Author Topic: 1972 CB750 Four K2 -- Rebuilt to NEW OLD STOCK -- PIX ON PAGE 50  (Read 289984 times)
Re: 1972 CB750 Four K2 -- Project "Ice Cream"-- SLOW ASSEMBLY
« Reply #1050 on: June 08, 2015, 07:47:00 PM »
Hey Mo - that front end looks fantastic!  Better than new.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #1051 on: June 09, 2015, 07:21:27 AM »
Where did you get your Diamond chain? Local dealer? My local Honda/Harley doesn't carry Diamond! I will likely get it from Revzilla... http://www.revzilla.com/motorcycle/diamond-530-chain
Amazon.
http://www.amazon.com/Diamond-Chain-530-XDL-Drive/dp/B000GTW3QO/ref=sr_1_1?ie=UTF8&qid=1433781902&sr=8-1&keywords=diamond+xdl&pebp=1433781905448&perid=0ERT41TESAMYKHWXBC67
Its pretty tough to cut the extra links, and you'll need to "press fit" the master link. I used a C-Clamp with a socket, worked well, neat trick from Bill Benton.
Cool. Seem to be cheaper prices, too...
--Evan
1975 CB750K "Rhonda"
Offline edwardmorris
  • Youngish
« Reply #1052 on: June 09, 2015, 08:07:12 AM »
Thanks! Means, its pretty close to the goal which was new from factory only better (hence the few restoration sins/upgrades  ;D). I hope the rear matches up too (waiting on few tiny bits to arrive).
I want to wrap up the electrical stuff when I get home tonight, any ideas on how to deal with the igntition switch not fitting right in the bracket when I use the washer? Without the washer its a perfect fit, but with the washer, it stands proud a good 2-3 complete threads :-\ :-\
« Reply #1053 on: June 09, 2015, 08:32:31 AM »
The washer fit problem I've seen before. Has to do with mismatch of model year parts, or specs from after market suppliers. I think. I got a super thin washer from the hardware. "Machine bushing" I think it was called.
  • Youngish
« Reply #1054 on: June 09, 2015, 09:09:29 AM »
Its a NOS K2 correct one (round brown connector) :-\ I do recall reading through the Phaedrus log about the Ace h/w replacement, I'll go back and look, but IIRC even that had to be ground down some? I'll check out the local Ace before being too tempted to just skip it. Thanks!
  • Youngish
« Reply #1055 on: June 09, 2015, 04:36:43 PM »
Turn buzzer spruced up nicely! New sleeving and terminals (last of my samples  :(). I located a NOS one but its outrageously priced for something that will most likely be ripped out by the Future Owner. I wired it entirely separate all the way with its own sleeve throughout so should be easy peasy to pull. This one came from KC_Northstar as well along with the gauges and controls. Looked to be in great shape until installation >:( Lubed up its mounting rubber end with silicone, 3/4th of it slid into place, then the last chunk just craked and fell off >:( >:(. It stays in place pretty well, but for added insurance...... :-[ :-[ :-[.......I used  :-[ :-[ :-[ :-[ :-[........zip ties :'( :'( I'm officially an PO now :-X
Wanted to finish up the rat's nest next so got the headlight shell out of the yamiya body kit packaging. Bought this handy HL mounting kit either form Z1 or 4into1, can't remember. Has all the bushings, screws etc. etc. in one place.
  • Youngish
« Reply #1056 on: June 09, 2015, 04:42:22 PM »
All new everything for the turn signals and their mounting hardware. Sorely disappointed in the signal stems, my rechromed ones outshine these by miles (can't use them coz they were for K4+ and already sent to a member who needed them (traded for smaller aftermaket ones IIRC)). The signals themselves have beautiful chrome, but those pesky DOT Honda stickers made a gooey mess. Had to clean it up >:( >:(
Here we are, nice and clean, but still a damned rat's nest. This took all of 9 miuntes to finish up, which worries me greatly. I think I have it all done right, will go through it again. Everything is accounted for EXCEPT a solid brown wire with a female terminal. There is nothing (besides the three headlight wires) left to go with it. Is this some Euro specific thing?
  • Youngish
« Reply #1057 on: June 09, 2015, 04:46:15 PM »
AND hello search!
No clue who made the replacement harness, but I think I'm looking at this
http://forums.sohc4.net/index.php/topic,110284.msg1236333.html#msg1236333
  • Youngish
« Reply #1058 on: June 09, 2015, 05:07:26 PM »
I might just get lucky and not need to bother with it. There's only one fuse on the K2, no separate fuses for HL/TL etc. Will wait till Mark swings by and confirms. I'm planning on skipping the fuse box altogether and use the automotive style fuse hooked straight into the harness leads.
