Author Topic: CB750 Spark Advancers = what are the differences  (Read 21095 times)
Re: CB750 Spark Advancers = what are the differences
« Reply #50 on: May 27, 2017, 11:51:23 PM »
You need to turn plate (1-4) and 2-3 points more clockwise to line up with F, but grooves does not allow more movements?
this has been common for me in the initial setup.
Reduce gap. Easier with dwell meter, adjust when engine is idling around 2000rpm. 8 cyl setup 23 degrees on both. This will make both to be equally set.
If advancer unit has a huge play when center nut is not tightened, the correct posistion can be found with a piston stop and find the real TDC that "T" should line up with.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #51 on: August 10, 2017, 07:59:15 PM »
Like 754, my advancer is marked AD125. Does anyone know what that is? Seems different than all photos I've seen.
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #52 on: August 10, 2017, 08:41:43 PM »
Honda used two different suppliers for the advancers. One was TEC, and the other was Denso. The symbol near the 2-3 timing marks on your unit is Denso. My K1 has a similar part.
« Reply #53 on: August 11, 2017, 01:56:40 PM »
The ones marked with the 'AD125' were seen (in my old notes) during the later K3 bikes, in the summer of 1973. They have a slightly slower advance curve (at least, when the springs were new!) and led me to discover how much these bikes prefer a later curve when used in city riding a lot. These seemed to vanish by the K4.
« Reply #54 on: August 12, 2017, 01:26:29 PM »
I have an AD125-01 on the shelf. Written to come from a CB750 Super sport 1975. I have not used it yet, probably to my CB750 K2 project.
It has a slower curve as using shortened springs?
« Last Edit: August 12, 2017, 01:29:04 PM by PeWe »
Offline CycleRanger
  • No comment about being an
« Reply #55 on: August 12, 2017, 08:14:13 PM »
Actually, that symbol is for Hitachi.
« Reply #56 on: August 12, 2017, 10:07:26 PM »
Thank you for the correction CR. :-[ :-[ :-[
« Reply #57 on: August 12, 2017, 10:22:12 PM »
Yes, very similar to cutting off 1/2 turn of both springs. That was how I first discovered that these engines like it. ;)
« Reply #58 on: August 13, 2017, 07:03:53 AM »
OK, that will be fine. Springs must be OK when the seller wrote it came from a 8000 miles bike. The cam holders from same bike were tight and fine.
« Reply #59 on: August 17, 2017, 07:24:14 PM »
CR, would you happen to know the symbol for Diachi? Thanks.
Offline CycleRanger
« Reply #60 on: August 17, 2017, 07:38:32 PM »
That one's easy.
« Reply #61 on: August 18, 2017, 08:14:54 AM »
That's the symbol I saw on one of Matt's replacement condensers. :( Thanks.
« Reply #62 on: August 19, 2017, 08:23:02 PM »
Yeah...we see it on dispensaries around here, too, looks just like that.
Offline YoungBlood
  • 1975 Honda Cb750F
« Reply #63 on: June 10, 2021, 09:15:41 PM »
PeWe, any chance you remember or still have that advancer from the 75' Honda Cb750F? I am curious what the od was on its pin.
When you're going through hell, give it some more gas.
« Reply #64 on: December 31, 2021, 12:41:38 AM »
I see this now ;)
That advancer has moved into my blue K6 with Dyna-S ignition.
-I do not know which pin you ask about.
I cut the springs as both my other TEC 300 advancers.
Stable idle, ign spot on F. Full adv at 2600-2700rpm.
I set ignition to match F at around  1000-1200 rpm.
 Advancer has a several degrees  lash noticed when nut is not tightened. Case mark will match with TDC (T) when advancer is in its counterclockwise position.
That engine has an alternative case mark 3mm to the right I use when timing the cam and advancer in its clockwise position. It will easy move to that when rotating crank with the big nut. No plugs in.
When done back to counterclockwise and set ign F to match stock case mark.
Bike had 104whp in October with good torque curve from low so ignition is fine. Shell V-Power street fuel.
