Author Topic: Building the Dream...  (Read 89687 times)
Offline toytuff
  • "watching the pinheads"
Re: Building the Dream...
« Reply #125 on: March 27, 2013, 07:52:01 PM »
Kickstarter seal is a likely place to leak.
Possible. Most of this mess is from the chain being enclosed in the guard. If over the years someone removed the inspection plug and shot oil on the chain or like OS said the self oilier. The guard was a half inch thick of caked on muck.
All this gets slung up into the the case area. This is the dry side. There is no gasket on the case cover. The front sprocket sits way into the case also so this oil basically gets slung into the case. I'm going to use chain lube in the future.  ;)
I need to find me some strong drill bits as my drill index has seen better days. Lowe's?
tt
« Reply #126 on: March 27, 2013, 08:20:43 PM »
Try the titanium drill bits, Toy.
« Reply #127 on: March 27, 2013, 09:21:06 PM »
This bit from the Feb 2013 issue of EAA Experimenter might be of help during your refurbishment and work on mechanical bits...
Full issue here: http://experimenter.epubxp.com/i/108002
David
« Last Edit: March 27, 2013, 09:22:37 PM by RAFster122S »
Offline wowbagger
  • Not much of an
« Reply #128 on: March 28, 2013, 05:27:35 AM »
Just came across this thread and thought it might be of use to you:
http://forums.sohc4.net/index.php?topic=114006.0
They have a number of reproduction rubber bits for the Dream.
Offline toytuff
« Reply #129 on: March 28, 2013, 01:26:45 PM »
Thank you! I'll be ordering from them soon.
tt
Offline toytuff
« Reply #130 on: March 28, 2013, 01:38:17 PM »
Hooray!  :)
Off and on for three days! Only had to use an easy out on one cover screw. Man, that was a lot of time. Now it's time for three more days of cleaning parts. Front fender going in tomorrow for repair.
The entire front end removed.  :o And more cleaning!  ::)
Might as well tear the whole thing apart at this point!
tt
Offline SohRon
« Reply #131 on: March 28, 2013, 05:02:20 PM »
What a great bike, and in such excellent shape! I saw my first Dream (a black one) just about the same time yours was built and it was just cool as heck as far as I was concerned. It was like somebody took an old Caddy and turned it into a bike! I never forgot that bike, but never saw one again until I came across your build; I guess they're pretty rare? Or maybe I just never looked hard enough...
If you find drool dripping from your computer the next time you visit your thread, it'll be coming from me!  :) ;) :D ;D
Keep the pics coming! So cool! So cool!
« Last Edit: March 28, 2013, 05:04:01 PM by SohRon »
Offline vfourfreak
  • Do you think that's wise
« Reply #132 on: March 28, 2013, 05:35:47 PM »
Did you spray your car to match Caspar ?
Kev
Offline toytuff
« Reply #133 on: March 28, 2013, 05:41:03 PM »
Well thank you Sir!
There are plenty around actually but parts are getting harder to find and OEM for the most part has been discontinued. Yes, this was a rare find having the original title. so far I have found nothing that was not stock.
This build, as all of mine seem to be, will be close to the selling price of most. Nature of the beast.
Stay tuned for more and bring on Elvis!
tt
« Reply #134 on: March 28, 2013, 05:41:35 PM »
Looking good Toy.   That's the oddest front end I've ever seen, like a reverse swing arm.
Offline toytuff
« Reply #135 on: March 28, 2013, 07:02:30 PM »
Or a springer..on the bottom.
A lot of parts for sure. The cleaning begins. Again.
tt
Offline toytuff
« Reply #136 on: March 28, 2013, 07:05:19 PM »
Kev
 ;D
We were talking about that the other day. Two cargo trailers in white, the Tunda and the Scion.
Then casper.
tt
« Reply #137 on: March 28, 2013, 07:11:42 PM »
Ha!  You gonna paint the K7 next?
Offline toytuff
« Reply #138 on: March 28, 2013, 07:25:57 PM »
No, but I forgot the CBX is White also.  :P
tt
« Reply #139 on: March 28, 2013, 11:09:15 PM »
Well, you are a member of the "cool 2 club"  and the one way to stay cool in AZ is to be in lighter colored vehicles and clothing.
