Author Topic: Let it all hang out,tell us how you really feel and what pisses you off.  (Read 1723916 times)
Offline Alan F.
Re: Let it all hang out,tell us how you really feel and what pisses you off.
« Reply #21675 on: September 16, 2025, 07:34:20 PM »
Don that reminds me to opt for a much cheaper phone plan, thanks!
« Reply #21676 on: September 16, 2025, 08:11:40 PM »
I dumped Verizon a couple of years ago and went with Consumer Cellular. For voice and text(which I never use) I pay $21.xx a month, and the simple flip phone cost me $40 out the door at Target with free activation, plus I kept my old phone number. At the time, Verizon was going to raise my rate to $49/mo, and required me to purchase a new phone, which would then cost $35 to activate!??
Offline Alan F.
« Reply #21677 on: September 18, 2025, 05:57:29 PM »
I got the tappet adjust screw replaced today, adjusted the valves again and got it all put back together and running, all is well there.
But I also swapped out my stock head pipes and non-stock mufflers for a used Tec Stinger 2:1 pipe I've had on the shelf for a few years. It's on and sounds good, doesn't leak.
*The problem is my stock clutch cable is now too short.
Normally adding a couple of zip ties will keep the cable off of these pipes, but I already used that slack up with my taller handlebars, 1.5" taller and 3" wider.
*So I'm a little pissed off that I spent a whole afternoon working on this bike but didn't forsee the need for a longer clutch cable.
I can swap back to my stock bars or get creative with clutch cable routing. Maybe a support bracket from the frame under the tank just in front of the engine will allow lock to lock turns and keep the cable off the pipes?
Online BenelliSEI
  • 1969 cb750
« Reply #21678 on: September 25, 2025, 06:39:50 AM »
Loading up the big enclosed trailer yesterday, going to the track today. I noticed a few of the small fasteners (holding the exterior skin in place) were coming loose. Looked like a Torx screw with a slight dome in the middle of the pan head.
I have three or four kits with literally 100’s of different screw bits. None fit.
What a bunch of a’holes. You made your own screws?
Offline lash
« Reply #21679 on: September 25, 2025, 06:49:30 AM »
My cargo trailer is the same way. At least they could have put some locktite on them.
Offline simon#42
  • liverpool
« Reply #21680 on: September 25, 2025, 10:58:08 AM »
or you could just buy a longer cable , im sure there is someone over there making one off cables . if not venhill would make you one
« Reply #21681 on: September 25, 2025, 11:12:37 AM »
They sound like torx security screws John, you need special hollow torx bits to tighten or remove them. I bought some torx security screws to replace the phillips screws attaching the number plate screws after some arsehole stole the number plates off my son’s Subaru to do a smash and grab robbery several years ago. ;D
« Reply #21682 on: September 28, 2025, 12:01:38 PM »
 My Haulmark has an 8 point torx which is hard to find but a square bit does the job, just turn by hand if you break any tight ones loose so they don't strip out. And Yes, they don't want us to be able to fix them.
« Last Edit: September 28, 2025, 12:04:43 PM by Don R »
« Reply #21683 on: September 28, 2025, 12:45:25 PM »
I always kept a set of torx bits on hand to remove stripped out allan bolts. Just belt a torx bit into the rounded out internal hex and I was good to go. My mysterious Harley (that the seller swore was a 2010 model but is actually at least a 2014 model, even if you’re a Harley expert you’d be struggling to identify this pile) with the 103 twin cam engine has the much improved compensator (cush drive) assembly which requires a T70 torx bit on at least a 3 foot breaker bar to remove. I now have the special tools, I just don’t know if I have the strength to remove it. ;D
Offline grcamna2
« Reply #21684 on: September 28, 2025, 05:35:58 PM »
You may need a 4' breaker bar  :D
75' CB400F/'bunch o' parts'
« Reply #21685 on: October 03, 2025, 08:57:57 AM »
 An old rusty fork tube makes a big cheater bar, just sayin'
Offline Kelly E
  • Geriatric Hooligan
« Reply #21686 on: October 03, 2025, 10:07:39 AM »
Yes they do and also can replace the baseball bat leaning behind the front door. 8)
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
