Author Topic: My Pet is COCKIER than yours..  (Read 1297 times)
« on: June 22, 2016, 11:27:50 AM »
Check out what I got for my alloy tank..
Not one, not two, but THREE outlets..... Top that..
Re: My Pet is COCKIER than yours..
« Reply #1 on: June 22, 2016, 11:36:29 AM »
754 says..Man who has PINGEL in pocket...feels Cocky....
« Reply #2 on: June 22, 2016, 11:39:29 AM »
Is that a Pingel in your pocket or are you 754?
« Reply #3 on: June 22, 2016, 11:52:14 AM »
My original. Thought was to eliminate one barb with a stainless pipe plug..this would make the two out let's closer together..rather than 180 degrees apart that duals have. Having the two closer together could learn ok cleaner
.. The triple outlet, does not have a reserve, and the alloy tank I want this for, only holds about 9 litres.
.. And then I thought of running a clear line of outlet three for a fuel visiguage..
 If you ever drain your tank using stock petcock it takes like 20 minutes, seems like forever.. With a PINGEL it takes like 2 or 3..
« Last Edit: June 22, 2016, 04:16:50 PM by 754 »
Offline 01Thomas
« Reply #4 on: June 22, 2016, 12:19:26 PM »
Looking good - but what are you going to do with it? Have you bought an SOHC triple?
1971 Honda CB750 Four K1 [Engine: CB750E-1113521 / Frame: CB750-1113838]
1977 Seeley Honda CB750F (F1) [Engine: CB750E-2551214 / Frame No: SH7-655F]
'96 Yamaha YZF750SP & '81 Moto Guzzi SP1000 & '80 Moto Guzzi 850 LeMans II & '82 Bimota KB-3 [Frame No 49] & '66 Ducati 50 SL/1 & '53 Miele K-50 & '38 Miele 98
« Reply #5 on: June 22, 2016, 01:17:01 PM »
See above.  I think he's thinking of running a dual output with the third to a sight glass gauge.
Offline strynboen
« Reply #6 on: June 22, 2016, 01:23:02 PM »
i vas thinking to make a groove in the tank...to hold a kler fuel line..use a nippel at bottom and top...evenuell use a 20 mm end drill cutter..make a nice groove in a piece if steel.. and veld the vhole thing in the tank..a safe vay to have a fuel indikation caunter sunck..so it not can be ripped off the tank ..
i hate all this v-w.... vords
« Reply #7 on: June 22, 2016, 03:46:50 PM »
or do like me, open lid, insert lit cigarette until it is extinguished, the lower down in the tank it goes out, the more gas I need :P
My VF500F has one BIG outlet on a vacuum petcock.   The other day after some tank off service I had difficulty getting the fuel line re-attached and knocked the line off without noticing while installing the tank, cranked the engine, and instantly found myself standing in a very large puddle of gasoline. :o
Offline carnivorous chicken
« Reply #8 on: June 22, 2016, 04:32:48 PM »
This, if I understand visiguage correctly!
« Reply #9 on: June 22, 2016, 07:37:24 PM »
That petcock would be perfect for my Kawasaki Triple
« Reply #10 on: June 22, 2016, 08:39:59 PM »
The triple guys are the main users, I would think..need an adaptor..
...drawback no reserve..not so bad on an SOHC, but I bet it ducks on a two stroke.. The h2 guys said they never could drain a tank so fast as with the PINGEL.
  Honestly,  I bid on one thinking. Way less bidders than a two outlet, and I can plug one.. But 120 degree apart would look cleaner than 180. IMO...
« Reply #11 on: June 23, 2016, 06:26:33 AM »
I like the petcock on my H1 - vacuum operated.  I dont even bother to turn it off, leaks have not been an issue.  I need reserve so I'd pass....
