Author Topic: 1974 CB550. Racetech Monoshock. JMR Head. Built Engine. "BLAC"  (Read 204540 times)
Re: 1974 Honda CB550 Build. "BlacSOHC"
« Reply #200 on: June 06, 2016, 02:07:31 PM »
hmm... #$%*.   :-[
Do you think i will be ok reusing them if I can pull them out and flip them? They went in pretty easy so I dont think i would damage anything getting them out..
No.  Don't be a cheapskate for something as important as fork seals.
Offline BLAC
  • An espresso is a
« Reply #201 on: June 06, 2016, 02:31:34 PM »
hmm... #$%*.   :-[
Sounds good, new seals ordered.. Im more impatient on the shipping times than I am with cost.. I hate the waiting lol
If you can't fix it with a hammer, it's an electrical problem... If it's an electrical problem, it's Cal's problem.
*2005 Yamaha R6 (sold)
*2014 Ducati Streetfighter 848 (sold)
*2014 BMW S1000RR (sold)
*2010 Ducati Streetfighter S
*1978 CB550 Restomod Build
*1974 CB550 Monoshock build
http://forums.sohc4.net/index.php/topic,154614.0.html
« Reply #202 on: June 07, 2016, 08:33:29 PM »
Nice job on the polishing, BTW.
Offline BLAC
  • An espresso is a
« Reply #203 on: June 08, 2016, 05:11:44 PM »
Thank you!  I literally wet sanded my fingertips off and bled on those buggers (mechanix gloves are ordered and on the way).
Excel shouldered wheels are just getting finished at Buchannan's and will be here this weekend.  I CANT WAIT to see what the wheel looks like between these forks =)
« Reply #204 on: June 08, 2016, 08:48:54 PM »
Something like this:
Offline BLAC
  • An espresso is a
« Reply #205 on: June 09, 2016, 10:32:32 AM »
Wheels were delivered!
They are beautiful, but it looks like there are a bunch of weights on the spokes?  Is there a different way to do this? I think it looks a little clunky...
« Reply #206 on: June 09, 2016, 12:17:13 PM »
Very nice looking hoops.  I suppose you could use adhesive weights in place of the spoke weights, but that's definitely not a period thing.
Offline BLAC
  • An espresso is a
« Reply #207 on: June 09, 2016, 01:08:51 PM »
Ah gotcha! If that is period correct and common I'll leave them, I just wasn't familiar with it
« Reply #208 on: June 09, 2016, 03:48:39 PM »
There are other types of weights, those do not look bad.  I have this type on my Z1...
http://www.ebay.com/itm/K-L-Chrome-Steel-Spoke-Wheel-Weight-1-oz-/282042440929?hash=item41ab0a1ce1:g:1ywAAOSwgQ9V00r0&vxp=mtr
Offline BLAC
  • An espresso is a
« Reply #209 on: June 12, 2016, 02:09:40 AM »
A little progress! The seat cowl came in from cliff / cognito :)
« Reply #210 on: June 12, 2016, 07:16:19 AM »
I think you're going to need a few more parts!   :D  Bet you can't wait to put those wheels and rubber to use.
Offline BLAC
  • An espresso is a
« Reply #211 on: June 12, 2016, 12:16:05 PM »
I don't know what you are talking about, I took her for a test ride last night after I took the picture.  It handles very nice! Really light and flickable in the twisties
Offline Camrector
« Reply #212 on: June 12, 2016, 01:02:15 PM »
Did you get the matching loop for the seat cowl?
Offline flatlander
« Reply #213 on: June 12, 2016, 01:02:33 PM »
never mind the steering damper. i find that thin-air supported suspension system even more worrisome. pfff... some people really go to far with the weight savings.
Offline flatlander
« Reply #214 on: June 12, 2016, 01:16:26 PM »
you are right, that's very innovative. and the way that steering-by-intuition mechanism is ergonomically integrated with the mindpower brakes, is completely revolutionary.
Offline BLAC
  • An espresso is a
« Reply #215 on: June 12, 2016, 03:48:22 PM »
I put a lot of time and thinking into this build  :P
Offline BLAC
  • An espresso is a
« Reply #216 on: June 12, 2016, 03:49:13 PM »
Hey, maybe its none of my business, but looking at your steering geometry in the latest picture, I can't believe you didn't install a steering damper  :o What, you got a death wish or something?  ;D
What are you talking about!  I ride motorcycles just for the tank slappers, thats the best part!
Offline BLAC
  • An espresso is a
« Reply #217 on: June 12, 2016, 04:15:49 PM »
Yes, I actually got the extended loop so I can chop off my stock subframe and replace it with straight tubing.  I just sat this on the stock frame for the pic :)
Offline Camrector
« Reply #218 on: June 12, 2016, 04:25:39 PM »
Word!
Offline BLAC
  • An espresso is a
« Reply #219 on: June 13, 2016, 11:17:58 AM »
I need to buy a tap to put threads in a mounting plate for my Motogadget buttons.
They are listed as M12, but it doesnt list the thread pitch.  Anyone know what it is?
Offline BLAC
  • An espresso is a
« Reply #220 on: June 13, 2016, 11:58:32 AM »
Offline BLAC
  • An espresso is a
« Reply #221 on: June 13, 2016, 02:31:49 PM »
I have reached yet another "point of no return" moment  ;D
(small tacks to help me see what I want it to look like)
« Reply #222 on: June 13, 2016, 03:06:07 PM »
Are you planning on using that tank?
« Reply #223 on: June 13, 2016, 03:17:28 PM »
I like it with the stock tank.  I assume blacSOHC has already worked out his suspension mount points, geometry and adequate support for the new subframe.
Offline BLAC
  • An espresso is a
« Reply #224 on: June 13, 2016, 03:23:23 PM »
Yes, I took measurements from the stem to the stock mounting points for the rear springs and plan on getting it pretty much exactly the same.  I bought the mounting kit from Cognito so it should be a clean and straightforward weld in solve.
On the support bars, I am going back and forth on whether I want to recreate them in the factory spot (creating the large 'triangle' area) or mount them higher up on the bar behind the motor creating a shallower/sleeker triangle.  If that makes any sense...
I will mock up some photoshops soon  8)
