Poll
Which CB500/550 gets your vote??
Onetruepunk87’s 1972 CB500K1
43 (71.7%)
Kevin's (aka Blackfin5) 1978 CB550K4 "Danielle" aka Toyon Club #5
17 (28.3%)
Total Members Voted: 58
Voting closed: December 31, 2015, 09:43:13 PM
Author Topic: Vote for Bike of the Month - January 2016  (Read 4663 times)
« on: December 16, 2015, 09:01:17 AM »
BATTLE OF THE BLUES!
Build Thread: http://forums.sohc4.net/index.php/topic,137078.0.html
From this:
To this:
Shout out to riverfever (Chris) for those beautiful stock 4-4s (I am envious!):
Build Thread: http://forums.sohc4.net/index.php/topic,130092.0.html
Down to the bare bones:
And on to this:
« Last Edit: December 17, 2015, 06:34:26 AM by CB750 Cafe Racer Fan »
Offline onetruepunk87
Re: Vote for Bike of the Month - January 2016
« Reply #1 on: December 17, 2015, 04:35:32 PM »
I guess I'll get this started, first off I want to thank Raffi and Steve-o for nominating me for BOTM. In the few months since I've had the bike finished I've racked up 960 miles. The bike gets compliments and questions everywhere I go. Sitting at red lights or stopping for gas I'm always telling people all about the bike.
Quick Rundown of the Build:
Engine:
Replaced several gaskets, seals and pucks
NOS Stator Cover
Original style points cover
Painted case
Polished covers
Stainless hardware
Rebuilt carburetors
Original 4-4 Exhaust
Body:
Replaced tank
Frankenstuff side covers
Did all body work and paint on tank and covers myself
Reproduction gas cap/latch
NOS Tank badges
Reproduction side cover badges
Replaced front and rear fenders
Replaced grab rail
Custom-ish Seat
Suspension:
ALL Balls tapered steering stem bearings/races
CB550 Fork Swap
Replaced forks seals/boots
Rebuilt Forks
Replaced fork oil
CB550 fork ears
CB500 K0 Reflectors
Polished fork lowers
Replaced/Rebuilt Rear shocks
Controls:
Cleaned and reassembled hand controls
Painted controls
CB400F Handlebars
Mini "2.5 Speedo/Tach
Bar end Mirrors
Electrical:
Daytona Electronic Ignition
Dyna 5 OHM coils
Dyna Spark Plug Leads
NGK Spark Plug caps
H4 Headlight
Wireing harness retaped
All connections cleaned
Wheels/Brakes:
Replaced wheels
All Balls wheel bearing
Shinko 712 Tires
Goddfrey speedo drive
New 15.8mm Master Cylinder
Braided steel brake lines
Dual Disk Conversion
Rebuilt brake calipers
Goddfrey phenolic pistons
Drilled and champhered Disks
New brakes front and back
Polished rear drum
Misc:
Replaced Front/back sprockets
Replaced Chain
Replaced Clutch Lifter Rod
Replaced Clutch Adjuster
Replaced Horn
Replaced just about every piece of chrome
New headlight bucket
New OEM Clutch Cables
Motion Pro Throttle/Tach/Speedo Cables
Sealed AGM Battery
(apologies in advance for going a little picture heavy)
I don't have many before pictures of this bike, i started tearing into it pretty quickly, but it was bad.
When I picked up the bike It was not in running condition and I really can't say the last time it was on the road. It had gone through at least two owners who had never seen it run and was last titled in 2000.
The bike had no key, no battery, the carbs were off and partially disassembled. It was a mess and a total gamble buying it.
My first task was to get this thing to fire up. So I started out cleaning the carbs. I've been riding and wrenching for a few years but I had never fully disassembled carbs so this was a fun learning experience. The bike came with a nice carb kit with new brass and o-rings but I wanted to use all the original jets I could so I cleaned them all out starting with a pine-sol dip and followed by a healthy dose of carb cleaner and compressed air.
I finished the carbs off with polishing up the lids and bowls and reassembling them.
I mounted the carbs back up, rigged a fuel line, and fired it up. It ran. So I knew I wasn't wasting my time.
I started taking the bike apart now and seeing what was still good on it. The answer was, not much. Every piece of chrome was pitted with rust, the tank had a Kreem liner that was falling apart and it for some reason was filled with rocks. (My only guess on this is that they were put in to shake up and break up the crap but they were left there to solidify to the bottom of the tank.)
I stripped down the bike, pulled the engine, used an angle grinder to remove rust, primed it and painted it with SprayMax2k paint.
The motor I took off all the covers and polished them all up, primed and painted the engine with duplicolor high heat paint, replaced all the gaskets and seals I could and reassembled.
I got a donor tank that wasn't in too bad of shape (or filled with rocks) and stripped the paint, did some body work to fix a few small dings and dents, primed, painted and cleared it. The whole process took about a month itself.
The bike had no sidecovers when I got it so I got some from Frankenstuff and painted them up as well. Primer and paint were just duplicolor with a high gloss SprayMax2k clearcoat. It's a 2 part gas resistant clear that I've used on a couple other bikes.
The wheels like everything else were rusted out so I found a set on craigslist that I cleaned up and, replaced the bearings and put on some new tires.
