Author Topic: CB550 Motor Build  (Read 19807 times)
Offline Camrector
Re: CB550 Motor Build
« Reply #50 on: February 06, 2016, 11:50:42 AM »
A little progress made while we wait for the cases from Nils. Stator and field coil were sent to Ricks for rebuilding. They tested out fine, but hey why not right. A.P.E was also shipped the crank. Started ordering some fresh parts for the rebuild. Primary chain, cam chain, tensioner, guide, new oil pump etc etc. Will still need bearings as I can't remember the case numbers. And a bunch of other stuff too.
Top end recipe is still in the works.
Brent has a great set of 572 Pistons that will work great with any cam choice and over sized valves.
Also is still the 61rs from dynoman with a 126-00 or 126-20.
How Streetable do you guys think the 126-20 is? Cal please chime in here.
Offline Camrector
« Reply #51 on: February 13, 2016, 07:54:47 PM »
Cases arrived on Wednesday. All i can say is WOW! Nils your are a wizard.
in that last picture notice the two chips on the cylinder sleeves? will that be ok or is it new liner time?
All the other covers are still wrapped up and waiting.
« Reply #52 on: February 13, 2016, 10:43:39 PM »
You should be ok with those small nicks.
Wow, Nils does awesome work.  That finish looks NEW.
Online MRieck
« Reply #53 on: February 14, 2016, 05:52:04 AM »
While the chip sin the sleeve are not in an area involved in the travel of the piston, you definitely want a machine shop to grind them back. The constant heat cycles and vibration can prey upon those areas and turn them into a crack. If you have decided to use the 59mm Wisecos, even better as you won't be thinning the wall so severely either.
That is correct.
« Reply #54 on: February 14, 2016, 06:44:23 AM »
Yes, my comment was not so clear.  Grind back the chips and chamfer the edges.
One of my sleeves was really chomped.  I ended up using a spare cylinder.
Offline Camrector
« Reply #55 on: February 14, 2016, 07:21:31 AM »
Excellent info. Still undecided on the piston size, and from the looks of that last picture I rather be safe that sorry!
Some parts are arriving and waiting to hear back from MRieck about the top end. I'll likely send the cylinders to him as well, so he can see what needs to be done.
Offline Trad
« Reply #56 on: February 14, 2016, 11:18:00 PM »
Those cases look so good! Wow is right!
I went with 60mm (JE forged pistons). Many do 61mm but that would be the thinnest you can really leave the factory CB550 bores.
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
Offline Camrector
« Reply #57 on: February 14, 2016, 11:37:54 PM »
Exactly Trad. Hondaman is putting 61s in my Gentlemens Express motor, this one might get something a little "different".
Offline Camrector
« Reply #58 on: March 01, 2016, 09:10:01 PM »
Not much to report. Parts are starting to come in, so i figured i could add some more porn here.
New oil pump
Stator and field coil rebuilt by Ricks
And Race cut gears by Fast by Gast. These are beautiful and Paul is a great dude!
Mr.Rieck is still swamped so it'll be about a month until i can send him the top end. So that gives me plenty of time to source a few more internal parts and start building the bottom end.
Offline Camrector
« Reply #59 on: March 10, 2016, 04:21:51 PM »
Following your advice here guys, the dynoman 61r  wiseco pistons arrived today. They are quite nice except for a few burrs along the valve reliefs. I would have expected these to be cleaned up a little better for being "high quality", and at $600 a set.
otherwise Im happy though.
« Reply #60 on: March 10, 2016, 06:51:33 PM »
Those are pretty but for $600, I'd expect a coating on the skirt. These are the Wisecos I put in my H1...
Offline Camrector
« Reply #61 on: March 10, 2016, 11:02:26 PM »
Yeah I didn't even get those cute little wiseco "socks". Heartbroken.....
[sarcastic tone]
Offline Camrector
« Reply #62 on: May 02, 2016, 01:37:40 PM »
Crank arrived last week from APE. They shaved 2.4lbs off the stock weight. So now just waiting on rods from Mike Reick( polished and shot peened) and we can build this bottom end.
14k!!! I wish  ;D
And a teaser pic from Mike of the oversize intake valve bore
« Reply #63 on: May 02, 2016, 01:43:30 PM »
14k!!! I wish  ;D
Nice APE crank work.  It looks like you went with a Mike Rieck Stage 4 (Stage III with oversize valves) job.  What kind of cam are you going to use?
Offline Camrector
« Reply #64 on: May 02, 2016, 02:45:17 PM »
Went with the Megacycle 126-20 CB fan. You guys bullyed me into it. ;D
And yes stage 4 from Mike.
« Reply #65 on: May 02, 2016, 02:49:57 PM »
Haha!  I like what Mike says about the Stage 3 job: "This head kicks ass…..no disappointments no matter the displacement (400cc, 500/550cc, 750 etc.)."  Think of your Stage 4 as that ON STEROIDS!!
« Reply #66 on: May 02, 2016, 04:04:30 PM »
OOOOOH   stage 31..... ;D :P
Offline Camrector
« Reply #67 on: May 02, 2016, 05:05:30 PM »
I guess we can call it "Stage 3 plus" lol. The oversize valves are recommended for the stage 3 but not included.
« Reply #68 on: May 02, 2016, 06:35:34 PM »
As I understand it:
Stage 1: Includes the following. Disassemble, inspect, hot tank, bead blast entire head, porting
and reassembly. OEM valve guide seals are extra OR can be provided by the customer.
Stage 2: Same as above but more extensive porting especially around the guide boss and intake
floor.
Stage 3: Requires removal of valve guides. Extensive reshaping of both intake and exhaust ports.
Epoxy reinforced intake spigots. This head will require new guides, guide honing and a Serdi
valve job. Basic price minus guide and valve seat work….please take note!!! This head
performs best with oversize (33.5) intake valves and cams with lifts .360 and over. A great
performing street head with 836cc and larger…..This head kicks ass…..no disappointments no
Stage 4: Unofficially on the menu as a Stage 3 PLUS oversize valve kit.
Offline Camrector
« Reply #69 on: May 02, 2016, 07:15:33 PM »
Well I'll have the lift (.363) from the cam, but not the 33.5 on the intakes lol
Online MRieck
« Reply #70 on: May 03, 2016, 04:30:34 AM »
That would be a tight fit.....28.5 intakes
Offline akabek
« Reply #71 on: June 10, 2016, 10:09:01 AM »
Any progress on this build?  Are you going to use the Power-Barn CR26 kit or the Cycle x adapter to mount the carbs?
Offline Camrector
« Reply #72 on: June 10, 2016, 06:54:38 PM »
Mike R is just finishing up on the head,rods, and jugs. So in the next few weeks I'll start building. And yes going with the cr26s carbs from Godfrey.
I did buy the cycle X adapter manifolds and sent those to Mike to port match. But we might have run into a little snafu with those. I'll post more on those once I hear from Ken at cycle X.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #73 on: June 10, 2016, 07:03:23 PM »
I'm sure you and Godfrey know the carb spacing is different than standard CB550 spacing. What issues are you having with the CycleX manifold?
Offline Camrector
« Reply #74 on: June 10, 2016, 07:40:05 PM »
Well they do not have any o rings cut into the back where they attach to the head. So we both want to know how they seal up. Maybe they want me to use some kind of RTV? Or break out a rotary table and cut them myself? So we will see what Ken says. I'm going to send Mike my stock manifolds to port match just in case.