Offline jerry h
« Reply #1059 on: June 09, 2015, 08:23:39 PM »
Wow, really looking good!  Your bike will be as close as you can get to a new "NOS" bike.  Very nice! ;)
  • Youngish
« Reply #1060 on: June 10, 2015, 09:33:05 AM »
Thanks Jerry!
So my first guess about that brown wire was right, its a Euro park lamp thing, so leaving it be. Checked tracking on the clutch cover gaskets, they're waiting at my door! Will be closing that up and adjusting the clutch tonight along with finishing up the rear fender, tail light and turn signals. Then do points ugh, I'm struggling to get a hang of that despite all the reading >:(
  • Youngish
« Reply #1061 on: June 10, 2015, 10:37:07 PM »
Should have installed the new gauge cables before installing the headlight dome >:( Got them on there though.
New horn, cable guide and their mounting hardware. Opened up the horn and it came with its own mounting bracket, so saved my powder coated one.
Installed and cables routed. The clutch cable is through the guide too, forgot the pic.
  • Youngish
« Reply #1062 on: June 10, 2015, 10:48:01 PM »
Clutch cover back on, may have gotten a little to tough on the screws :( but its on there nice and even.
New clutch spring.
Adjusted the clutch following instructions in the manual, and I really hate instructions like "turn till you feel a slight resistance".  I turned it out loose as far as it went, then back in till first resistance, then half turn back again. Got it to a point where it "feels" right and there's just a little slack. The locknut is in place and the adjusting screw sits out about 2 threads proud. Look and sound about right?
Offline Davez134
« Reply #1063 on: June 10, 2015, 10:50:03 PM »
Now that looks right
Offline evanphi
  • Apparently I'm an
« Reply #1064 on: June 11, 2015, 07:06:14 AM »
Closer and closer! That tach cable bracket is some shiny!
--Evan
Offline Davez134
« Reply #1065 on: June 11, 2015, 08:53:19 AM »
Is that some sort of corrosion or dirt I see on clutch arm? Unacceptable!? ;D
Offline oldhatt45
  • The person called in at the last minute to share the blame is the...
  • Just an Old Guy that's gone to the Dogs
« Reply #1066 on: June 11, 2015, 09:20:28 AM »
Dave,
Did you also notice the 4 mashed up screw heads????
One above the kickstart and the other 3 around the clutch cable exit point??
He needs to get one of those JIS screwdriver kits from Gordon.  Sheesh.  :)
I think Rafi needs to start over again from the ground up with pictures to make sure this is a good resto.  ROFL
I mean, how can we possibly nominate this bike for BOTM in this condition????  :) :)
Charlie
Offline Davez134
« Reply #1067 on: June 11, 2015, 11:13:39 AM »
unsubscribed
  • Youngish
« Reply #1068 on: June 11, 2015, 02:09:59 PM »
Holy crap what happened here!? There's NO RUST, that's the gold/yellow chromate shine bouncing off the clear/blue one dude  ;D ;D ;D (I gotta ditch my cell phone and get a real camera).
Everybody, chill, new screws are on their way 8). Hate to say it, but the yami ones are essentially one time use only >:(
I actually used zip ties and fessed up earlier, yet I'm gonna get booed off the forum for some yellow chromate shine and mashed screw heads :o :o  :P :P :P
Some pix of NOS 341 ought to calm things down I hope ;)?
Offline oldhatt45
« Reply #1069 on: June 11, 2015, 02:27:59 PM »
Well, it's been 3+ hours and no 341 pics.
Natives getting restless.  :))) :)))
Charlie
  • Youngish
« Reply #1070 on: June 11, 2015, 02:37:33 PM »
Charlie
Bear with me, us old folks are slow when it comes to heavy boxes :P :P :P :P
  • Youngish
« Reply #1071 on: June 11, 2015, 08:35:21 PM »
Well, ain't karma a b%&$^?. All my old man jokes I bet. Lower back spazzed out after work, things on hold till I can move freely again :( :(
Offline Restoration Fan
  • My wife will never call me
« Reply #1072 on: June 12, 2015, 04:09:09 AM »
Rafi, sorry to hear that.  You do know that everyone was just enjoying messing with you because you have done such an incredible job on this bike, right?  Sorry to hear you're going to be down for a while...we'll have to get our bike porn fix from other threads now.
Rest up and get better quickly.
Offline oldhatt45
« Reply #1073 on: June 12, 2015, 04:31:08 AM »
Rafi,
Get better soon.
Charlie
Offline evanphi
  • Apparently I'm an
« Reply #1074 on: June 12, 2015, 05:09:32 AM »
Get better soon, from a young'un who also has a bad back...
--Evan
