Author Topic: $12 aux fuel tank in one stop!  (Read 6844 times)
Offline xsmooth69x
« on: August 01, 2012, 09:29:31 PM »
now i wanted an aux fuel tank to sync carbs and just be able to work on the bike without the tank so i made one for $12
went to o rileys auto parts and got this bad boy
it was like $7 and some change
it has an on/off, filter and lid
then what i did was get a 1/4" male to male connector which fit perfectly on the end of the funnel. $2
the i just put some plumbing tape and some zip ties just for good measure but i doubt i needed too. i also put a fuel filter on it that was laying around that was probably not needed either......
then on the end i took a 1/4" Y tube thing to split the single tube into 2 since u need 2 fuel lines to the cb550 $2
so with tax its around $12-13 for the essentials
there is also another tread with a professional cheap aux fuel tank but it was to expensive for me lol even though the title says $20 it was more like $25 with shipping and the rubber bung to be able to fill it with a funnel.... and i didnt want to wait 2-3 days for it to come in the mail hahaha
http://forums.sohc4.net/index.php?topic=106348.0
but its a very legit aux tank. if i wouldve planed ahead i probably wouldve went that route but my $12 does the job very very well
finished product
sorry the flood light stand kinda makes the last picture confusing looking  :P
« Last Edit: August 01, 2012, 09:33:14 PM by xsmooth69x »
1975 CB550 (FINISHED?!?!?)
Offline shinyribs
Re: $12 aux fuel tank
« Reply #1 on: August 01, 2012, 09:32:46 PM »
Cool!   I really dig the green levers,too ;)
The darn fool didn't know it couldn't be done...so he went ahead and did it anyway.
My Hackjob build- http://forums.sohc4.net/index.php?topic=106103.0
Offline xsmooth69x
« Reply #2 on: August 01, 2012, 09:33:58 PM »
check out my build thread last page.... u should check out the carbs hehehe
Offline shinyribs
Re: $12 aux fuel tank in one stop!
« Reply #3 on: August 01, 2012, 09:44:03 PM »
Dude! That thing looks killer! You did a great job on that tank. I might have to rip that off ;)
Looking forward to reading your whole build thread when I get the chance. Good stuff man,you did good!
Offline xsmooth69x
« Reply #4 on: August 01, 2012, 09:44:49 PM »
thanks man  :)
« Reply #5 on: August 01, 2012, 09:48:38 PM »
Makes my driving lawnmower tank in a bird cage stand look weak.   ;)  Always thought a slave tank show me thread was good,will post pics after next trip---- Newbies though take note--Slave tanks are the way to check out your engine without polluting the work you may have done on your carbs from a CRAP tank. It all needs to be UBER clean as far as fuel flow !!
Offline xsmooth69x
« Reply #6 on: August 01, 2012, 09:58:05 PM »
yup when im done the lid stays on and the slave/aux tank is nice and clean
i only run pure premium gas too!! cuz im that cool but whats not cool its like $4.20 a gallon the last time i filled my 5 gallon gas can....
i want to seen this lawn mower bird house aux fuel tank lol
« Last Edit: August 01, 2012, 10:03:11 PM by xsmooth69x »
Offline lucky
« Reply #7 on: August 02, 2012, 10:54:44 AM »
You forgot to put a vent hole in the plastic lid. :o
Offline Mo
« Reply #8 on: August 02, 2012, 12:55:44 PM »
this is possibly the easiest/simplest brilliant idea I've seen in a while. Will definitely be making me one of those. Thanks for posting!
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #9 on: August 02, 2012, 01:47:14 PM »
Old lacquer thinner can (metal) solder old fuel fitting in bottom.  Store with hose on top and lid tight.  Free, and easy.  I strap it to the rear of the frame for riding.  Two straps and it would be permanent.
Offline xsmooth69x
« Reply #10 on: August 02, 2012, 03:25:19 PM »
nope dont need a hole.
the lid is more of a splash and dust cover.
its lot like a lid lid so you cant hold it upside down or anything.
but when ur done the 1/4 fitting that connects to the actually funnel end you can pull out and just drain the rest of your gas back into the gas can or into your bike.
Offline aperry
« Reply #11 on: August 25, 2012, 06:56:33 AM »
Thanks for this writeup.  I have the exact same tank (think I found it at Walmart).  Any chance you can provide a close-up photo of the fittings that you used to connect it to the hoses?  The tank's clear hose has a little black fitting at the end of it and I'm having trouble understanding how to connect anything to that.
Also, did you use real fuel line for this?  Or is standard PVC tubing fine (for temporary use).
Thanks!
Aaron
CB750K3 with F1 frame/swingarm
Offline MoMo
  • Ride like you're invisible
« Reply #12 on: August 25, 2012, 12:58:33 PM »
Thanks!
Aaron
Aaron,  do not use anything other than real fuel line.  I put some on a Silverwing for a short ride and was stranded when the plastic bits that were eaten off by gas filled the carb bowls...Larry
Offline aperry
« Reply #13 on: August 25, 2012, 01:34:00 PM »
Thanks!
Aaron
Wow, thanks for the warning.  More carb issues is about the last thing in the world that I need!   I will use real fuel line.
Aaron
