Author Topic: Cognito Moto CB750 cafe with GSX-R forks  (Read 112347 times)
Offline Free Booter
  • My Build: CB750k5
  • Meh.
Re: Cognito Moto CB750 cafe with GSX-R forks
« Reply #25 on: November 22, 2013, 08:30:01 PM »
I finished my 750...You can see it in my link. I always considered doing this conversion, but opted for a more old school look. I DO happen to have a cb550 FOUR just sitting around though...heheheh...
Was considering doing this with my xs650 Yamaha, but I've always wanted a little bobber and they seem quite suited for that. I was going to rail on you for what I thought amounted to a big advertisement for your site, but DAMN! I love your parts! So you can put me on the list to order some bits to convert my 550 over...love the look.
Offline CognitoMoto
  • Cognito Moto
    • CognitoMoto
« Reply #26 on: November 26, 2013, 10:33:37 AM »
Little update. Had this electronics pan made. Bolts in where the old battery use to go
www.CognitoMoto.com
www.CognitoMoto.com
www.CognitoMoto.com
GSX-R Fork Conversions/Laced Hubs and Cafe Racer Parts
www.facebook.com/cognitomoto
Offline CBcafeJunkie
  • 75 CB750F
« Reply #27 on: November 30, 2013, 11:26:36 PM »
love your ingenuity man! ill be watching also love your swing arm build idea. subscribed
« Reply #28 on: November 30, 2013, 11:41:06 PM »
Me, too, and I suspect many others.
Offline USCG_C130
« Reply #29 on: December 01, 2013, 09:11:26 AM »
keep up the good work, i love the GSXR front ends and i know many will thank you for selling a conversion kit. rock on i will be following!
« Reply #30 on: December 01, 2013, 10:35:55 AM »
Can you explain the oil feed on the swingarm oil can? Will it be high enough for gravity to do it's thing or am I missing something?? Pressurized??
Offline CognitoMoto
  • Cognito Moto
    • CognitoMoto
« Reply #31 on: December 01, 2013, 10:50:16 AM »
The oil is pumped in and out so gravity shouldn't play a factor. I've seen it done before but not much detail so I will build a prototype and see how it works.
www.CognitoMoto.com
www.CognitoMoto.com
Offline CognitoMoto
  • Cognito Moto
    • CognitoMoto
« Reply #32 on: December 13, 2013, 03:52:49 PM »
This build has been on the back burner for a few weeks now but I've been gathering parts. I'm going to use the harley hub because it's already laced and disc in the rear looks cooler than it is functional. Disc was there so I figured why not. Picked up a rear caliper from a harley off eBay for $65 shipped. The axle hole is 3/4" (19mm) so I'll need to bore it out to 20mm. Little test fit
Looks promising.
www.CognitoMoto.com
www.CognitoMoto.com
Offline brandEn
« Reply #33 on: December 13, 2013, 04:43:19 PM »
That does look promising! Sweet....
Offline redrider736
« Reply #34 on: December 14, 2013, 10:46:46 AM »
www.CognitoMoto.com
Hey Devin, are your Retro Top Clamps flat on the underside ?? Looking to mount a min-gauge bracket to the underside of them if possible ??? Is this possibly something you could make/add to your product line to fit your Clamp ??
ThX
Ryan
« Last Edit: December 14, 2013, 11:14:14 AM by redrider736 »
78' CB550k (Not Run'n / Basket Case Project)
77/78 cool 2 member #269
Offline CognitoMoto
  • Cognito Moto
    • CognitoMoto
« Reply #35 on: December 14, 2013, 10:51:02 AM »
www.CognitoMoto.com
Hey Devin, are your Retro Top Clamps flat on the underside ?? Looking to mount a min-gauge bracket to the underside of your Clamp if possible.
ThX
Ryan
Ryan,
Yes it's pretty much flat. It's contoured but large amount is flat.
www.CognitoMoto.com
www.CognitoMoto.com
Offline redrider736
« Reply #36 on: December 14, 2013, 11:42:19 AM »
WoW, that's pretty trick ! If want to run Clip-on's you can, and If I decide you want to go back to a 7/8ths bar you just flip over the clamp and buy the risers !! Cool
« Reply #37 on: December 14, 2013, 11:58:24 AM »
I am not seeing a slit in the clamping element in the last pic. Is there any clamping to the stem nut?
« Last Edit: December 16, 2013, 08:10:44 AM by 754 »
Offline CognitoMoto
  • Cognito Moto
    • CognitoMoto
« Reply #38 on: December 14, 2013, 02:18:06 PM »
I am not seeing a islit in the clamping element in the last pic. Is there any clamping to the stem nut?
