Author Topic: why SOHC over DOHC?  (Read 12398 times)
Offline phil71
Re: why SOHC over DOHC?
« Reply #50 on: September 08, 2012, 08:09:26 PM »
hondanut, you're right.. I should have worded that differently. I was describing desmodronic, but I only meant that the 450 valvetrain bears more similarity to it than a typical rocker arm setup.
Offline rb550four
« Reply #51 on: September 10, 2012, 05:53:37 PM »
Every now and then you run into something like this
and it ends up sitting in the back of the shop until you put the front end on a 550,maybe the engine in a go cart or something,or just leave it in the back of the shop because it's too good to strip. I've been wrasseling with the what to do with this one? for a while. and feeling ashamed about it.
« Reply #52 on: September 10, 2012, 07:04:50 PM »
Just think, that seat was someone's pride and joy. :o
« Reply #53 on: September 10, 2012, 07:09:47 PM »
Did anyone actually think they looked  good?
Offline rb550four
« Reply #54 on: September 11, 2012, 06:54:35 PM »
They are horrible to look at, ruins the lines of any machine, but I must say ,if you have a big assed lady on the back of a stock 550 seat, I've noticed each time I use the brake she slides up forward. Put one of these seats on she stays put and ya won't be riding with your nuts crushed into the fuel tank.
« Last Edit: September 11, 2012, 06:56:27 PM by rb550four »
« Reply #55 on: September 11, 2012, 07:23:07 PM »
Note to self: no big assed lady allowed on my 550!
« Reply #56 on: September 12, 2012, 03:34:50 AM »
id love to see an old advert from a magazine or so for one of these behemoth seats!something like sohc but a double big arse?
years ago my older sisters boyfriend had a cb450 twin dohc,,he was the fonz.
« Last Edit: September 12, 2012, 03:36:28 AM by dave500 »
Offline phil71
« Reply #57 on: September 12, 2012, 11:33:36 AM »
rb550, i hope your ole lady doesn't read this site ;).
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #58 on: September 12, 2012, 06:20:37 PM »
  While I think the 350 is a cool engine and all, myself, I prefer the 450 DOHC and also would like to make a correction (I didn't see where this was done and forgive me if I overlooked it but), in the way the valves are adjusted, on the 450 (Well, at least you don't need rocker arms in a DOHC. On the other hand, you don't need to take the camshafts out to adjust the valves on the SOHC.). You see, you don't have to take out the cams, to adjust the valves on the 450, you just loosen a locknut and make your adjustments, during the procedure and adjust the screw for each valve. You don't even have to remove the valve covers.
Member # 1969
Offline phil71
« Reply #59 on: September 14, 2012, 04:21:54 PM »
it's not a great idea to adjust those valves on the fly, but it can be done.
Offline strynboen
« Reply #60 on: September 15, 2012, 06:13:01 AM »
450/500 engine
« Last Edit: September 15, 2012, 06:20:45 AM by strynboen »
i hate all this v-w.... vords
