Author Topic: Antigravity 4 or 8 cell vs lead acid (bonus Ricks Reg/Rec placement question)  (Read 8026 times)
AirCanuck
Right. So I've got a cafe 1978 Cb550k and this seems to be an issue still under debate. (Various threads here loving or decrying the use of lithium ion)
It has a ricks Reg rec combo unit. Currently it has a lead acid battery under the seat (along with an Munit).
The issue of course is that the lead acid sits on its side to fit under the seat which I'm told will kill it in fairly short order. Apparently the antigravity 4 or 8 cell is the way to go given that I've got the upgraded ricks. Links at bottom for both batteries.
I know nothing about electronics. How do I know what amp-hour and voltages I need? What is the significance of this? It's how many amps it can provide for how many hours, ya? But someone told me it's also related to how long it can crank the engine?
Second bonus question: ricks Reg/Rec is under the seat as well. Apparently this is common in cafe builds. Worried about heat as it won't have airflow. Anyone else done this with theres? Alternative ideas?
All help and advice is appreciated.
https://m.ebay.ca/itm/Antigravity-Batteries-Small-Case-8-Cell-Lithium-Ion-Battery-AG-801-AG-801-/232125851051?hash=item360bc765ab%3Ag%3APCkAAOSw44BYEfU2&_trkparms=pageci%253A662eab19-8ec7-11e7-8a98-74dbd180831e%257Cparentrq%253A3b873c7015e0a86705b861dffffa51dd%257Ciid%253A1
https://www.amazon.ca/gp/aw/d/B00COSNMSI/ref=mp_s_a_1_1?ie=UTF8&qid=1504238997&sr=8-1&pi=AC_SX236_SY340_QL65&keywords=4+cell+antigravity&dpPl=1&dpID=51hd5-vak7L&ref=plSrch
Offline Bodi
I would use an AGM lead-acid battery that can go in any orientation, rather than a lithium one. The charge characteristics are very similar to the wet cell original and - although damaged as with a normal bike battery - it won't be destroyed by full discharge like lithium cells are. The bike has no protection against full discharge.
« Last Edit: September 01, 2017, 12:27:26 PM by Bodi »
Offline lrutt
Use a Shorai, safer alternative than ion types. Mount anywhere, any angle, small and light. I've had a Shorai in my XR650l now for 8 years.
As for Ricks RR, I've got mine mounted bottom side of an AL plate under the seat. It barely gets warm it seems. There is plenty of air circulating but then I'm running pods so it's wide open.
I would allow the reg/reg unit to get some airflow.  As for Lithium based batteries, I would only recommend Shorai or Speedcell.  I have had 2 others fail.  NOTE: if a lithium-based battery falls under a specified voltage (enumerated in the manual), IT WILL NOT COME BACK -- unlike gel mat or lead batteries.
If space and weight are not hypercritical (eg. racebike), go with a gel mat battery.  They are still way lighter than a lead acid battery.
AirCanuck
Do you have photos of your ricks rr rig? Is the rest of the wiring under your seat? I have Pods as well so your rig may work for me..
AirCanuck
How do I know what shorai I should use for my 550?
Offline innovativems
    • Innovative MotoSports
I second sohc cafe racer fan on speedcell.  I can get you one of you chose
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
I don't have any photos handy.  My wiring is about to say "adios" next week as I replace the stock wiring for Motogadget.
AirCanuck
Is that an Munit? Mine has that. Pretty slick.
It's getting one.
AirCanuck
Re: Antigravity 4 or 8 cell vs lead acid (bonus Ricks Reg/Rec placement question)
« Reply #10 on: September 01, 2017, 04:04:01 PM »
What is this Munit of which you speak?  ;D
I can't tell if you mean it or not due to my absolute newbiness  ;D
AirCanuck
« Reply #11 on: September 01, 2017, 04:09:30 PM »
Hmmm so it would seem that there is no real "consensus" amongst the community on batterie, eh?
