Author Topic: and so it begins, cb550k under the knife  (Read 44666 times)
Offline DMcD
Re: and so it begins, cb550k under the knife
« Reply #125 on: February 26, 2016, 11:54:38 AM »
Very accurate observation!
« Reply #126 on: February 26, 2016, 03:31:30 PM »
...just need to join the two parts now.
"Just"... I love it when people describe the work involved in TIG welding aluminum as "just". Coronary transplants take less time  ;D I know you were self-describing and know all too well what I mean, but it just looked completely under-stated in print  ;)
Beat me and everyone else to the loaded "just"!
If only it were that easy, aluminum race tanks would be bountiful!
Offline DMcD
« Reply #127 on: March 01, 2016, 02:28:52 PM »
Tank 99% done.
If I was doing it again I would put a larger radius on a couple of the corners.
« Reply #128 on: March 01, 2016, 02:56:42 PM »
Pretty damn good for your second aluminum gas tank!
Offline DMcD
« Reply #129 on: March 01, 2016, 03:07:45 PM »
Ah well, 4th tank actually, made one for a tz350a for a friend, and then one for my mates x5, that was why I wanted to make a better one for myself.
« Reply #130 on: March 02, 2016, 01:04:56 AM »
It's just aluminum. Cut it, bend it, weld it. Done  ;D
Smarty pants.... :P
Offline DMcD
« Reply #131 on: March 02, 2016, 05:51:36 AM »
I'm just surprised that someone is still interested! :o
« Reply #132 on: March 02, 2016, 07:30:42 AM »
That's about the truth Cal. We can only understand through pictures DMcD.  ;D
Thanks and good work.
Offline Pan1cReaper
« Reply #133 on: March 02, 2016, 09:48:56 AM »
Awesome work man. Loving all the fab work. One day I might be 10% as good.
Offline DMcD
« Reply #134 on: March 02, 2016, 01:25:41 PM »
Don't underestimate your abilities, when I started this thread I had never bent a piece of aluminium, seen an english wheel, or even held a tig welder.  If I can do it, it can't be that difficult.
Offline Pan1cReaper
« Reply #135 on: March 02, 2016, 04:31:42 PM »
I like seeing "the little guy" do work like this. Of course a shop can do it, but seeing someone do it at home is really cool. Might be worth seeing if the local com college has a class. I mig all the time, have never tig welded.
Offline DMcD
« Reply #136 on: March 04, 2016, 03:20:42 PM »
Second attempt at megaphones today 32X60x300.
Offline DMcD
« Reply #137 on: March 05, 2016, 07:56:40 AM »
Engine back in for exhaust fitting, got 4 metres of 32mm exhaust pipe today for £20.  Not sure whether to bend it, or pie cut and weld it?  Anybody got advice?
« Reply #138 on: March 05, 2016, 10:11:55 AM »
Sand is better than nothing, however I remember seeing it done using lead, and that really worked great. Want to guess how long ago that was?  ;D
Offline DMcD
« Reply #139 on: March 07, 2016, 11:48:27 AM »
Couldn't get my cone layout app on the phone to do what I wanted, so took a lucky guess using the inner and outer of a roll of masking tape.  Lucky guess!
Need a bit of tidying before welding on a belt sander, which I don't have, but I like the overall shape.
« Last Edit: March 07, 2016, 11:50:35 AM by DMcD »
« Reply #140 on: March 07, 2016, 01:12:11 PM »
The overall shape does look good.  I bet those suckers are going to be LOUD.  ;D
Offline DMcD
« Reply #141 on: March 07, 2016, 02:05:09 PM »
Yes, going to have to rig up something temporary to get it through the test for the road, won't matter if it runs like crap for that 5 minutes each year
« Reply #142 on: March 07, 2016, 06:07:30 PM »
Every time I see unbaffled megaphones like that, I think of Lord Moonpie's racing exhaust on "Doctor D" Dave Hiller's 750F and Vincent's CR for the street.  Doctor D's can wake up half of Seattle with his pipes on the dyno.
Offline DMcD
« Reply #143 on: March 19, 2016, 02:04:15 PM »
1/4 of the exhausts done, well nearly, not going to put the megas on until the swingarm, rearsets etc. are in place.
Offline DMcD
« Reply #144 on: March 30, 2016, 08:59:07 AM »
Bling
Offline DMcD
« Reply #145 on: March 30, 2016, 11:26:48 AM »
36 cuts and welds later.......
Need the footrest hangers finished now, before I can finish the exhausts.
Offline DMcD
« Reply #146 on: March 31, 2016, 11:04:46 AM »
Bit more mocking up today, need to bring the lower ones (upper in pic) in a bit I think.  Definitely not going to interfere with the wheel spindle
« Reply #147 on: March 31, 2016, 05:22:38 PM »
Are you sure those will not scrape when you lean the bike over?
Offline DMcD
« Reply #148 on: March 31, 2016, 11:49:42 PM »
Probably, this was just a mock up to see if they were any where close to being ok.  I'll be tweaking them further.
Offline DMcD
« Reply #149 on: April 01, 2016, 12:52:50 PM »
Just for you CB750CafeRacerFan