And to make a long story short (too late) I scoured the forums/ebay/craigslist for replacement parts and built up the bike little by little.
Made some upgrades where I could
and just kept on reassembling...
I'm sure I missed some stuff but that's the gist of it. 14 months of coming home from work and going straight to the garage to get a couple hours of work done. Spending weekends polishing and painting. It's all worth it and this bike now has a new lease on life. I love doing this. It's by no means perfect but this is what you can do with a few tools and a little know how.
I want to thank everyone that contributes to this forum, you're a wealth of knowledge. I can't wait to start tearing into my next bike, a '74 CB750. Special thanks to my dad for letting me pick his brain, use a lot of his tools, and helping me whenever I needed a hand.
Hope you enjoyed following along and thank you again for the nomination
Best of luck to Kevin and his beautiful CB550 cafe.
Thanks,
-Tom
« Last Edit: December 17, 2015, 05:19:38 PM by onetruepunk87 »
Offline Blackfin5
« Reply #2 on: December 25, 2015, 04:20:43 AM »
Hi Tom,
To be honest, I haven't looked at your build thread before now.  I must say, I think my blue beastie will outperform yours with all the engine and suspension mods.  But - you definitely captured the originality and spirit of our classic Hondas, especially using a CB500 as your build choice.  Also, while I farmed out a good portion of the work to professionals (frame, paint, engine (Thx Mike!!), polishing, powder coat, etc.), it seems that you did nearly all, if not all, of the resto on your own with no outside assistance.  Quite the labor of love.  I'm impressed.  Kudos to you Tom!  Although I love the performance of my 550 and she puts a smile on my face every time I ride her, you got my vote, Tom!  Congrats on a superb job.
Merry Christmas everyone!!
« Reply #3 on: December 26, 2015, 10:50:11 PM »
Only five days to vote!
« Reply #4 on: December 27, 2015, 02:24:19 PM »
Hey Kevin,
Yeah, the engine and suspension on my 500 are still stock so you've definitely got me there. But, even after being used to riding my 750 before this, she's still a blast to ride and loads of fun in the twisties. The bike was done on a budget and mostly as weekend project. Just over a lot of weekends  :). I did all the paintwork myself just in my driveway. I stripped the frame with an angle grinder. Lost all my finger tips sanding down the aluminum to get a nice polish and then finished it all off on a bench grinder that I threw some buffing pads on. I drilled the rotors on a bench press. Where there's a will there's a way. Thanks for the compliments and your vote, it means a lot to me.
Your 550 came out phenomenal. Don't sell yourself short, even if you farmed out some of the work you still put a ton in yourself. Maybe if I come across a 550 engine in the future I can send it out to pick up some extra cc's to keep up with yours. Again, great job on your bike, I definitely wouldn't mind having that in my garage.
Hope everyone had a great Christmas and has a happy New Year.
« Last Edit: December 27, 2015, 08:30:41 PM by onetruepunk87 »
Offline flatlander
« Reply #5 on: December 28, 2015, 02:28:06 AM »
guys your bikes are both amazing. danielle is one of my favourite builds here on the forum. it was a very hard decision but i voted for onetruepunk in the end, out of respect for the impressive work you did yourself.
« Reply #6 on: December 29, 2015, 07:41:18 AM »
VOTE VOTE VOTE!!!
« Reply #7 on: December 29, 2015, 06:05:03 PM »
voted.
happy holidays!
« Reply #8 on: December 31, 2015, 03:46:18 AM »
Thanks for voting everyone and thank you for the compliments and kind words! One more day to go.
Have a safe and happy New Year!
-Tom
« Reply #9 on: December 31, 2015, 10:17:59 AM »
Light turn out so far. Let see some more votes!
Offline Kickstart
« Reply #10 on: December 31, 2015, 09:14:55 PM »
Voted...
I would like to kindly request whoever wins to send me a nice high resolution picture of your bike for use in next years calendar.... similar to the one we put together for the BOTM winners in 2015: http://www.lulu.com/shop/sohc4-2016-calendar-bikes-of-the-month/calendar/product-22485533.html
Thanks,
Chris
- Chris
75' CB750F Orange flake (rider)
75' CB750F Blue (Project)
75' CB750F Painted black (Project)
No Reserve Racing #171 AHRMA
« Reply #11 on: January 01, 2016, 07:55:22 AM »
Congrats to OTP....
« Reply #12 on: January 01, 2016, 09:42:35 AM »
Congratulations, OTP, and an honorable mention to Kevin.  I love both of these bikes!
« Reply #13 on: January 01, 2016, 11:34:31 AM »
Thanks Steve and Don and everyone that voted! What a great way to start the new year. I couldn't have done it without all the help from this forum. Now that I've set the bar for myself I'll have to get to work on the 750 I just picked up.
Great job to Kevin too, your bike is definitely just as deserving of a win. Beautiful work!
Chris I'll get a picture over to you asap. The high res ones I have now don't have the prettiest background so I might send you another one once the weather warms up.
Thanks to all and Happy New Year!
-Tom
Offline Blackfin5
« Reply #14 on: January 18, 2016, 06:22:13 PM »
Tom,
Belated congrats to a walk off win!!  Great looking bike.
