Author Topic: 1975 Honda CB400F Build  (Read 29385 times)
Offline Jore
Re: 1975 Honda CB400F Build
« Reply #100 on: May 19, 2014, 10:03:21 PM »
Nice looking bike mate! The next time you take apart your carbs and airbox (because you will), use a bike inner tube, like so:
http://forums.sohc4.net/index.php?topic=112310.0
This trick makes it easy to mount the whole thing.
1975 CB400F owner
-Having a vintage motorcycle is like having a moody girlfriend.
My 466 build: http://forums.sohc4.net/index.php/topic,146494.0.html
Offline inv3ctiv3
« Reply #101 on: May 20, 2014, 10:22:14 AM »
Ok awesome!
Now I need to figure out why it won't start after installing the Dyna S :( Anyone ever had that happen when putting one of those in?
1975 CB400F
Offline kiwikk
  • Plumbing by Michelotti
« Reply #102 on: May 21, 2014, 12:49:14 AM »
I'm sticking with ye olde points so I can only suggest you have a look at this list of documents.
I'm sure I spotted one or two referring to Dyna ignition set up and troubleshooting specifically for CB400F
Offline inv3ctiv3
« Reply #103 on: May 27, 2014, 09:38:03 AM »
Well I'm an idiot and installed the magnet backwards on the rotor for the Dyna S so I flipped it and it started right up. It revs much better now but it still bogs on WOT and over 7.5k RPM so I guess I will be taking the carbs out again :( I took it by the local cars and coffee meet this weekend and it's amazing how many people love the CB400F haha.
1975 CB400F
Offline cgarbe
« Reply #104 on: May 27, 2014, 12:31:32 PM »
Parts are starting to roll in!
Dyna S Ignition
Various bolts/washers
Speedo Cable
Tach Cable
Clutch Cable
Timing cover gasket
OEM Honda Petcock
Awaiting on a throttle cable, carb rebuild kits and a couple of other little things can't wait to have a garage weekend soon!
Where did you get your cb400f Shop Manual?
« Last Edit: May 27, 2014, 12:42:06 PM by cgarbe »
1975 Honda CB400F
1978 Honda CB750F
Offline inv3ctiv3
« Reply #105 on: May 28, 2014, 03:01:24 PM »
Dyna S Ignition
Speedo Cable
Tach Cable
Clutch Cable
Timing cover gasket
OEM Honda Petcock
I downloaded it on here somewhere and had it printed and bound.
1975 CB400F
Offline cgarbe
« Reply #106 on: May 29, 2014, 10:24:41 AM »
That's what I thought...I just looked very professional like someone was making them.  ;D
Thanks!
1975 Honda CB400F
1978 Honda CB750F
Offline inv3ctiv3
« Reply #107 on: January 04, 2015, 10:47:14 PM »
Ok guys I'll update this.
I've just been riding and enjoying the bike but the new battery I got is dead! I talked to a mechanic and he thinks the shorting out at full throttle is either from the stator or my rectifier/regulator not working and the bike is trying to draw power from the battery which is why I'm going through batteries. Does this make sense? Should I order a new rectifier?
1975 CB400F
Offline strynboen
« Reply #108 on: January 05, 2015, 07:52:00 AM »
easyer to use your fine new book.think all are in the book..
.and thek the ohm in 3 yellov generator vires..and the elektromagenet konnektions...just pull the sidecover,,at chail side..and find the konnektors..open them klean all up and use a mulitmeter..all data is here on forum..even how to put the terminals to the right konnektors
i hate all this v-w.... vords
Offline inv3ctiv3
« Reply #109 on: January 05, 2015, 09:52:33 AM »
I should have added more info, the bike revs fine when in neutral and no load but when riding it has a real struggle at anything past 3/4 throttle or like 6k RPM....So I guess I could hook up a multimeter to the battery and ride and hold the meter between my legs and see?
1975 CB400F
Offline strynboen
« Reply #110 on: January 05, 2015, 09:56:34 AM »
if voltage are low it vil splutter..but most problems is fuel relatedet..dirt in tank/rust/bloking for fuel.=..leaking kaburettors..but full battery are  first thek
Offline strynboen
« Reply #111 on: January 05, 2015, 10:12:51 AM »
those meldet red vires(you fixed erlyer) can be  corsed by a reversed battery..po can have reversed it for a few sekunds..then the regdifier are meldet..but thek the redifier diodes..as you thek the vindings ohm..the 3 yellov vires are kommon konnekted so readings vill be the same between 2 of them at time
Offline inv3ctiv3
« Reply #112 on: January 05, 2015, 10:24:31 AM »
I've cleaned the carbs out, got a brand new OEM honda petcock and added a Dyna S ignition system so I'm thinking this could be it, I'll break out the multimeter and see what I find!
1975 CB400F
Offline inv3ctiv3
« Reply #113 on: January 27, 2015, 06:07:30 PM »
New problem, got a ricks motorsports R/R combo and installed it. Nike starts and runs great except after a few minutes it just blows the main 15amp fuse! Any ideas? I've checked all the grounds and they are fine, is 15amps too low?
1975 CB400F
