Author Topic: how to save a cb750 from the garbage dump  (Read 55969 times)
Offline JohnK6
  • I'm NOT Crazy, says the crazy man
Re: how to save a cb750 from the garbage dump
« Reply #100 on: September 12, 2006, 01:44:10 PM »
what exhaust is on there???????????  It sound wicked.......
an old gsx-r 750 pipe 1988 ore so
« Last Edit: September 13, 2006, 11:20:00 AM by JohnK6 »
owner of: cb750k6(76), cb750k7(78), cb750K7(79)(sold), zwolle, netherlands
Offline JohnK6
« Reply #101 on: September 13, 2006, 10:18:24 AM »
And I wanted to go on a holliday with a few friends, so i mounted my suitcases on the "new one" ::)
I bought those very cheap from a friend
and than she looked like this :P
Offline JohnK6
« Reply #102 on: September 13, 2006, 10:24:07 AM »
Last week i had a problem with my frontwheel , whenever i turned in a bend it started squeaking (made a lot of noise ), and so i decided that it was time for a new tire, this is a Bridgestone BT45
without frontwheel :P
and the new tire ;D
Offline JohnK6
« Reply #103 on: September 13, 2006, 10:53:27 AM »
this week I had a problem with the engine, whenever i wanted to speed up fast, the engine did burp burp burp en then getting speed,  meanwhile burping out the exhaust ;D, I thought the ignitionadvancer or a spring from this was broken so i went checking :)
got the ignition out and indeed de ignitionadvancer didn't went smooth, needed a drop of oil
at that moment i tough wait a minute in my other bike which has a engine which needs a lot of service (the blue one, it uses more oil than fuel  ;) ) i installed an electronic ignition, why don't i use that one ;D
it comes with a special advancerpart, here is a part of aluminium with sticked in that two little magnets
and here you can just see one of the magnets, and the pick-up
en this is it, it works great
it runs smoother now,
uses less fuel( i don't know how thats possible, maybe one of you can explane me, i had the same on the other bike, the ignition saves me about 1 km per liter fuel)
this ignition works only with the original coils (5 ohm)
if i ever think of selling the bike i will put in the old ignition  ;D
« Last Edit: September 13, 2006, 01:20:16 PM by JohnK6 »
Offline JohnK6
« Reply #104 on: September 13, 2006, 11:12:28 AM »
the garagebox were i did all of this , i had to get out, (I rented it from a friend, who's now moved to another town), just my luck  :(, luckily i could rent a new garagebox under my apartment and after a lot of work it looks now like this  8)
just a few things to do butt .....
and
« Last Edit: September 13, 2006, 11:23:21 AM by JohnK6 »
Offline flyin_
« Reply #105 on: September 13, 2006, 02:31:44 PM »
Nice work!!
Thanks for all the great pics
CB750K6
CB750K1/K4
2000 Honda Magna
1965 S65
Offline Loudpipe
  • Broken Vehicle Collector
« Reply #106 on: September 13, 2006, 03:06:23 PM »
All this is quite impressive. I worked as a mechanic, restoring old British cars for 2 years, and can guess that all this work was probably a lot harder than the pictures show! In any case, you've done an amazing job John. Congrats.
- LP
1974 Honda CB350F
Previous: 1978 Honda CB750F, 1971 Honda CB500K, 2009 Yamaha YZF-R1
Offline JohnK6
« Reply #107 on: September 13, 2006, 04:04:47 PM »
this is the last thing i did on my bike :)
 I've decided to buy a second hand ..... from another friend whom got a new ....... ;D
 guess now, i just made a few pictures which are needed :P
the thing needs a powersource:
the red button is an off/on button  ;D(5 amp max)
and this was also needed  8)
« Last Edit: September 13, 2006, 04:15:30 PM by JohnK6 »
Offline JohnK6
« Reply #108 on: September 14, 2006, 08:13:59 AM »
I mounted a GPS the streetpilot III
that's all I hope you liked it all to read.
John.
Offline dusterdude
« Reply #109 on: September 14, 2006, 12:05:07 PM »
groovy,thanks john
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
ktp1598
« Reply #110 on: September 14, 2006, 02:11:05 PM »
Excellent!
Offline JohnK6
« Reply #111 on: September 14, 2006, 02:31:26 PM »
just one picture to post i had made a dyno run, with a engine witch needed attention
after that the guy said the gasneedle one clip lower(gasneedle higher), and the fuel... 2 measures higher i went from 110 to 125 and than it runs ;D
« Last Edit: September 14, 2006, 02:39:44 PM by JohnK6 »
Offline JohnK6
« Reply #112 on: September 14, 2006, 02:42:24 PM »
bump  ::) putt the wrong dyno in here ;)
« Last Edit: September 14, 2006, 03:04:05 PM by JohnK6 »
Offline JohnK6
« Reply #113 on: September 28, 2006, 03:45:10 PM »
i was talking somewhere in this thread about a 822 cc Kit, here are a few pictures of it 8), I'm going to use CB900 Bol'dor pistons
(the 836 cc is difficult to get here in Europe)
pistons and rings
each cylinder with it's own piston
(the boring i couldn't do , luckily i know a man who knew how to do it  ;D
special gasket
and just a nice Pict
all this will be used in my cafe-racer project, i open a new thread for it  ;D
« Last Edit: September 28, 2006, 03:53:11 PM by JohnK6 »
Offline mrbreeze
  • Not your average
« Reply #114 on: October 16, 2006, 11:24:44 PM »
I saw this post awhile back but didn't follow it. I'm glad I reread it.Lots of great info with excellent pictures.I assumed it was put into FAQ but didn't see it there(it really should be somewhere for reference).Anyway,I put it on my favorites so I can go back & have a peek!!! Good deal John.
