Author Topic: My 1977 CB550F project  (Read 22128 times)
Offline JMS28411 I'm no Spring Chicken
    • My 1977 CB550F
Re: My 1977 CB550F project
« Reply #25 on: May 31, 2016, 03:42:18 PM »
We have put 108 miles on the bike as of 5-29-2016 and the dual disk brakes & front suspension feel good :)
The improved braking is worth the effort!
We no longer have a soft mushy front suspension and it's not a stiff harsh suspension either :)
When I was balancing the front wheel I noticed the rim needs to be trued a little in one area, so I need to make a bracket to attach my dial gauge so I can correct this.
Also I would like to find another clutch lever handle that's a little longer than the stock one and hopefully match the one on the new master cylinder :)
Next a new seat, I want to make the seat, but my son wants to buy one so I'll let him buy it that way he can get what he want's :)
My 1977 CB550F Project
    • My 1977 CB550F
« Reply #26 on: June 04, 2016, 07:57:06 AM »
Has anyone here ever chamfered the rear brake shoes, if so any pics or advice on doing this would be appreciated.
Thanks ... Jesse
Offline Deltarider
« Reply #27 on: June 04, 2016, 08:24:20 AM »
Shoes may contain asbestos. Don't know how dangerous that is.
CB500K2-ED Excel black
Offline jonda500
« Reply #28 on: June 04, 2016, 07:51:06 PM »
Thanks ... Jesse
Why would you want to chamfer the rear shoes? This is often done to the front brake pads to try and stop them from squealing - sometimes it helps...
John
A starter clutch thread:
    • My 1977 CB550F
« Reply #29 on: June 06, 2016, 04:59:02 PM »
Thanks ... Jesse
John
I read some where it could help keep the rear brakes from locking up
    • My 1977 CB550F
« Reply #30 on: June 06, 2016, 05:13:19 PM »
Saturday night out, putting some miles on the new disc brakes and playing some Blues music at a blues Jam
The brakes are feeling real good.
    • My 1977 CB550F
« Reply #31 on: June 06, 2016, 05:41:33 PM »
I've never heard that. Interesting notion. I wonder what the premise for that is? Chamfering the leading edge would only prevent chatter (in my opinion) of the shoe when it first contacts the drum. If you can recall what/why I would be interested to hear it.  ???
I just did some quick searching,but could not find anything, I'll do some more searching tomorrow.
Also I was reading about water grooving brake shoes, EBC makes shoes with water grooving and chamfered ends.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #32 on: June 06, 2016, 05:46:13 PM »
I have ridden both my 550's through some very heavy rain storms and it was the front disk that was the problem, not the rear drum. If it weren't for the drum I wouldn't have had hardly any braking power.
Chatter has never been a problem and I have ridden in lots of stop and go traffic and on twisties requiring frequent braking. I would not spend extra money on grooved shoes nor spend personal time chamfering stock ones.
    • My 1977 CB550F
« Reply #33 on: June 06, 2016, 06:13:09 PM »
Yeah I know about internet quotes, I always look for multiple sources before accepting any info whether on the internet or a person, I learned that the hard way a long time ago.
Have not been in any heavy rain with it yet, but the drilled dual disk faired well in light rain, just a little fading when first applied then they worked satisfactorily.
I have been checking the disc's after braking and they seem to be running cooler than the stock single non drilled disk.
Offline Deltarider
« Reply #34 on: June 07, 2016, 02:42:48 AM »
Oh, and when you think WD-40 is fine for cleaning the front fender, think again. Day before yesterday much to my surprise I had no front brake when I started out. Luckily I was still in town. Stopped and discovered the disc was still dripping wet from the WD-40 I had sprayed the day before. Phfeww, could have killed me. Then I remembered the lesson taught in my advanced training class to always check a few things before you start riding.
    • My 1977 CB550F
« Reply #35 on: June 08, 2016, 07:10:11 AM »
What front fender :) Can't say I ever sprayed WD40 on metal parts to clean them. Rubbing alcohol makes a pretty good cleaner for removing grit and grime.
Mine & my son's 1977 CB550F after getting back home from the Rusty Nail
http://s210.photobucket.com/user/jms23185/library/Motorcycles%20I%20owned
« Last Edit: June 08, 2016, 07:49:39 AM by JMS28411 »
Offline Deltarider
« Reply #36 on: June 08, 2016, 07:23:13 AM »
WD-40 is great stuff. You can clean your bike with it. Wonderful to clean the drivechain. Lamp oil (kerosene) is also fine to clean the chain. What I admire most in WD-40 is that it is thinner than water. That's quite an achievement. In marine environment when bolts and nuts are corroded by seawater, WD-40 penetrates. It smells nice too. The last drips of every can I rub in my hair.
