Author Topic: how to remove tires from wheels?  (Read 6756 times)
Offline killersoundz
« on: May 02, 2012, 05:25:34 PM »
Can I remove the tires from my wheels from my 750, 18" and 19" on my own? I kind of tried with a screwdriver already with no success. I need to clean up the wheels and paint them and get some new tires. I might just cut these friggin tires off! They're junk anyways. Any tips before I go inhaling burning rubber?
My project thread:
http://forums.sohc4.net/index.php?topic=107447.0
My CB750K4 Starting up for the first time after a seized motor and rebuild!
Offline cmonSTART
Re: how to remove tires from wheels?
« Reply #1 on: May 02, 2012, 05:31:37 PM »
Use Armor-All as a lubricant.  Tire spoons are better than screwdrivers.
1981 GL1100 Interstate
1978 CB750F Project
« Reply #2 on: May 02, 2012, 05:49:12 PM »
Old tires get hard and they are a #$%* to get off. I have cut them off and that is fine. You will need some irons to put the new tires on and not put a hole in the tube. Soapy water or Windex is a good lube to mounting tires.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #3 on: May 02, 2012, 05:53:54 PM »
Warning Warning  ::)
« Last Edit: May 02, 2012, 05:55:41 PM by LesterPiglet »
Offline Kevin D
  • SE Michigan
« Reply #4 on: May 02, 2012, 06:10:14 PM »
I have several tire irons like the ones pictured in the upper right. The biggest one is fairly new and I found it necessary for modern tires.
Warning Warning
If you try to use screwdrivers you are gonna pinch a few tubes.
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
« Reply #5 on: May 02, 2012, 06:14:10 PM »
Thanks guys looks like I'll do whatever I can to get these old crusty tires off so I can work on the wheels. When I get new tires I'll have them mounted and balanced at a tire shop! I'll be replacing the tubes and everything anyways. Not sure you get the idea just HOW crusty these tires are LOL
« Last Edit: May 02, 2012, 06:16:32 PM by killersoundz »
My project thread:
Offline fmctm1sw
« Reply #6 on: May 02, 2012, 06:14:37 PM »
+1.  I cut them off too.  I used to mount my own but it was just way too difficult for me.  I leave mount and balance to the local shop, I know a guy so they cut me a break.
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline fishslayeryo
« Reply #7 on: May 02, 2012, 06:41:18 PM »
Just took mine off both front and back so i could put new spokes on. Just used a utility knife to cut away down to the inner cable and then cut those with a dremel. The crustier the easier to cut with a utitlity knife....my forearm got a good workout:) Think I read elsewhere some people used a sawsawl
'71 CB750 K1...work in progress:)
Budget Build: http://forums.sohc4.net/index.php?topic=100525.0
Fishing is much more than fish. It is the great occasion when we may return to the fine simplicity of our forefathers.  ~Herbert Hoover
Offline fiolola
« Reply #8 on: May 02, 2012, 07:11:32 PM »
Like Bobby said,old tires are pain.I use 1) 2x4x6' 4) 2x4x8". Need a heavy object to use it as counter weight.Take 3pcs of 2x4x8" laid them on the floor on a circular fashion ,then place your wheel on top close to the heavy object (car,wood pile) Take the 6 footer pcs and place a tip under your object,take the small 2x4 left and place it between the long pcs of wood and tire.Before you apply downward force put one of your feet on the opposite end of the tire. A steel round pipe cut to 14"or so then hammer the tip grind it round . That how I change mine old or new.
Offline BeSeeingYou
« Reply #9 on: May 02, 2012, 10:02:14 PM »
I found that three irons worked best for getting the initial start of getting the tire bead over the rim edge.  But since you have no need to save these just cut around the circumference with a utility knife leaving just the bead.  That's the hard part to cut has it has wire embedded into the rubber but at least you have better access to cut it off.  When I do it this way I use a cable cutter with an overlapping cut (looks like a parrot beak) to get through it.