MEMBER # 257
Offline cleveland
« Reply #115 on: October 17, 2006, 09:40:20 AM »
This is with out question the best thread I have seen on this forum.  GREAT JOB!!  Thanks for sharing.
Offline MoTo-BunnY
  • The 'Torque 'er Down 'till it Strips Then Back 'er Off a Quarter Turn', Type of
  • 1973 CB500 ~ member #3791
    • http://instagram.com/moto_bunny#
« Reply #116 on: October 17, 2006, 08:33:26 PM »
wOw. ..  .very very well done .. ..   I think you need to write your own shop/service manual! like, seriously!!!  ;D
I really am amazed at the dedication and skills so many of the sohc4 peeps have here, shown in these forums. I am just a happy lil' sponge here, soaking up all this knowledge and giving me the motivation (and courage? lol) to tackle my own projects.  ::)
T H A N K   Y O U  for sharing!!
---> instagram.com/moto_bunny# <---
[img width= height=]http://farm4.static.flickr.com/3440/3846213109_ae572002d4_o.gif[/img]
hoppin' on down the bunny trail . . .
1973 Honda CB500K2
1970 Ding-How aka Nova R-S w/3.5HP Tecumseh MiniBike
1970 Taco Model 22 deluxe w/3.0HP Briggs & Stratton MiniBike
1973 GMC Vandura 3/4 Ton Van (350CID V8)
1973 Dodge "Chinook" RV (360CID V8)
1985 Toyota Tercel Wagon SR5 (4WD - 3A engine)
1982 Toyota Pickup Truck (2WD - 22R engine)
1962? DriveX Pack-Mule (Tote-Gote clone)
1989 VW Jetta GLi 16V
1991 Diamondback Mtn. Bike
Offline joeson
  • back in the day
« Reply #117 on: October 17, 2006, 10:26:49 PM »
fantastic read and the pictures are great .This is why I'm on this forum no where else is this availible
cracka'mybackjack
Offline Nate
    • Alternative Cruisers BB
« Reply #118 on: October 18, 2006, 02:57:12 PM »
I gained more insight in the last 30min of reading this than i have in days with a Honda manual ;D
Rainmaker
« Reply #119 on: October 23, 2006, 08:32:54 PM »
JohnK6.....like the others I am totally impressed with what you're doing here.  Your chronicles here are an inspiration for others to follow suit rather than part out that barn bike.  I had to post a High Five for you but I also noticed something that I want to make sure you correct.  On September 4th this year reply #42 you show the parts going back into your front disc brake caliper. I may be mistaken but the picture shows your brake piston in backwards. The solid side goes in first otherwise your fluid may be absorbed into the cavity of the piston and cause spongyy front brake response or possibly brake failure. Wouldn't want to lose you.  If I'm wrong or this has been corrected......great. Keep up the great work.  How do you take all those pictures without getting grease all over the camera?   Cheers,
Offline Rsnip988
« Reply #120 on: October 24, 2006, 01:42:51 AM »
Ditto
RKS
R.K.S.
1976 CB750 K6 Full
1976 CB750 K6 Cafe'ish
Offline 750goes
  • it will live
« Reply #121 on: October 24, 2006, 02:26:18 AM »
rainmaker,
if you have done what this guy has done, then forgive him one small mistake if that is what it is....appreciate the post for what it is ............an awesome effort .................
Offline JohnK6
« Reply #122 on: October 25, 2006, 11:42:41 AM »
I want to make sure you correct.  On September 4th this year reply #42 you show the parts going back into your front disc brake caliper. I may be mistaken but the picture shows your brake piston in backwards.   If I'm wrong or this has been corrected......great. Keep up the great work.  How do you take all those pictures without getting grease all over the camera?   Cheers,
It is in the rightway, it's a solid brake piston (homemade from an rvs 316-rod), when i had an original one you were right :)
and about the camera :-X it's all greasy only the lens is clean  ;)
John.
« Last Edit: October 25, 2006, 12:00:48 PM by JohnK6 »
Offline Rsnip988
« Reply #123 on: October 25, 2006, 12:32:50 PM »
If you dont mind my asking how did you change your fork oil, ws it difficullt, and are there any special tools needed?
RKS
R.K.S.
1976 CB750 K6 Full
Offline JohnK6
« Reply #124 on: October 25, 2006, 01:01:12 PM »
If you don't mind my asking how did you change your fork oil, ws it difficullt, and are there any special tools needed?
RKS
it's an easy job,
 butt do it one fork each time !!!! so first the left one and than the right one or first right and than left ;)
get the m6 bleeder(no-27)- bolt in the bottom at the side of the fork out, let the old oil out push the fork in and out (so most of the oil gets out.)
renew the copper ring on the M6 bolt
than take the big bolt(no-22) on the topsite of the fork off (watch out, do first one fork, and when your finished than the other one)if you do both the front will go to your frontwheel (don't know the English words for it and you say :#:&:$% or so ;) )
fill oil in (about 155cc)
get the big bolt in (it's a little difficult with spring, use a socketwrench)
and only when the big bolt is in you can take the big bolt from the other fork out:)
and do the same on the other fork
the job is: in dutch it's easy, in english also, butt when you're dutch and you have to think in english it's getting difficult to translate  :P
« Last Edit: October 25, 2006, 01:07:51 PM by JohnK6 »