Oh... and spray it on the disk brake and it will never sqeal again (nor will you).
« Last Edit: June 09, 2016, 01:06:22 AM by Deltarider »
    • My 1977 CB550F
« Reply #37 on: June 08, 2016, 07:47:27 AM »
I never tried WD40 on my hair, I bet the comb glides through your hair very easily :)
As far as WD40 on your disk brake lessons learned the hard way you never forget ... if you survive :)
Take Care ... Jesse
    • My 1977 CB550F
« Reply #38 on: June 11, 2016, 08:35:44 PM »
Lubricated the tach, speedo, clutch cables & chain - greased swing arm and adjusted drive chain - adjusted headlight.
I checked all nuts & bolts on handlebars, triple tree, calipers, disc rotor, brake lines, front & rear suspension, foot pegs and synced the carbs.
I replaced M8x1.25x75mm Steering Stem pinch bolt because I couldn't torque it to the required setting. I pulled #1 & #4 plugs, they looked good, a greyish tan color. we have 265 miles on the dual disc & new brake pads. The brakes feel much better than the stock single disk. The bike is running strong and feels great. Tomorrow I turn it over to Shelby for the Summer & Fall. We have yet to get more than 35 mpg, but that's what happens when you tach it up most of the time. It's a great handling bike for around town and short trips off the interstate.
I think I need to find a CB750 project bike.
Bottom pic my old chopped 74 CB750 with an 836 big bore kit & a RC Engineering cam.
« Last Edit: June 13, 2016, 04:48:01 AM by JMS28411 »
    • My 1977 CB550F
« Reply #39 on: June 13, 2016, 07:46:54 AM »
This is weird, everything was working fine, now all of a sudden
1. The headlight stopped working (bulb is good), but all the other lights work - all fuses are good
2. The electric starter stopped working, but I can kick start it
3. When I press the starter button it flashes on the headlight
This is going to take me a while to figure out :(
I HATE ELECTRICAL PROBLEMS!
    • My 1977 CB550F
« Reply #40 on: June 13, 2016, 01:02:05 PM »
Yea I just finished removing the starter switch and that is where the problem is, the printed circuit board which provides a double throw single contact has crumbled preventing the starter and headlight from working :)
The never ending challenge of restoring and maintaining a vintage motorcycle :)
Found a new replacement only $84 I think I can fix this problem without spending about $90+ I would like to keep it original, but at that price it's not gonna happen unless I can find a SPDT push switch that will fit inside the handlebar unit and I know where to start looking http://www.mpja.com/
yellow/red wire = power to the starter relay
black/red wire = power to the headlight
black wire is power source
I also discovered a faulty factory electrical connection in the charging system wiring, I soldered the wire to the connector
    • My 1977 CB550F
« Reply #41 on: June 13, 2016, 01:13:38 PM »
In the meantime I discovered something under the rear of the seat.
I had over looked because I am used to seeing it behind a side cover or in the battery compartment?
I don't know what the tiny Allen wrench is for at this time, the only thing missing is the spark plug socket :)
Offline Deltarider
« Reply #42 on: June 13, 2016, 02:28:17 PM »
Maybe PO has changed the 16 crossheads that hold the floatbowls for much handier allen bolts.
see if you can find one, it's the best tool in the set and I wouldn't trade it for any other.
Offline Bankerdanny
« Reply #43 on: June 13, 2016, 02:43:05 PM »
The spark plug socket is the most useful tool in the bunch with the pin spanner second.
    • My 1977 CB550F
« Reply #44 on: June 13, 2016, 07:03:40 PM »
I had a spark plug socket from my old CB500, but I found a better one than the one that came in the Honda tool kit
It's a Motion Pro thin wall 18mm socket 08-0175 about $20 but worth it.
Socket can be driven with various tools including the Motion Pro spark plug ratchet wrench, 3/8 in. ratchet, 13/16 in. wrench, tool kit bar, or a Phillips screw driver placed through the 8.5 mm hole at the top of the socket. Socket has 23.8mm outside diameter and the total length is 110mm.
Offline jonda500
« Reply #45 on: June 13, 2016, 07:16:24 PM »
There were originally 3 screwdriver shanks..
John
    • My 1977 CB550F
« Reply #46 on: June 13, 2016, 07:26:03 PM »
John
I believe you are right there was a larger Philips head shank
Offline Deltarider
« Reply #47 on: June 14, 2016, 05:33:26 AM »
But does it have that rubber inside?
    • My 1977 CB550F
« Reply #49 on: June 15, 2016, 10:00:24 PM »
Yes it does :)
« Last Edit: June 21, 2016, 07:43:38 AM by JMS28411 »
