.bp.blogspot.com/-5t-DLE9IafI/TrFrgmpKWII/AAAAAAAAAV8/U7Oewy7X-h0/s1600/101_7524.JPG
Brian, i would send Hugh an email and see what he suggests, considering his alternators are built for the street, he could make something more suitable for your chair...  He offered to make a better charging system for my bike so it had lots more output so i would imagine making something to suit your chair would be easier....  Just a thought... ;)
Offline Tintop
« Reply #153 on: June 26, 2012, 07:10:56 PM »
Time isn't on my side RR, and the SPARX system has a much lighter PM rotor (faster spin up), than the current offering from Hugh.  As well the windings are encased, which will improve durability in a racing application.  Got an email reply to my inquiry - they have a 3 phase kit in stock, so that's the way I'll go.  Going with the Weber has definitely been an expensive decision. ::)  However, I'm convinced it is making more useable power than the VM's.
The dustbin is fitted, just waiting for the chair fairing to be repaired, and all the bodywork will be completed (again ;)).  While I'm waiting for the alternator to arrive, I'll work on getting the shifter sorted.  Also need to re-bleed the brakes. :(
77 CB550 Cafe build
« Reply #154 on: June 26, 2012, 07:16:42 PM »
You know the rules, pics or it didn't happen.... :P
« Reply #155 on: June 26, 2012, 07:19:48 PM »
;D ;D ;D
Offline Tintop
« Reply #156 on: June 26, 2012, 07:22:44 PM »
I'll take one tomorrow :), it's still sitting on stands, while I complete other work.  Kind of wanted to wait until it was 'race ready', but......
;D ;D ;D
Got to love that accel pump. ;D ;D ;D ;D ;D ;D ;D
77 CB550 Cafe build
« Reply #157 on: June 26, 2012, 07:31:40 PM »
A great accelerator pump alone, does not a great carburetor make. ;)  ;D ;D
Offline Tintop
« Reply #158 on: June 27, 2012, 03:07:44 PM »
Here you go RR......still some decals & number to be fitted.  Also added the 2nd colour & pin stripe to the wheel fairing.  The chair fairing is being redone in the dark blue with pin stripe.
77 CB550 Cafe build
« Reply #159 on: June 27, 2012, 04:01:56 PM »
Looks great Brian, i am a fan of powder blue.... ;)
  • Moderator
« Reply #160 on: June 27, 2012, 04:25:57 PM »
Awesome, don't crash it next time ;D ;D ;D ;D ;D ;D
Offline Tintop
« Reply #161 on: June 27, 2012, 04:53:33 PM »
I plan to be a lot more careful with passing from now on Sam, even if it means my painter goes a bit hungry. ;D ;D ;D ;D
77 CB550 Cafe build
Offline bear
  • Leeton in Australia
« Reply #162 on: June 27, 2012, 09:31:48 PM »
Very nice Brian.
You'll look "as flash as a rat with a gold tooth" riding that rig around. ;D
It puts my old girl to shame. :-[
Brian
Offline bear
« Reply #163 on: June 27, 2012, 09:41:13 PM »
Any chance of talking you into an exchange program sometime, further down the track? :D
Brian
Offline Tintop
« Reply #164 on: June 28, 2012, 11:58:22 AM »
Brian
Hummm....that could be interesting.
77 CB550 Cafe build
Offline Tintop
« Reply #165 on: July 02, 2012, 07:26:38 PM »
Slowly ticking things off the list for the next race.  Got the repaired chair fairing back from Ron, my 'glas' & painter guy.  Fitted a new bubble, and added ducting for the cooler.  Had planned on the ducting before, but ran out of time before the 1st race.
Pics for RR  ;D ;D ;D ;D ;D ;D
Still have to install the new alternator & reg/rec (when they arrive), and wire up the electronic tach I got from bwaller.  Looks like I can fit it into the XS tach housing, so it will have lots of rubber for vibration isolation.
77 CB550 Cafe build
« Reply #166 on: July 02, 2012, 07:54:32 PM »
Thank you sir... ;D ;D ;)
Looking very business like my friend... ;)
« Reply #167 on: July 02, 2012, 08:12:12 PM »
Looking VERY nice, Brian! Try to keep it that way! ;)
Offline Tintop
« Reply #168 on: July 03, 2012, 05:31:09 AM »
Still plan to carry lots of speed through the corners (drifting is fun ;D).  However, I've got real brakes now, even the bias adjuster works properly.  There will also be a lot more caution when passing. ;) :)
77 CB550 Cafe build
« Reply #169 on: July 03, 2012, 07:44:25 AM »
Atta boy Brian.  tick...tick...tick. We're getting closer to race date, but makes me nervous as my bike has been ready for days & days, probably bad luck.
Offline Tintop
« Reply #170 on: July 03, 2012, 09:25:45 AM »
Hey bw, see you at the track.  Must be nice to just have to polish things and keep it looking nice. ;) ;D ;D ;D ;D
I owe you for that tach, so please PM or email me.  Did you ever get any info on the wiring??
77 CB550 Cafe build
« Reply #171 on: July 03, 2012, 09:51:37 AM »
Nothing on wiring. Check with funjimmy, he's using that tach and has mentioned wiring, I just don't recall.
Offline Tintop
« Reply #172 on: July 03, 2012, 02:58:36 PM »
Will do, I have a new connector set coming tomorrow.  Just need to know which wire  goes where.
77 CB550 Cafe build
Offline FuZZie
« Reply #173 on: July 03, 2012, 03:35:10 PM »
Damn it's looking good!
When you guys get to the track take some pic's for us!!!
Offline Tintop
« Reply #174 on: July 03, 2012, 05:08:28 PM »
Thanks FuZZie, I'm sure there will be some.
edit - update, got a call from Mackie HD, dyno time booked for next Friday @ 8AM. 8)  Of course its only 2 1/2 hours away ::), so it will be a long day.
« Last Edit: July 03, 2012, 08:04:18 PM by Tintop »
77 CB550 Cafe build
