Author Topic: Nebraska CB750 K8 Resto/Mod  (Read 19406 times)
Re: Nebraska CB750 K8 Resto/Mod
« Reply #50 on: January 23, 2018, 04:32:44 PM »
Now if I do the 18" rim, do I have to get a special spoke kit from buchanan or will a regular cb750 18" spoke kit for the 69-76 cb750k work?
The 8" rim from any other K0-K6 bike will fit, you'll just need new spokes. Or, Buchanon makes fancy ones, like I am lacing up now for someone.
I think we all know Mark meant 18" but an 8" wheel would need new spokes!  ;D
Offline zeffcat
« Reply #51 on: January 24, 2018, 07:39:31 AM »
Have you dug yourself out from yesterday's snowfall?
I have indeed! We didn't get it nearly as bad here in eastern NE as the western part did. Only about 3 inches here but the 30mph wind iced everything over real good. Into the 40s & 50s for the rest of the week though. My folks in western NE got over 12".
I ended up finding out that someone had switched the rear to an 18" at some point! So less work for me. I've got the wheels all dissembled at the moment, spokes removed and such. Water had gotten beneath the tubes so there was some rust happening. I'm going to have rims blasted and powdercoated rather than buying new rims. New spokes are in order and hubs will be polished.
Still have not heard back from the shop about the engine, getting a little impatient with them as it has been over a month. I guess it doesn't matter so much as I've still got a lot of cleaning to do on the rest of the engine and need warmer weather for painting.
CB750 K8
Offline zeffcat
« Reply #52 on: January 24, 2018, 07:25:43 PM »
Finally heard back from the machinist today, missed the phonecall but from the voicemail I gathered the following: Need to go first oversize on the bores, so I'm in the market for 61.25 pistons. Valves were good, intake valve guides also good, exhaust valve guides need replaced. He suggested cast iron valve guides.
Currently looking at cycleX for these parts. Pistons, rings, pins & retainers can be had for just shy of $200. 8 cast iron valve guides just under $100, going to see if I can just get the 4 exhaust ones. Haven't gotten pricing for the bore yet.
CB750 K8
Offline zeffcat
« Reply #53 on: February 25, 2018, 04:38:06 PM »
Got my engine back from the shop finally. Cylinders bored out one size over, 4 new exhuast valves, ports blasted, valves recut and base of head resurfaced. Going to be ordering a gasket set, cam chain and cam chain guide and tensioner wheel soon. Also got the frame, swingarm, triples and rims powdercoated in gloss black and they turned out fantastic. I'll get some pics up of those eventually. In the mean time I've finally had some free time to get to work on polishing. Here's a little before and after on the rear hub.
CB750 K8
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #54 on: February 25, 2018, 05:45:11 PM »
Will you be taking the Cush drive apart to check the rubbers? They are easy to change and not too pricey. They protect your transmission and drive chain. Mine were pretty hard.
Also, I think the cam chain tensioner is a must. I also can't stress enough how important it is to get Hondaman's rebuild "bible". It will save you a lot of time and grief, most of the answers you need are in there. Best Benjamin I ever spent.
One more thing, inside the case is a primary chain tensioner, it has a roller like the cam chain, I would worry myself to tears if I had not changed it.
Nice project. Keep going.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline zeffcat
« Reply #55 on: February 25, 2018, 06:26:04 PM »
Yep I've taken the cush drive apart and already pulled the rubbers out. Just put it back together for the picture, I'll plan on replacing them. Is replacing the cam chain tensioner wheel not sufficient? And yes, I'd like to get hondaman's book. Just still convincing myself to spend $100 on it when that could go towards parts haha. I'm assuming the cases have to be split to accomplish that last task? I'm desperately trying to avoid that. Although maybe it would be worth it since I've come this far.
CB750 K8
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #56 on: February 25, 2018, 06:53:27 PM »
I too was nervous about splitting cases. The interior of the lower end comes apart very easily, no "shower of parts" will result. When doing the cam chain tensioner you do the wheels and the slipper, they usually come as a kit.
Hondaman's book is a big help with case splitting, he has all the tips and tricks in there. Also, watch Dean Segovia's you tube video on Hackaweek about his K3 rebuild. It's not always helpful but the part where he puts the cases together is a pretty good visual. It's really simple in there. You can measure the main bearing clearances with plastigauge very easily.
Would hate to see you go through all the trouble and have to go back in later.
1973 CB 750 K3
Offline Restoration Fan
  • My wife will never call me
« Reply #57 on: February 25, 2018, 07:22:27 PM »
zeff,
If you haven't downloaded the specific service manuals for the 77 and 78 bikes yet, I have them on a shared Google Drive that you're welcome to use.  Here's the link and it has some other 78 stuff in there as well (parts list, etc)
https://drive.google.com/drive/folders/0B4nqeBb662mZZjZjTWdGRk9Qd0E?usp=sharing
Offline zeffcat
« Reply #58 on: February 25, 2018, 08:39:44 PM »
Yeah I am pretty nervous to get in there but I suppose it would be worth checking while I'm going through everything. And it would make the process of cleaning, stripping and repainting the cases WAY easier. I'll consider just doing that I suppose. I've watched all of hackaweeks's rebuild along with his whole other series on the other bike. As far as the cam chain tensioner, you can buy just the wheel on cyclex and for cost efficiency I was just going to do that since I figured the metal "slipper" as you called it would still be just fine.
zeff,
Thanks restoration fan, I've got one downloaded on my computer and referencing it as I go.
