Author Topic: 1970 Triumph Tiger 650  (Read 73946 times)
Offline Powderman
Re: 1970 Triumph Tiger 650
« Reply #275 on: October 05, 2016, 08:41:30 AM »
Got the Black motor back in the frame and will proceed with the reassembly. Found out you can install a complete motor in the frame with rocker boxes on, but you have to remove 2 of the center head bolts. I had to drill out the Hinkley clutch perch and narrow the barrel on the cable to accept the earlier clutch cable barrel.
Offline grcamna2
« Reply #276 on: October 05, 2016, 11:20:36 AM »
That's looking great PM  8) 8) I look forward to seeing it w/ the chrome head-pipes on it;will you have round,finned chrome clamps at the head also ?
« Last Edit: October 05, 2016, 11:22:07 AM by grcamna2 »
75' CB400F/'bunch o' parts'
Offline Powderman
« Reply #277 on: October 05, 2016, 11:31:59 AM »
I'll be running the stock exhaust collars, in black with chrome pipes.
Offline Powderman
« Reply #278 on: October 05, 2016, 01:41:06 PM »
First time she's seen sunlight since Jan.
Here's a "before" pic of what I started with:
« Last Edit: October 05, 2016, 02:31:11 PM by Powderman »
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #279 on: October 05, 2016, 02:20:12 PM »
Engine back in the frame. Great stuff, pivotal moment in any build. Another one saved, good on ya mate  :)
Would it be too picky to ask about that rear sprocket? Is it staying that way? Stands out a bit to my eye (but what would I know ::))?
From a fellow Triumph fan ;D
Build threads:
1977 CB750 F2
1958 Norton Model 99
Offline Powderman
« Reply #280 on: October 05, 2016, 02:29:12 PM »
It does need addressing doesn't it. I may powder coat it Matte Black.
Offline grcamna2
« Reply #281 on: October 05, 2016, 02:37:04 PM »
Will you be installing the orig. tank badges ?
Offline Powderman
« Reply #282 on: October 05, 2016, 02:40:05 PM »
Yes, don't know yet if the colors will be modified or not. I just noticed, and am surprised no one else did, that I have the rocker boxes swapped front to rear. The oil cooler goes on the other side.
« Reply #283 on: October 05, 2016, 02:46:58 PM »
Looks great PM.  +1...the rear sprocket blinded my eyes too!  My current build has a powdered rear sprocket....good idea.
Offline martin99
  • UK Based, Non-
« Reply #284 on: October 05, 2016, 03:02:55 PM »
Or machine a few holes in it to mirror the front disc, then chrome to balance the headers? Just a thought...
Build threads:
1977 CB750 F2
« Reply #285 on: October 05, 2016, 03:46:35 PM »
It needs drilling or lightening holes..
Offline Powderman
« Reply #286 on: October 05, 2016, 03:48:36 PM »
I'm checking now with Slikwilli420 to put 10 holes in it to match the rotors.
« Last Edit: October 12, 2016, 10:41:32 AM by Powderman »
Offline Powderman
« Reply #287 on: October 05, 2016, 10:45:06 PM »
Original tank badges and I'll be adding the rubber knee pads.
Offline grcamna2
« Reply #288 on: October 06, 2016, 03:55:57 AM »
Those badges are nice,any background ?
Offline Powderman
« Reply #289 on: October 06, 2016, 08:49:34 AM »
Like I said, not sure of the colors for the badges yet, probably black background with gold letters.
Offline MoMo
  • Ride like you're invisible
« Reply #290 on: October 06, 2016, 08:54:06 AM »
Looking good PM.  Is the color green or gold or greenish/gold?  Photos aren't color correct I assume-know what happens though when one does that..Larry
Offline Powderman
« Reply #291 on: October 06, 2016, 09:09:01 AM »
The stock color was called Spring Gold and was more green like the tank color now. I'm actually changing the color slightly to late model Jeep Rescue Green which you can see on the fenders now. It's darker and has red in the metal flake. It fits nicer with the blacked out chrome than the lighter Spring Gold does.
Offline Powderman
« Reply #292 on: October 08, 2016, 01:14:36 PM »
Had all the parts laying around needed to fab up the front upper brake line. I may slide a piece of shrink wrap over it to keep it from chaffing the headlight bracket.
Offline vfourfreak
  • Do you think that's wise
« Reply #293 on: October 08, 2016, 01:18:00 PM »
One could never call me a Triumph fan, nevertheless I admire the work taking place here.
I'd love to hear this classic fire up when the day arrives.
Bravo PM.
Kev
Offline grcamna2
« Reply #294 on: October 08, 2016, 01:51:17 PM »
PM,They have clear shrink wrap too  :)
Offline digschopper
« Reply #295 on: October 08, 2016, 04:18:46 PM »
as a triumph guy for years,and the painter at a triumph shop,i cringed at first.we are like that;if it hasn't been cut yet,then DON'T. there are swap meets full  of bikes that aren't correct,wrecked,or chopped.HOWEVER,i'm looking at your pix,and really likin it. i have a '79 hotrod bonnie in a hard-tailed 65 frame,so i can't be pointing fingers,lmao. nice bike so far,keep going!
digger
Offline Powderman
« Reply #296 on: October 11, 2016, 10:09:29 PM »
Found a tidy spot behind the side cover for the rear brake reservoir. Need to move it up an inch to clear the chain guard. Sprocket doesn't look so massive with the chain guard on.
Might hit the tank with some paint tomorrow.
Offline MoMo
« Reply #297 on: October 12, 2016, 05:48:16 AM »
still planning to drill the rear sprocket PM? ...Larry
Offline grcamna2
« Reply #298 on: October 12, 2016, 07:17:15 AM »
Sprocket Specialist's has rear sprockets in high grade aircraft alloy that have holes drilled the way you might like and they also have a very hard surface treatment process called 'Titan Tough' that makes the sprocket last much longer,it's a gold finish also.I have one if you'd like a pic later.
Offline Powderman
« Reply #299 on: October 12, 2016, 09:04:00 AM »
I'm looking at options. The price I was quoted to put 10 holes in this one is about twice what I can buy a new one for. So I'm looking at replacing it if I can't get the cost down to do mine. SS should have a chart to input the dimensions to relate to part numbers they have.
grcamna2, I'd love to see a pic of yours.
« Last Edit: October 12, 2016, 09:14:46 AM by Powderman »