No clamp. Stock gsxr doesn't clamp.
www.CognitoMoto.com
www.CognitoMoto.com
Offline jpfrk2001
  • I hate being a
  • What was that!
« Reply #39 on: December 16, 2013, 06:22:34 AM »
So your going to show us how to fit a rear Harley wheel assembly to a CB rear swing arm?
This is awesome to wait. I also have the exact rear Harley wheel assembly sitting in my living room. I was going to start de-lacing this weekend, but that updated post/pic, caused me to wait.
Definatly paying attention.
I do tasks the most difficult way. My life is interesting.
1978 750K
1978 550K on a table
2009 Ducati Monster 1100
77/78 cool 2 member
Offline CognitoMoto
  • Cognito Moto
    • CognitoMoto
« Reply #40 on: December 16, 2013, 06:35:18 AM »
So far I have bearing to convert the axle on the way. Then it's on to setting up the spacing and sprocket
www.CognitoMoto.com
www.CognitoMoto.com
Offline jpfrk2001
  • I hate being a
  • What was that!
« Reply #41 on: December 16, 2013, 10:48:55 AM »
www.CognitoMoto.com
Please post all details. I may be interested in this. May change the direction of my build. Expect a PM this week sometime.
1978 750K
77/78 cool 2 member
Offline CognitoMoto
  • Cognito Moto
    • CognitoMoto
« Reply #42 on: December 17, 2013, 07:34:44 PM »
Replaced the stock harley bearings with the 20mm ID bearings. So far so good
Diameter difference.
Axle installed.
Now i will bore out the caliper and see what spacers I need.
www.CognitoMoto.com
www.CognitoMoto.com
Offline jpfrk2001
  • I hate being a
  • What was that!
« Reply #43 on: December 18, 2013, 06:24:22 AM »
Ok, so far its bearing change out, Spacers, boring caliper, Fab up brackets for caliper, fab up mounts for Rear MC. So far, it looks like Im interested.
Looking good.
1978 750K
77/78 cool 2 member
Offline RustyOlive
  • rustyolive.com
« Reply #44 on: December 18, 2013, 09:48:06 AM »
Outstanding work thus far man!
Your oilpan/swingarm idea. Fabricating the oil pan to fit the stock 750 swingarm, or fab up a swingarm from scratch?
I really dig the idea. Air flow under the engine might even help cool the oil as it hits the pan.. Lol in theroy ..
However.... (Excuse me while I have a brain fart) oil return line to the engine, is it not gravity fed feed? If oil pan is lower than the engine oil return inlet.... Orrrrr, am I off? Lol
Offline CognitoMoto
  • Cognito Moto
    • CognitoMoto
« Reply #45 on: December 18, 2013, 10:17:11 AM »
The swingarm will be fabricated from scratch.  The feed line into the engine is vacuumed by the pump and pushed through the engine. Then pushed into the oil can. Like how the pickup at the bottom of the engine in the cb550 works.
Fuller built this swingarm oil can on his cb750 so I know it can be done.
http://www.pumpsessions.com/2011/09/fuller-cb750-cafe-racer.html
Another guy over on DTT also did one a few years back.
www.CognitoMoto.com
www.CognitoMoto.com
Offline RustyOlive
  • rustyolive.com
« Reply #46 on: December 18, 2013, 10:38:13 AM »
Wicked!!! Knew it was done before.. Like I said. Brain fart.... Hahahaha.
Offline greenjeans
  • 1972 CB750K2
« Reply #47 on: December 18, 2013, 10:45:45 AM »
FYI the swing arm on that Fuller bike is off a Honda Ascot of all things -
And another thing - those are by far the best looking top clamp/triples I've seen in a very long while.  Simple, elegant, clean, beautiful.  I could go on.
« Last Edit: December 18, 2013, 10:58:20 AM by greenjeans »
Offline CognitoMoto
  • Cognito Moto
    • CognitoMoto
« Reply #48 on: December 18, 2013, 11:08:38 AM »
Thanks!
www.CognitoMoto.com
www.CognitoMoto.com
Offline CognitoMoto
  • Cognito Moto
    • CognitoMoto
« Reply #49 on: December 20, 2013, 07:57:38 AM »
Got my seat pan and the length I want. This seat length doesn't work with the existing frame setup.
Trying to get it looking correct before anything gets welded.
www.CognitoMoto.com
www.CognitoMoto.com