CB750 K8
Offline zeffcat
« Reply #59 on: March 02, 2018, 06:36:43 PM »
Checked the primary chain tensioner today. I'm guessing the general consensus would be too split the case and replace this? The tensioner to deck height was 67.8mm.
Sent from my Pixel using Tapatalk
« Last Edit: June 26, 2018, 10:21:54 PM by zeffcat »
CB750 K8
Offline zeffcat
« Reply #60 on: March 25, 2018, 12:14:26 PM »
Haven't had time to work on the bike in while but got a slew of parts from Honda: cam chain tensioner, wheel, rear wheel dampers,etc. Plus a 4-1 exhaust from Bill Benton! Also got some alumiprep and bonderite to prep the engine for painting. As soon as the weather is favorable I'll be spraying the engine and getting it back together.
« Last Edit: June 26, 2018, 10:22:35 PM by zeffcat »
CB750 K8
« Reply #61 on: March 26, 2018, 06:54:54 PM »
Why do you need alumiprep and bondoite??!
Offline zeffcat
« Reply #62 on: March 26, 2018, 08:38:15 PM »
Well I like to be thorough and I suppose too much so sometimes but I'd found this engine painting prep guide a few months back and wanted to follow through with it! Alumprep is an etching compound that cleans and removes oxidation from the bare aluminum, then the bonderite forms a chromic acid coating which helps stabilize the aluminum to prevent any future corrossion and ensure the paint sticks for good.
CB750 K8
Offline MoMo
  • Ride like you're invisible
« Reply #63 on: March 26, 2018, 09:42:31 PM »
^^interesting info,thanks....Larry
« Reply #64 on: March 27, 2018, 09:11:26 AM »
Interesting post from the CBX forum.  Thanks.
« Reply #65 on: March 27, 2018, 06:55:02 PM »
Hope your motor doesn't turn gold!
Offline zeffcat
« Reply #66 on: March 27, 2018, 07:11:48 PM »
You and me both! I actually contacted the manufacturer of the product with concerns that it was the engine running temp that caused the discoloration mentioned on the CBX forum. They told me that it is commonly used for pre-powdercoating treatment though so engine temps shouldn't be an issue. The OP of that CBX forum said he thinks it was due to the curing process. The chromic acid product requires that the surface being treated be kept wet the entire time during the cure by reapplying product and then rinsing off with water. I imagine thats the step that was missed.
CB750 K8
Offline zeffcat
« Reply #67 on: April 11, 2018, 08:40:06 PM »
Painted the head today. Pretreated with alumiprep 33 followed by bonderite1201 (super easy process). 1 layer of VHT engine primer followed by 2 light, 1 medium coat of VHT engine gloss black. Very happy with the result. Will do the jugs the same and the crank in VHT aluminum. Finish off with polished covers when I get to that point.
« Last Edit: April 12, 2018, 07:21:08 AM by zeffcat »
CB750 K8
Offline markreimer
« Reply #68 on: April 11, 2018, 09:21:07 PM »
Wow that looks really really good! I’m painting an engine black soon, was going to use PJ1 satin, might do the same prep process as you did.
Offline zeffcat
« Reply #69 on: April 12, 2018, 12:15:13 AM »
I considered PJ1 as well but I've had good luck with VHT and it's readily available locally, also was on sale 2 for $12 so that's a plus. Went the extra few steps with this to ensure the best paint adhesion I could. Forgot to mention that it was silica blasted beforehand too.
CB750 K8
Offline zeffcat
« Reply #70 on: July 18, 2018, 12:53:22 PM »
Finally made some progress worth noting. The engine has been reassembled and oil pressure checked so I went ahead and put it back in the frame last night.
Wheels are also reassembled and waiting to be trued up and have tires installed.
CB750 K8
Offline zeffcat
« Reply #71 on: July 19, 2018, 07:22:11 AM »
Realized last night I forgot to put the tach drive gear in the valve cover before reinstalling the engine :-X. So looks like I'll be pulling the engine back out to get that back in.
CB750 K8
« Reply #72 on: July 19, 2018, 08:42:20 AM »
Bummer.  I feel your pain.  This is yet another argument for a frame kit.
Offline zeffcat
« Reply #73 on: July 19, 2018, 09:03:59 AM »
Really wishing I would have jumped for that before powder coating the frame.
CB750 K8
Offline Jnel
« Reply #74 on: July 19, 2018, 09:32:49 AM »
Do it now.  It makes the job so easy.  Best investment I made on my mod.
Sent from my SM-N950U using Tapatalk