The front end design is a leading link design.  The C70 passport used a similar setup and it is odd the first few times out with it at slow speed because when you engage the front brakes the forks rise up.  It is an anti-dive design of old...
Looks like your parts are in pretty good shape, being stored indoors has been kind to this old Honda Dream.
Not a ton of front suspension dampening but it works fine.
Elvis was on a CB or Hawk variant as the front suspension is a telescopic fork design.
Hang in there tt, the cleaning will be worth it.
We are going to have to find the guy in white leathers from the UK auto show or Sam come visit for a photo-op... ;D
« Reply #140 on: March 29, 2013, 05:33:01 AM »
Or we'll pitch in and buy Toy a white Elvis outfit!
Offline toytuff
« Reply #141 on: March 29, 2013, 03:47:29 PM »
The leading link is now clean and somewhat assembled. There are felt washers on the rear portion that were long gone thus the heavy layer of build up that took forever to clean.
I took the whole piece over to the auto store and we fitted O rings that should keep the grease where it belongs.
Right cover almost done. Have to remove the kick shaft. Pretty sure the side cases will need painting. Have a can of paint that is factory matched from Marble Motors.  ;)
tt
Offline toytuff
« Reply #142 on: March 29, 2013, 03:48:59 PM »
 :o :o :o :o :o :o :o :o :o :o :o
tt
Offline toytuff
« Reply #143 on: March 29, 2013, 03:51:47 PM »
There ya go! Leading link. Yes, the parts are in great shape. Look how nice that link cleaned up.  8)
Can't say the same for my hands.  ;D
tt
Offline toytuff
« Reply #144 on: March 29, 2013, 04:00:28 PM »
The K7 is the "black sheep" of the flock.  ;D
tt
Offline Old Scrambler
« Reply #145 on: March 29, 2013, 07:32:29 PM »
tt...........if all else fails on the front fender repair............the trick is to locate a cheap fender with a good bottom and butt-weld it to the good front on yours.  The place to cut the fenders is at the fork to take advantage of the gasket to hide any imperfections.
The oil seals are all common sizes (hardware store) except the crank-seal behind the dyno.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline Goofaroo
  • general nuisance
« Reply #146 on: March 29, 2013, 07:56:38 PM »
If you paint the fender it won't match the patina on the rest of the bike.
Does it really look that bad?  Have you cleaned it up yet?
1972 CB500 four
1972 CT90
1974 CT90
1978 BMW R100S
1983 CX500
1986 GL1200 Aspencade
1986 CH150 Elite Deluxe
1984 NH125 Aero
2005 Genuine Stella 2T
2007 KLR650
2002 KLR250
1985 XR350R plated
1994 DR350SE
2004 Concours ZG1000
1987 KDX200 C
1992 KDX200 E
2010 BMW F800GS
Always room for one more.
Offline toytuff
« Reply #147 on: March 30, 2013, 06:22:29 AM »
OS, I have a question. Actually a couple. It appears you just pull out the kick starter shaft seal and slide a new one in. Pretty straight forward.
On the front sprocket the teeth look good but there is play "in and out" but no play "front to back". Normal?
Thanks.
tt
Offline toytuff
« Reply #148 on: March 30, 2013, 06:25:55 AM »
I'm just using gray primer on the repaired areas. I left explicit instructions to not paint the entire fender. I have no choice really as the damage takes away from the rest of the bike.
tt
Offline toytuff
« Reply #149 on: March 30, 2013, 06:36:59 AM »
The more I go the deeper it gets. I have this bike down to almost nothing. Part trays everywhere!  ::)
The steering stem needs removed now. Pretty dry in there. No play but does need repacked or replaced. Might as well do it then concentrate on the front end work.
I have done quite a few Honda facelifts but one thing is for sure. The older they are the more work they become.
So, carburetor is out for rebuild, parts on order from three suppliers, box of parts arrived yesterday, some OEM parts off a donor bike shipping from Maryland, new parts from California, fender in for repair and the seat goes in next week. Trays and boxes of cleaned parts as well as parts to be cleaned. Petcock, front fork assembly, rear wheel, front wheel ,chain all to be cleaned. Still shopping for brake shoes and exhaust and a donor rear wheel for spokes.
I need a nap!  :D Better yet a break for a few days.
tt
