Author Topic: My 750 k2 build  (Read 5436 times)
Offline McBain
Re: My 750 k2 build
« Reply #25 on: March 04, 2016, 11:07:59 PM »
Only one with the whole assembly, I'll get one with a measurement. See how it looks like the wear marks not consistent with were the points are running now?
Sent from my SM-G900I using Tapatalk
Offline McBain
Re: My 750 k2 build
« Reply #26 on: March 05, 2016, 05:36:17 PM »
19mm from the points plate.
Offline McBain
Re: My 750 k2 build
« Reply #27 on: March 10, 2016, 04:50:54 PM »
Does anybody have any advice on putting the tank decals on my k2 ? Measurements ect. Or just put them on where they look correct?
Re: My 750 k2 build
« Reply #28 on: March 10, 2016, 05:43:03 PM »
Get one on where you like it.  Use painter's tape from fixed reference points to the decal.  Then pull off the tape to get your target and affix the second decal.
Re: My 750 k2 build
« Reply #29 on: March 10, 2016, 06:26:57 PM »
read somewhere here recently someone was having the same problem...turns out, if I remember right, shaft from another smaller bike fits and otherwise functions but is too long.  Just replace it.
Offline McBain
Re: My 750 k2 build
« Reply #30 on: March 10, 2016, 08:20:07 PM »
Pic of it installed, definitely doesn't look like it is in far enough. I removed the shaft. Total length of 75mm
Offline Davez134
Re: My 750 k2 build
« Reply #31 on: March 10, 2016, 09:46:26 PM »
If you don't get an answer before tomorrow, I have one at home I can measure to compare with. I get off work in 11 more hours (but who's counting
Offline McBain
Re: My 750 k2 build
« Reply #32 on: March 10, 2016, 11:43:48 PM »
Cheers mate! I think it's correct, but the thread in the crank is damaged so therefore not letting the shaft go in all the way.  And of course the only tap Im missing in my kit is an 8mm.
If you could send me a measurement that would be awesome.
Offline Davez134
Re: My 750 k2 build
« Reply #33 on: March 11, 2016, 08:10:34 AM »
Ok, here you go. This one was from a running K2 motor, so I know it's right.
75mm
50mm
Offline McBain
Re: My 750 k2 build
« Reply #34 on: March 11, 2016, 01:54:50 PM »
Thanks davez1324, that's the same measurements as mine. Must be damaged internal threads. I'll tap it out today.
Offline Davez134
Re: My 750 k2 build
« Reply #35 on: March 11, 2016, 03:30:43 PM »
Be careful with the metal shavings and debris, oil flows back there.
Offline McBain
Re: My 750 k2 build
« Reply #36 on: March 13, 2016, 09:28:50 PM »
Tapped out the thread. All good now! Wonder how long the previous owner had been running it like that.
Also blasted my tank today got a very nasty surprise! Looked pretty neat beforehand!
Offline McBain
Re: My 750 k2 build
« Reply #37 on: March 13, 2016, 09:38:41 PM »
What do you guys think?  Repair or source a new fuel tank?
Offline mystic_1
  • 1970 CB750K
Re: My 750 k2 build
« Reply #38 on: March 13, 2016, 09:45:07 PM »
That's a shame, looks like someone went after it with a stud gun at some point.
I say it's repairable but it would be a lot of work.  I'd look into sourcing a replacement.
mystic_1
- John Augustus Shedd
Offline McBain
Re: My 750 k2 build
« Reply #39 on: March 13, 2016, 09:50:23 PM »
It definitely looked better with paint on it!
Re: My 750 k2 build
« Reply #40 on: March 14, 2016, 11:56:20 AM »
That metal looks like it has been through a wringer or rather pushed and pulled.
IMHO, I'd source a cleaner looking replacement.
Offline McBain
Re: My 750 k2 build
« Reply #41 on: March 14, 2016, 03:37:01 PM »
It's a hard one! Most tanks in Australia seem to be around  $500 for a decent one!
Re: My 750 k2 build
« Reply #42 on: March 14, 2016, 04:30:13 PM »
Yikes!  Maybe you should ask Terry if he has a spare.
Offline McBain
Re: My 750 k2 build
« Reply #43 on: March 14, 2016, 10:36:23 PM »
So I think I'm going to have a bit of a play around with the tank I've got and see what I can do. Luckily I have an extremely good paint and panel guy that helps me out!
