Author Topic: The Amalgam: honda past meets present, take 2! or 3?  (Read 43158 times)
Re: The Amalgam: honda past meets present, take 2! or 3?
« Reply #175 on: June 27, 2017, 09:30:19 AM »
I understand the allure.  I have a buddy who was stuffing a modern Yamaha EFI engine into a 550 frame.
You might also want to add some modest bracing to the frame, since it was not necessarily designed for 60 hp.
Offline jag767
« Reply #176 on: June 28, 2017, 01:42:54 AM »
Ya know, there was only one spot I'd identify as a weak point which was in the backbone that i've already made plans to add a little meat to, but otherwise it seems ok to me, mostly because even though it's a little more power, there's also a lot less weigh to put stress on it.
I had a few minutes today and I strated screwing with the ugliness of that fork brace. I figure if I remove the receivers for the boots, then smooth all the hard edges out, it'll look way better. I'm also going to polish it to match the forks instead of standing out. I always have a hard time with crap like this. Sure, it's going to look far better, but it won't function any better, so the 5-10 hours into the one piece is purely for looks. That's why the battery box is a rectangle sitting in the frame instead of something pretty. My cnc buddy had to convince me to make a cover for that too.  :o
« Last Edit: June 28, 2017, 01:45:29 AM by jag767 »
« Reply #177 on: June 28, 2017, 08:43:04 AM »
If you think that fork brace is ugly, try a TKAT brace -- very industrial, over-engineered but effective.  Yours looks almost like a bare metal Tarozzi.
As for bracing, I think you can do it with a few discrete pieces and even a few speed holes for lightening.
Offline 540nova
« Reply #178 on: June 28, 2017, 08:54:16 AM »
Since you're trying to shed grams, I'd ditch the centerstand and upper/lower covers on your shocks.
Sent from my SM-G955U using Tapatalk
Offline jag767
« Reply #179 on: June 28, 2017, 10:26:48 AM »
The shock I've been dying to use so it's only 1 pound total, I will deal. The centerstand has to stay there's no other way to stand the bike lol!
« Reply #180 on: June 28, 2017, 01:57:20 PM »
I was considering running only centerstand on my next project but there are too many hills locally.  I was worried about parking on a hill with only a center stand.
Offline jag767
« Reply #181 on: July 01, 2017, 08:13:14 AM »
Starting reprofiling the fork brace
« Reply #182 on: July 01, 2017, 08:34:58 AM »
Jag,
Did you "start" with a Tarozzi brace?
Offline jag767
« Reply #183 on: July 01, 2017, 09:42:50 AM »
Jag,
Yup! Trying to slap the ugly off of it
« Reply #184 on: July 01, 2017, 03:26:05 PM »
You don't like squared edges without radii/much edge relief and machining without a lot of post machining finish work?  What kind of edgy machine are you trying to build with fluid stuff everywhere?  Looks like bondo?
You didn't consider using epoxy putty? Are you going to attach a fender like Godffrey does with brace beneath fender and going down an 1" in height on tire with 19"?
Probably already pointed out in this thread if not somevother thread I have been reading or following.
Fortune cookie I kept the fortune from reads,
" Advice is like kissing. It costs nothing is a pleasant thing to do."
Reminds me more of, " Opinions are like aholes, everyone has one."  A longer version of that ends, "... and no one wants to be around them or hear them "speak"."
Believe it or not, another fortune cookie fortune read, " What's more important - your goal or others' opinion of your goal."
I have no wisdom so I should shut up...no one wants my opinion lest they wish to consider me an ahole?
Offline jag767
« Reply #185 on: July 01, 2017, 05:41:24 PM »
Lol. No front fender, 18 inch rim, and no bondo because i am going to polish it once i get a shape i can live with the goal is to have it blend into the forks like it was always there.
New oil pan
« Reply #186 on: July 01, 2017, 09:52:33 PM »
No need for windage tray around pickup for pump? With shallower oil pump you will have to reduce the volume of oil so your crank does not emmerse itself in the oil.  That leads to foaming/frothing and cavitating pumps which can cause oil starvation in the motor as well as possible oil pump failure.
Just making sure you are not risking causing a problem solving another.
Offline jag767
« Reply #187 on: July 02, 2017, 02:18:37 AM »
The bottom if the case isn't open to the crank, i'll take a photo. The crank is enclosed other than the lead for the oil feed. So in theory the exact same volume of oil will be used and should be fine. The pump itself is unchanged, and the oil level itself is unchange. All I did is change the shape since I won't be needing the cat which normally sits next to it.
« Reply #188 on: July 02, 2017, 03:55:59 PM »
"Opinions are like aholes, everyone has one."
Everyone has one and they all stink.
Offline jag767
« Reply #189 on: July 16, 2017, 07:03:49 AM »
Been busy, but my buddy started cncing my redesigned oil pan
« Reply #190 on: July 16, 2017, 10:27:05 AM »
I'm a sucker for the CNC-porn.
« Reply #191 on: July 17, 2017, 11:04:18 PM »
Pretty nice.  So you have that swirl feature in the oil pan...little known performance mod
He may need to mirror that swirl for south of the equator...
 (teasing)
Looks really nice!  Do you plan on having it be sent out for a clear hard anodized coating?
David
Offline jag767
« Reply #192 on: July 18, 2017, 02:54:32 AM »
 (teasing)
David
Thanks! I'm not sure that's necessary, and the outside will get painted to match the motor. It'll end up being one of those details that done right no one will know is there.
Offline jag767
« Reply #193 on: July 18, 2017, 02:57:05 AM »
Have to take a month break on this bike, since I have a customer bike to do. That's the bad news. The good news is the money I make from the customer bike will pay for the rest of this bike  8). I cleaned up the little shop and everything
Offline jas67
« Reply #194 on: July 18, 2017, 04:17:54 AM »
Wow, that's got to have left a hell of a huge pile of metal chips!
Looks great!
Classic Honda:
1976 CB400F
1975 CB400F (project)
1975 GL1000
1968 CL175 (1 nice one, one project)
1967 CB77
1967 CB160 (2 of 'em, both projects)
1967 CL160 project
Triumph: 2017 Thruxton R
BMW: 2016 R1200RS, 1975 R90S, 1973 R75/5, 1980 R100S
Ducati: 2013  Monster 796, 2013 848 Evo Corse SE track beast, 1974 750GT, 1970 Mk3d 450, 1966 Monza 250
Moto Morini: 1975 (titled 1976) 3 1/2 Strada, w/ Sport clipons.
Moto Guzzi: 2017 V7III Special,  1977 Le Mans, 1974 Eldorado
« Reply #195 on: July 18, 2017, 10:56:59 AM »
Was teasing/joking about the swirl...there would be no impact from it...  too bad that bike porn is covered up with paint.  Nice and clean shop.
« Reply #196 on: July 21, 2017, 11:10:22 PM »
 That is quite a favor he us doing for you!  How much would it cost if he was selling them?
You should put it in projects, more people wood see your bike.
Offline jag767
« Reply #197 on: July 22, 2017, 01:12:09 AM »
Heh I have no clue, but it took 2 hours to design, 2 hours of setup, and 2 hours to run. So not cheap lol. I thought projects was only for 4's....
Offline jag767
« Reply #198 on: July 26, 2017, 09:29:42 AM »
Progress:
Offline SKTP
« Reply #199 on: July 26, 2017, 09:55:29 AM »
WOW...this thing is amazing
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