My options seem to be...
AGM lead acid
Speed cell (LI?)
Shorai (not LI?)
Antigravity (LI)
That about sum it up?
AirCanuck
« Reply #12 on: September 01, 2017, 04:11:29 PM »
How does speedcell compare to antigravity? Why do you recommend it? It's still a lithium ion right?
Are you saying you've got one for sale or have a good source on them or something, or are they hard to get on eBay/amazon etc?
« Reply #13 on: September 01, 2017, 04:38:47 PM »
Well I've been very impressed with speedcell and absolutely love the quick disconnect all of their batteries use.
I'm a dealer for speedcell.  I don't get a whole lot of a price cut but I can help out if you go that route.  Alot of the big ama superbike teams are running speedcell now.  Their quality is top notch.
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
« Reply #14 on: September 01, 2017, 06:07:01 PM »
Shorai is running a 20% off discount SUMMER20 until this coming Tuesday September 5th.
AirCanuck
« Reply #15 on: September 01, 2017, 06:56:27 PM »
Would you mind telling me which battery you recommend by them and why you do? I have a charging issue right now but a new lead acid, so I would keep that battery in until I knew the charging was bullet proof.
What are the pros and cons of this battery?
AirCanuck
« Reply #16 on: September 01, 2017, 07:02:44 PM »
I mean it.
Best explanation I can give you is that it's to replace the original wiring harness. Even better, here is the website...
https://motogadget.com/shop/en/m-unit-digit-tastersteuerung-u-sicherung.html
AirCanuck
« Reply #17 on: September 01, 2017, 07:13:38 PM »
LFX-14A2 is all you need.
Going on the shorai site, they recommend the LFX14A5 battery for my bike. Thoughts?
AirCanuck
« Reply #18 on: September 01, 2017, 07:42:38 PM »
The A5 is a larger frame battery, more comparable to your stock size. The A2 is a small frame battery, about the size of 4 packs of cigarettes.
That would definitely be better for fitting in the space under the seat!! Will it have enough juice for what I need on a 550? I think the bike runs pretty light on draw, all lights have been replaced with LEDs.
I really don't know anything about batteries... what is important? The voltage? The amp-hours? Why?
AirCanuck
« Reply #19 on: September 01, 2017, 07:55:42 PM »
Apologies if this is a silly question from a newbie, but you said shorai is a good alternative to ion - I thought shorai was lithium ion as well??
AirCanuck
« Reply #20 on: September 02, 2017, 05:49:54 AM »
The Shorai I posted has all the power you need, and it is used by many folks. The Shorai is a Lithium-Iron not Ion. The AntiGravs are Ion. The Shorai is still vulnerable to over-discharging as Bodi stated early on.
Oh geeze - so much to learn! Ok thanks very much. I'll have a look at that site. Wonder if they ship to Canada!
AirCanuck
« Reply #21 on: September 02, 2017, 06:38:39 AM »
Can anyone comment on why the shorai is safer than an ion type?
I'm so impressed by how helpful and patient this community is.
AirCanuck
« Reply #22 on: September 02, 2017, 06:45:26 AM »
https://shoraipower.com/lfx14a2-bs12-p66
all I can find is the lfx14a2-bs12 is that what you're recommending?
Offline przjohn
« Reply #23 on: September 02, 2017, 07:20:49 AM »
This thread is probably the most informative on the internet regarding batteries. The OP is very knowledgeable on the subject. Yes, the thread is huge but he gives a Readers Digest version a few posts in.
http://advrider.com/index.php?threads/motorcycle-batteries-agm-gel-wet-lithium-iron-phosphate-lifepo4.757934/
If you don't want to read through his explanations, here's the story spoiler. Buy an AGM if mounting and weight are not an issue.
« Last Edit: September 02, 2017, 07:26:29 AM by przjohn »
« Reply #24 on: September 02, 2017, 07:33:47 AM »
They are all relatively safe if you use a solid state regulator/rectifier.
