Author Topic: First bike: 1978 CB750 K8. Let's turn this piece into a solid runner.  (Read 11133 times)
Offline therobbstory
  • I hug too hard and get lost in malls.
    • Robb Hohmann Photo
Hi all, first post. Let's jump right in.
After 8 years of living license and car-free in our nations capitol, I decided on a whim to get a bike. After three arduous trips to the DMV, a weekend spent taking the MSF, and many dollars later, I'm the proud recipient of a plastic card with an M on it.
I wasted no time in finding a scoot. I negotiated an unbelievable deal on a CB750 after a few laps around the block and hasty visual inspection. I was concerned about it being a much bigger and heavier bike than the Rebel 250 I rode in the MSF, but ten minutes into my 10 mile ride home from the PO's house, I felt totally comfortable and at ease with the size. Manuvering around a parking spot with the engine off is a total pain, but slow speed handling in 1st and 2nd feels really natural.
So this is my project log. I'm not interested in turning it into a hipster bike. I just want something safe and reliable to ride for a year or so while I build skills and save up for something really impractical like a BMW R90.
Engine
  • runs
  • starts instantly with starter
  • Haven't attempted a kickstart, but I'm told it works
  • Oil leaking from head gasket
  • Oil leaking from oil tank cap
  • Won't run unless choke is fully on. Choke has a tendency to open back up and engine runs rough until closed again.
  • Throttle is a bit twitchy. Doesn't spring back to idle unless twisted. Could be the stock cables on the clubman bars.
Brakes
  • Rear brake is stronger than the front
  • They feel a little soft
Electrical
  • All lights are non-stock
  • Stupid adhesive strip LEDs for tail light. One strip for running light, two strips for actuated brakes
  • Turn signals are very intermittent. Flipping the switch will turn them on, but they only blink sometimes. There's an audible chime when they are working which is cool. Is that a stock feature?
  • Headlight seems dim. Not much difference between hi and low beam
  • Horn button puts a load on the electrical as evidenced by dimming headlight. Probably just a bad horn. Or a short somewhere.
Fuel
  • delivery seems okay, but I haven't had the bike over about 40mph
  • It was dark when I looked with a flashlight, but it looked like there was a little bit of rust floating in the full tank.
  • No idea what condition the carbs are in.
Cosmetic
  • Has clubman bars. Uncomfortable, but they don't hit the tank
  • stripped tank has a ton of surface rust, but clear coated. No big dents or scratches, though. I might paint this.
  • Some PO was huge Ravens fan and rattle canned the whole bike purple and black. There are still some purple screw heads and brackets.
  • some light surface rust on spokes
  • original seat, but huge tears towards the front. Might do a tracker seat, or just recover stock seat
And here's some eye candy. She's rough, but she's mine.
« Last Edit: November 03, 2015, 10:46:56 AM by therobbstory »
Re: First bike: 1978 CB750 K8. Let's turn this piece into a solid runner.
« Reply #1 on: November 03, 2015, 11:12:51 AM »
Thanks for the advice!
The battery is actually only a month old.
I'll check into the Hondaman book. I've got a Clymer which I've already learned a lot from. Very thankful that resources like this forum exist!
I've owned the bike less than 24 hours. I'll have a lot more time to dig in once the colder temps set in and I move the bike indoors.
Offline oldhatt45
  • The person called in at the last minute to share the blame is the...
  • Just an Old Guy that's gone to the Dogs
« Reply #2 on: November 03, 2015, 02:32:07 PM »
therobstory,
+2, no +3 to what calj737 said.
AND DO BUY THE Hondaman Book, as well as a set of JIS screwdrivers (including the Impacta)!!!!!!
Charlie
« Reply #3 on: November 04, 2015, 06:52:28 AM »
Many thanks, gents!
I took it out for about an hour after work last night to get comfortable riding in city traffic, and to get a better feel for the bike now that my nerves have calmed. Took off down my street feeling like Steve McQueen only to have the bike sputter and stall at the first stop light. Drained the battery trying to restart before realizing I hadn't turned the fuel on. Kicked right over and I was on my way.
My main priority for this weekend is to solve the won't-run-without-full-choke issue. I'm guessing the idle jets are all gummed up starving the motor of fuel. Would that make sense? The PO said he'd never done any carb work, and he owned it for a year, which would include a mid-atlantic winter. I'm going to pull the carbs and air filter on Sunday to see what I'm working with.
The other big issue is the sticky throttle. It's damn near impossible to get any kind of smooth throttle response off of idle. It's kind of on or off until you get into 2nd and 3rd. I'm hoping new cables (all of them have rotting housings and should be replaced) of the correct length on some normal bars will help.
