Author Topic: Padawan seeking Jedi Night (cb350 four)  (Read 10822 times)
Online Scott S
Re: Padawan seeking Jedi Night (cb350 four)
« Reply #76 on: March 13, 2016, 09:22:37 PM »
 I think it's $21.29 more expensive than the one I posted.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Dos
  • Owner of a cb350f
« Reply #77 on: March 13, 2016, 10:22:33 PM »
This listing has ended
Offline Dos
  • Owner of a cb350f
« Reply #79 on: March 15, 2016, 03:10:56 PM »
metering valves?
can you explain. When ever I do research and look up youtube videos everyone has the exact same one.
Offline jonda500
« Reply #80 on: March 15, 2016, 03:23:06 PM »
They are also called dampener valves. They are necessary to dampen the gauge needle fluctuation - screw the plastic adjusters all the way in so you don't loose them while putting the tubes onto them. With everything hooked up and the engine running, turn them out until the needle is moving, then back in until the needle fluctuation is only slight.
John
A starter clutch thread:
Online Scott S
« Reply #81 on: March 15, 2016, 05:45:08 PM »
 The metering valves are the little (usually) white knobs/valves in the hoses, about two inches below the gauges. Like jonda said, their purpose is to "calm down" the vacuum signal enough to keep the needles from jumping around wildly. All this sounds hard or exotic, but if you ever saw someone do it just once...
'71 CB500 K0
'81 Yamaha XS650
Offline Dos
  • Owner of a cb350f
« Reply #82 on: March 15, 2016, 08:07:57 PM »
haha yeah I've calmed down with it I think I will good be good. Can't find any below 80 which is meh but I'll find the right one. If you guys have a suggestion let me know
Offline Dos
  • Owner of a cb350f
« Reply #83 on: March 15, 2016, 09:38:44 PM »
Here we go!
http://www.ebay.com/itm/like/380985152644?lpid=82&chn=ps&ul_noapp=true
those dampers are split three ways so wont I loose some accuracy if i have one tube going in and the other in in the gauge meaning one is left open? or is that the point?
Offline jonda500
« Reply #84 on: March 16, 2016, 03:40:36 AM »
The gauges in that listing don't seem to have the dampening valves - mine came with four white plastic valves, two long brass tubes and two short,
John
p.s. I had to cut the rubber tubes to insert the valves just below the gauges
- I used a lawnmower fuel tank and a tee piece
Online Scott S
« Reply #85 on: March 16, 2016, 04:15:32 AM »
 That listing has them. Tools are always a good investment. Shop around and you'll find a decent deal.
'71 CB500 K0
'81 Yamaha XS650
« Reply #86 on: March 16, 2016, 08:04:26 AM »
Dos, I have had this set since 2008.  Its great and easy to use.  The $15 MotionPro adjustment tool is included.
This kit has all you need.
http://www.saber-cycle.com/store/product859.html
Offline Dos
  • Owner of a cb350f
« Reply #87 on: March 16, 2016, 03:52:33 PM »
Wow that is great thank you I will order it soon
Offline Dos
  • Owner of a cb350f
« Reply #88 on: March 21, 2016, 03:49:32 PM »
Do you have any suggestions with the timing light?
Offline Dos
  • Owner of a cb350f
« Reply #89 on: March 25, 2016, 05:35:16 PM »
I called up an autozone near me and they have one for $50 that's way to much for me I am thinking about this one:
http://www.ebay.com/itm/like/251516312529?lpid=82&chn=ps&ul_noapp=true
Or do you think that's to cheap and #$%*ty?
Offline Dos
  • Owner of a cb350f
« Reply #90 on: March 25, 2016, 05:37:31 PM »
after reading reviews on that It seems like it's a gamble.
What about this inductive one
http://www.walmart.com/ip/14644663?wmlspartner=wlpa&selectedSellerId=0&adid=22222222227009012798&wl0=&wl1=g&wl2=c&wl3=40839130232&wl4=&wl5=pla&wl6=56581746889&veh=sem
is there really a difference?
Offline DaveBarbier
« Reply #91 on: March 25, 2016, 06:49:36 PM »
 I have one that I got off eBay for $20. It's fine. I bet the $15 one would be just fine, too. Maybe also check craigslist.