« Last Edit: May 02, 2012, 10:04:12 PM by srust58 »
Offline Spanner 1
« Reply #10 on: May 02, 2012, 10:22:08 PM »
If you decide on going with the Sawsall method be sure to cover the rim with a protective piece of metal or something to avoid a 1/2 inch cut in the rim a.k.a. Spanner and Tugboat's efforts recently........ and we only had 1 or 2 beers which makes it un-excusable :o :D :D :) ;).
Offline rat racer
  • 76 Cb 550 "Ghost Dancer"
  • famous last words:hey watch this!
« Reply #11 on: May 02, 2012, 10:57:07 PM »
A regular hacksaw ,some elbow grease and a pair of snips to cut wire works every time as they are slower than a sawsall you dont have to worry as much about cutting your rims. trick is to cut two  diagonals across tire to give  you a trianglar hole to cut wire rim of tire I just cut a 36 yr old brick hard tire that way  thats my story and im stickin to it
rats to ya!
  • 1977 CB550F2
« Reply #12 on: May 03, 2012, 02:13:32 AM »
So much advice about removing a tyre.  :)
Offline ChuckG750f1
  • Not your average, everyday, run-of-the-mill
« Reply #13 on: May 03, 2012, 03:29:29 AM »
The key to removing tires is to compress the beads to the center of the rim which allows more slack for the tire iron to work with. Extra hands or clamps work wonders! :)
rt
Lots of advice...but this is key.
Life is hard; it's harder if you're stupid.
- John Wayne
1976 CB750 f1
1995 HD Softail Custom
Offline bert96
  • past ride
« Reply #14 on: May 03, 2012, 05:50:08 AM »
 And to mount them,this trick seem to work well....
How to mount motorcycle tire with zipties
Bert
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Offline ChuckG750f1
« Reply #15 on: May 03, 2012, 05:58:47 AM »
Bert- I wanted to watch the youtube...but I got stuck on your avatar.
- John Wayne
1976 CB750 f1
Offline bikerbart
« Reply #16 on: May 03, 2012, 06:29:31 AM »
lesterpig,just curious how old you are as most of your comments are snarky or wise ass?
Offline mrrch
« Reply #17 on: May 03, 2012, 06:31:33 AM »
Bert likes to get us sidetracked.
my build
  • 1977 CB550F2
« Reply #18 on: May 03, 2012, 06:33:01 AM »
Age has nothing to do with anything. I just find it funny that so much can be said about removing a tyre. I could do this task when I was around 6, nearly 8 years ago now.  :P
« Reply #19 on: May 03, 2012, 08:04:27 AM »
I use tire lubricant - got a gallon long time ago from pepboys - heavy object - myself cca 250  - to pop the bead and tire irons. Cheapest irons from local shop work well enough.
Cuttin is an option, but if you buy three irons, its faster just take them off whole.
« Reply #20 on: May 03, 2012, 08:28:45 AM »
 Read 12, 20 21, and pick up irons(3 of them..then polish them.... I probably have the tire off (with irons)by the time you are ready to cut the beads...
Offline bikerbart
« Reply #21 on: May 03, 2012, 08:34:27 AM »
I'm not critisizing ,because I KNOW I'm an a$$hole at times.
« Reply #22 on: May 03, 2012, 08:36:57 AM »
Thats why I read as much as possible here - I will polish my tire irons - obvious trick, never thought of that. Thanks 754!
« Reply #23 on: May 03, 2012, 09:27:44 AM »
 I didnt check mine once last year and I put a scratch in my Morris mag.. pissoff.. just check for burrs with your fingers before using on aluminum rims..  I bought a gallon of Ru-Glde, its enough for at least 1000 tires...
Offline lucky
« Reply #24 on: May 03, 2012, 11:30:28 AM »
Do NOT use screw drivers!!!!!
If you do the chance of pinching the tube is almost 100%.
Get tire spoons. Get 4 of them to make it easy on yourself.