Read the Clymer on those procedures and feel pretty confident in doing the work myself.
Will get some better photos this weekend. It's dark out by the time I leave work. I picked a great time to buy a bike  :o
« Reply #4 on: November 05, 2015, 09:45:06 AM »
Thank you, o wise and merciful master!
I'm going to pull the tank this weekend and clean the inside using one of the myriad methods found on this forum.
I've also ordered some carb kits with stock jets, fuel lines, and some filters.
Quick photo from this AM, which has prompted me to order a cover since she'll be living outside the next month or so.
Suicide Machine by Robb Hohmann, on Flickr
Offline Desert-SOHC
  • It's old
« Reply #5 on: November 05, 2015, 09:54:39 AM »
Yup, those throttle cables look to be the stockers and to long by the pic.
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
« Reply #6 on: November 05, 2015, 11:09:32 AM »
Owning a K7, I am not the biggest fan of the bulbous gas tank, but I have seen them work decently with tracker-style seats.  It's a personal taste thing, though.  If you love it (or just don't care to spend to replace it), keep it.
« Reply #7 on: November 05, 2015, 11:35:17 AM »
Just bear in mind the counsel about the carb kits...
Went with Honda OE parts from Dime City. Got some pre-drilled bars and a set of replacement cables, too.
« Reply #8 on: November 05, 2015, 11:36:52 AM »
I was wondering about this tank. Is it not stock?
I do plan to go with a tracker seat, but cosmetics are a long way away for now.
« Reply #9 on: November 05, 2015, 12:05:53 PM »
The tank is stock for the K7 and K8 (1977-1978) models.  If it works and you are just trying to get the bike into reliable running condition, don't worry about it right now.
For the future, you can also use the earlier model tanks from the 1969-76 CB750K models or the 1975-78 CB750F (Super Sport) models.  Using a different tank will require you to adjust the spacing between the tank and seat -- if you are still planning to use the stock seat on hinges.  Essentially, you will need to unscrew the seat hinge mounts and adjust the mount points to line up with the frame rails (but accommodate the longer or shorter length tanks).  It is not brain surgery.
For me, I really didn't care so much for the K7-K8 tank and used a CB750F tank.  Others have done this too.
« Reply #10 on: November 05, 2015, 01:03:13 PM »
I don't believe they resell Honda OE parts. They resell aftermarket kits to the best of my recollection. Keep your receipt in case they are not true Honda brand.
Interesting. Says here they're gen. Will see in about a week when they arrive.
http://www.dimecitycycles.com/77-78-vintage-honda-cb750-carburetor-gasket-and-o-ring-kit.html
« Reply #11 on: November 05, 2015, 05:56:46 PM »
Subscribed, I had a K7 until just recently.  Personally, I dont buy parts from DCC, especially Honda parts.
I like Partzilla and they are cheaper here...
http://www.partzilla.com/parts/detail/honda/HP-16010-405-004.html
« Reply #12 on: November 05, 2015, 07:58:57 PM »
Good to know. I just went with DCC because they're in my hometown.
Rode over to my girl's house tonight. Stalled about a block into my ride and walk-of-shamed home. Indicator lights were very dim, and electric start would obviously not work. Threw it on the charger for about an hour, and was able to kickstart it. The bike was idling rough, and stalled out  again at a light on Pennsylvania Ave. I managed to kickstart again but, only with 1/4 throttle. Idle was real rough unless I kept it above 2-3k. I assume that's carbs.
Is this also indicative of a bad charging system, or do these bikes just have ineffective charging in low-RPM city riding? Another system for me to consider refreshing, I guess.
EDIT: Tonight's homework - http://forums.sohc4.net/index.php/topic,1012.0.html
« Last Edit: November 05, 2015, 08:03:50 PM by therobbstory »
« Reply #13 on: November 05, 2015, 08:38:37 PM »
Sounds like a charging issue. Should have no issue riding in the City.
« Reply #14 on: November 09, 2015, 02:51:05 PM »
Had an existential crisis of buyer's remorse on Saturday. After waiting all day for the rain to stop, I got her fired up and planned to ride back to my place. Got halfway around Lincoln Park and she #$%* the bed as soon as I came off the throttle at a red light. Crab-walked back to my girlfriend's place and cracked a beer.
