Author Topic: Shipping motors  (Read 763 times)
Offline texianbiker
Shipping motors
« on: October 22, 2014, 06:36:52 AM »
I'll be shipping a CB750 motor in the near future and am totally ignorant of the process.  So, from out of the darkness I have some questions.
(1) In your experience which freight carrier is most suited to this specific task?
(2) Do they supply the crates or is their a commercial source for them?
(3) If there is no crate source available is there a set of directions for the construction of one posted somewhere?  This engine is a very early number K0 die cast and shipping damage is not an option.   Thanks in advance for your response.
Re: Shipping motors
« Reply #1 on: October 22, 2014, 06:53:28 AM »
You can strap or mount it securely to a small pallet and build a box around it if you think needed then drop off at a freight hauling company that has a terminal close to your buyer for pick up.
Re: Shipping motors
« Reply #2 on: October 22, 2014, 06:55:31 AM »
Strap it to a pallet and wrap it with a protective plastic.
Forward Air will most likley be the least expensive. https://www.forwardair.com/
Insure it!
Offline Old Scrambler
Re: Shipping motors
« Reply #3 on: October 22, 2014, 07:59:12 AM »
+1 with above.............I use wood to block the motor so it cant rock on the pallet..........then strap it down and build a box with screws.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline alacrity
  • Ride, Optimize, Repeat
Re: Shipping motors
« Reply #4 on: October 22, 2014, 11:34:44 AM »
+! on the pallete. you can make this easily out of scrap wood - just make the thing a uniform shape and make it strong. I probably "overkilled" it last time i sent one...but... it got there safely.
I built a little pallete.  I built a wood frame and used the engine mount bolt holes to bolt the thing in place (with long threaded studs.  I wrapped the engine tightly in thick plastic and then decided to double protect the fins. I made an "inner box out of heavy cardboard and fitted that closely around the top-end (covered as I said with heavy clear plastic.)  I then used a couple cans of that nasty/toxic smelling expanding gap-filling foam, smushing it into place by pressing on the cardboard to which it eventually adhered. It hardened and I then made a heavy corrugated box out of sections to go around the whole shebang.  I felt pretty sure that they could drop it off the forklift from 8' and the engine would have been fine, but luckily, they didn't test that.
I recently restored and sold a 77 cb750f, and am nearly finished with a (former basket case) cb750k5.  This is a place to share, learn and enjoy.  I am grateful to and for 99+% of this site's membership.
Offline Harsh
  • 74 CB750 and two 72 CB350's
Re: Shipping motors
« Reply #5 on: October 23, 2014, 07:10:35 AM »
I have shipped smaller motors in a cooler before.  Built a simple block to keep it off the bottom and to keep it from sliding around inside the cooler.
Offline grcamna2
Re: Shipping motors
« Reply #6 on: October 23, 2014, 07:42:15 AM »
a plastic cooler? they must sure be strong and protective enough
75' CB400F/'bunch o' parts'
Offline Harsh
Re: Shipping motors
« Reply #7 on: October 24, 2014, 07:23:13 AM »
Yep like an Igloo cooler.
Offline grcamna2
Re: Shipping motors
« Reply #8 on: October 24, 2014, 07:32:40 AM »
How do you close the lid to keep it from popping open in transit Harsh ?
Re: Shipping motors
« Reply #9 on: October 24, 2014, 07:41:14 AM »
You could use stretchtite, people do it for luggage at airports.
Offline Harsh
Re: Shipping motors
« Reply #10 on: October 24, 2014, 10:45:06 AM »
Packing tape.  I like the stuff with the string in it.
