Author Topic: Cafe Racer another level? What could be new in cafe racer market?  (Read 5086 times)
Offline GroovieGhoulie
  • I have to return some videotapes.
Re: Cafe Racer another level? What could be new in cafe racer market?
« Reply #25 on: September 06, 2006, 04:07:00 AM »
Earlier you mentioned wiring harnesses.  Perhaps you could do one that would relocate the electrics and fuse panel and turn the battery, so the CR tank could be used, or the under-seat area could be cleaned up and seen through.
Offline flatblack
« Reply #26 on: September 06, 2006, 04:26:16 AM »
Interesting, thought-provoking thread...
Here's a question I've been pondering on my 750K8: What air filter options are there beyond the stock airbox and pods? I don't want to run without a filter. The stock airbox is, well, stock, and I think the pods look cheap.
Some kind of chromed metal shroud with a single oiled foam or paper filter seems like a nice option. It doesn't have to be huge and there are a lot of filters out there that would fit.
I'll go take my meds now...
fb
'76 CB400F
'78 CB750K
'04 CBR600F4i
'76 Yamaha RD400C
'79 Yamaha RD400F Daytona Special
'84 Yamaha RZ350
Dirt bikes?  Sure...
Offline ChrisR
« Reply #27 on: September 06, 2006, 04:27:05 AM »
Didn't steviemac do a good job on his cafe in relocating battery, wiring etc so the frame was 'see-through' behind the carbs? Though I think his is a 550 not a 750.
ChrisR
1977 CB550F
1975 CB550K
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #28 on: September 06, 2006, 04:33:15 AM »
       Has anyone, with a 750, ever thought about doing some tube replacement so that the oil would be in the frame? Then you could clean up the area between the motor ans the rear wheel. Just a thought, since I'm not sure how else you could do it unless you built a tank and hid it in the hump of a cafe seat and tried to hide the electrics elsewhere. Just a thought.  Later on, Bill
Member # 1969
Offline bill440cars
« Reply #29 on: September 06, 2006, 04:50:12 AM »
       Back on the oil tank thing. If you did a gastank like the one DME did and could seal it properly, you might make the rear section the oil tank. The old Indian motorcycles did that. Worth a thought?
                                             I'm Still Thinking (I know....That's Scary)
                                                               Bill
Member # 1969
Offline 6adan
« Reply #30 on: September 06, 2006, 06:22:25 AM »
Something like the Tracy body only in more of a cafe style.Dannie
1970 CB750 JDM,1975 GL1000, 1979 GL1000, 1979 CBX, 1995 GL1500, 2000 GL1500CT Valkyrie, 2008 GL1800 Trike.
Offline pmpski_1
  • Beast V and Beast I
    • My CB550 related blog on MSN Spaces
« Reply #31 on: September 06, 2006, 07:42:32 AM »
You missed the point, With graphics costing chicken change, there would be no reason other than wanting to , to have a one color bike.
300 dollars for a 3000 dollar paint job will be great. But if this guy gets a whiff of what others are getting for the same work that he is doing, you're only gonna get about 5 -10 tanks from him before he starts charging more.
(unless he's already won the lottery and doesn't need the money, or he's against the idea of money for some reason or another).
Or maybe you have a secret to prepping the pieces before and during painting?  8)
Old Bike Barn used to have cafe kits with different stages. No brakes, but I think they offered bushings and mini tachs\speedos. And of course, the required clubman bars.
Beast   I: 1974 CB550K
Beast IV: 1976 Chevy Blazer
Beast  V: 2003 Buell XB9S
Offline Rushoid
  • Shameless
« Reply #32 on: September 06, 2006, 08:02:14 AM »
Hey, how 'bout a steering stabilizer?  ;D
Seriously, what do they do? Just act like a shock absorber against wobble? I apologize for my noobness, but I was experimenting while riding yesterday and noticed that with no hands on the bar, there was some wobble. I don't feel anything in my hands or arms though. Just wondering...
Ummm since you mentioned noobness....have ya tightened down the steering bearing nut lately? Slop in the bearings of the steering head will do just that.
Might be time for an adjustment or some tapered bearings in the ol' steering buddy.