Battery didn't seem to be an issue this time, as it cranked strong but just wouldn't fire for more than a second or two. Tried again the next morning with a cold engine and it fired right up. Idle was really rough, so I dicked with the idle screw which I'd recently discovered. Once the bike was warm, I adjusted the idle screw to about 3k and pushed the choke in (PO told me he could only ever ride it with the choke all the way out). It settled down to about 1k, idled beautifully, and I rode home basking in the beautiful sunlight and stares of douchebag DC Sunday brunchers.
So the charging system works, at least well enough. I'll probably put it on a tender for any extended periods where I'm not going to be starting it.
Is it best to give these 750's a warm-up period? Took her out again today to return the PO's tags, and it idled pretty roughly for the first half of the trip. Once warmed up she sang beautifully.
While idling, it sounds like the engine case has an entire socket set rattling around in there. Once I give it some gas, everything seems to sync up and it sounds like a motorcycle again. Is this normal?
Suspension-wise, I noticed a couple knocks from what we in the bicycle world call 'the headset.' I Read a good thread here recently on upgrading a bunch of suspension bits to All Balls, including the main steering bearings. Something I'm considering once I get the engine kinks figured out.
Also got some goodies in the mail today. Cheap-o $20 Amazon amber turn signals to replace the blue LEDs, and Bates-style LED tail light to replace the LED strips. Super bike bars and new throttle cables should be here tomorrow along with the carb kits.
« Reply #15 on: November 09, 2015, 05:18:20 PM »
Performing the full service will give you peace of mind.  It sounds like your carburetors still need ultrasonic cleaning and synching.  New spark plugs and an inspection of your wires -- and a meter test of your electrical harness is a good idea, too.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #16 on: November 30, 2015, 08:51:00 AM »
Hi from Reddit! ;D
--Evan
1975 CB750K "Rhonda"
« Reply #17 on: January 29, 2016, 10:42:47 AM »
Well, sh!t on a biscuit.
Noticed a hearty clatter coming from the head cover on my way home last night. Today, I pulled the tappet covers to re-adjust valve clearances and found the attached image. I can't immediately see where the locknut went, but I'm going to poke around tonight with a flashlight and a magnet.
I'd know pretty quickly if it fell into the cam chain guide, right? What other potential things should I be looking for before I replace the locknut and tappet covers, assuming I find the missing nut?
In other news, I performed all of the 3,000 mile maintenance after acquiring all the requisite tools and test equipment. Carbs weren't too badly out of sync, but I did swap out the points after losing cylinders 1/4 not too long ago. Old points were nasty. I've also got a HondaMan ignition on the way. Couldn't hurt, right?
Offline evanphi
  • Apparently I'm an
« Reply #18 on: February 01, 2016, 05:59:34 AM »
You could also drain your oil and drop the oil pan, that way you'll know if it made it all the way down to the bottom of the case!
--Evan
« Reply #19 on: February 01, 2016, 06:55:41 AM »
Likely what I'll end up doing. Shame, because I did a complete oil  change about 30 miles ago. At least I'll be able to inspect the oil screen. Good time to replace the gasket as well.
Hopefully it's just sitting on top of the head somewhere as other's on the board have reported. Fingers crossed I can find it with a flashlight and magnet. New locknut, adjuster, tappet cover, and seals will be here on Thursday.
« Reply #20 on: February 01, 2016, 07:02:25 AM »
We were on a ride a few years back and forum member Rick heard a loud noise from his motor, and then noticed oil leaking on his pants.
Turned out, the nut came loose and shot THROUGH the tappet adjustment cap!
We rode to the nearest shop, and they just happened to have an old parts bike and sold him the nut and we were back on the rode.
It is most likely still on the head.
« Reply #21 on: February 01, 2016, 07:08:42 AM »
If it's exhaust tappet I would expect the nut to still be under the cover somewhere.
There was a video by somebody here demonstrating how to take off the valve cover with engine still in frame.
Offline evanphi
  • Apparently I'm an
« Reply #22 on: February 01, 2016, 07:10:38 AM »
Reuse the oil. Still fresh! Just drain it into a clean container.
--Evan
« Reply #23 on: February 01, 2016, 07:30:19 AM »
It's the #1 intake valve. I'll pop the tappet cover off so you can see the indentation made by the adjuster. The adjuster threads at the top were completely buggered, so I'm  replacing that, too.
And good call on the oil reuse!
I can't wait for Saturday to do my valves and carb sync. Most of the snow is gone and it's already starting to feel like spring!
Offline evanphi
  • Apparently I'm an
« Reply #24 on: February 01, 2016, 07:43:33 AM »
I thought you could only replace the gasket with the engine still in? I know there are videos of this... The whole cover does NOT come off, in my experience. BUT... I suppose you could get it up enough for a quick inspection...
--Evan
