Treating this investigation like an onion.
First, peeled back the cam cover to reveal everything as normal. Then came the cam sprocket and cam (oh, what fond memories). So far so good there - I could even turn the engine from this point, but nothing broken yet and looking down the cam chain void I could see no noticeable sign of wear. Removed the carb rack assembly and exhaust. Holy 550 communion time with the rubber pucks to reveal the six header nuts (I'll have to replace these pucks, amen).
Popped off the header - thank goodness my gaskets are still clean and seemingly reusable.
Removed the cam chain tensioner and guide. This is where I noticed something a little off with the chain tensioner. A while back I had to replace the part 'cos I somehow broke the thread off of the adjuster bolt but now, having the two I compared them...
My original one on top and replacement on bottom. Did the replacement bend a little during the mishap, perhaps? Was this the design of some of the earlier 550s? Here's another look at them stacked on top of each other, the replacement on the bottom (a slight angle up compared to my original). Should this make any difference?
Anyway, onward with the investigation. Pistons and rings are all still looking good and even the cam chain looked fine. Since I was able to turn the engine, I gave a look on the underside of the engine case and there it was, the wreckage:
Gear on the right. Whatever it was knocked the hell out of those teeth! What could have caused this? I was shifting fine up to fifth. Things happened fast when the mishap occurred but I do remember for whatever reason I was downshifting from 5th to 4th and I was slow on letting go of the clutch; I think I wanted to downshift slightly and that's when the weirdness happened. First a clink, then a thud, and then a thunk and rear wheel locked up...
Crap. What now? Keep peeling back, I suppose? I gotta get that gear out. Do they even sell replacement parts? Should I be looking into getting another engine?
Check out this gangsta lean
I'm getting the hang of this rebuild. All this peeling only took a couple of hours (with some distractions in between).
Meanwhile, feast your eyes on my early Thanksgiving smorgasbord.