Thanks, kghost. No, I haven't tightened it. I've checked for play and freedom of movement. Those seem fine, but I'll go ahead and tighten that bad boy up! Tapered bearings are already on the winter projects list. ;)
Go Cards!! Go Colts!! Go Bucks!!
SOHC/4 Member #3452
Offline dusterdude
« Reply #33 on: September 06, 2006, 10:05:25 AM »
                                                               Bill
yea,im scared.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Rhonda750F
  • In the Works!
    • Gallery:
« Reply #34 on: September 06, 2006, 11:52:56 AM »
Wouldn't having the oil tank incorporated at the end of the gas tank burn the balls while riding? :o
I like the idea of making a harness to move the electronics to the back and using blade style fuses.  You should make this product it's pure gold, gold I tell ya!
Now how about a mod for the people with rear disk setups.  That Damn stabilizer bar is too close to my tire.  I want a wider wheel back there.  Any thoughts on how to move it further out, spacers, different bar etc.
How about a better swing arms, tubular like the ones on the Ducati Paul Smart/Sport 1000?
with single dampers?
It maybe too much stress on the OG frame, but I would certainly pay for a nice swingarm that can support wider wheels and more modern shocks (eye/clevis options)
Something I've done for cosmetic purposes only, is lower all the instruments (tack, speedo, dummy lights, ignition, and headlight) about 4 inches maybe more, to get them out of the sky.  They now sit about tank level a little more streamline.  This could be an easy kit to make.  It involves making a lowering bracket for the brakeline junction to make clearance for the headlight, some longer bolts w/ spacers for the instruments and ignition, and some headlight ear brackets mounted upside-down. This kit is pantent pending.  JK ;D
..........or maybe I'm not!
Paul Z.
1978 CB750 F rolling chassis for sale. PM me.
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #35 on: September 06, 2006, 12:03:42 PM »
custom frames.
No.
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #36 on: September 06, 2006, 12:17:26 PM »
Turbo option ?  ;D
Offline chrislib
« Reply #37 on: September 06, 2006, 04:32:05 PM »
 Bill
Would`nt that heat the gas up a wee bit? The idea of 200 some odd deg F fuel is kinda scary. I havta say, I love the way you folks think "outside" the box, ideas ALL OVER the place...awesome!
Chris...closet Idlefiddler
#1975
1973 CB750K...CANDY BACCHUS OLIVE
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #38 on: September 06, 2006, 04:45:08 PM »
I've seen on one of those "build shows" a gas tank split in 1/2 with oil on one side, gas on the other.
Doesn't mean it works though. ;D
Better minds than mine will input info
JP
« Reply #39 on: September 06, 2006, 05:00:29 PM »
My big secret for my 750SS is out :'(
My oil tank will be in the gas tank at the front right corner.  I have two SS tanks that have already been cut open and a tank is being installed.  This is in no way a new concept and is actually used on the true CR750 alluminum tanks and many many older bikes.  With around 4 gallons of gas to spread the heat and a good working oil cooler from Terry in Australia, it will actually provide more performance by keeping the oil at tempratures of around 160F!
Think about it, how hot do you think the gas is on a 100F day?  Fuel being hot or cool doesn't make nearly as much difference as engine temp.
Also, for whoever asked about a 550- they have no external oil tanks, so the electrics can just be put in the bump stop and that's it.
JP
Offline bill440cars
« Reply #40 on: September 06, 2006, 05:47:30 PM »
                Just for Info, the old Indians had a 2 piece gas tank and one half had the oil tank built into it.
         That setup worked for quite some time (now the oil part was in the front of the right hand part I
         believe. That's why I made the suggestion and it was just to throw something out there that
         might give someone ideas to create something that would work. Hey, I don't even have a 750
         SOHC but, I'm trying to give ideas to help others.
        later on, Bill
Member # 1969
Offline cafehonda
« Reply #41 on: September 07, 2006, 07:17:04 PM »
The problem with a "box" cafe is the same thing that's wrong with cookie cutter choppers. The style is by definition individual. I'm all for being able to buy parts off the rack, cuz it would cut down on the hundreds of hours I seem to spend prototyping and then trying to convince someone to pay more than $50.00 for a duplicate. The problem is most of us are cheap bass-turds. And I for one am sick of workin' for free! :P
Anger is an energy. May the road rise with you.
73 cb750 cafe
