Author Topic: 72 CB500 Restomod - *Update* Sold!  (Read 58546 times)
Offline Scramps
  • Luke Warm, maybe. Not quite a
Re: 71 CB500 Restomod
« Reply #100 on: May 10, 2018, 12:05:17 PM »
Eureka!
While investigating the idiot lights (thanks cal) I discovered the culprit; my cheap Chinese switches!
The kill switch had a ground wire running to one side of it, and the starter button had a switched power wire running to it, so I just swapped those two pins on the plug and VIOLA!
That’s a load off my toad
Offline Scramps
« Reply #101 on: May 10, 2018, 05:48:54 PM »
Well gang, I’ve got all the things hooked up, fuel in the carbs, spark from the plugs, and air from the atmosphere. What else should I check if it’s not firing up?
Offline Scramps
« Reply #102 on: May 11, 2018, 09:25:16 AM »
It is cranking, but not even so much as a cough or a sputter.
I have a Pamco ignition installed, and I have it set up per the instructions on their website. I also have new coils, plugs and wires. I set the valve timing back when I put the engine together, it’s possible that I messed that up, I’ll check it out.
Offline Scramps
« Reply #103 on: May 11, 2018, 02:25:34 PM »
Tested for spark on plug #4, it is firing appropriately, with the “1-4” F mark. As for the points cam, this ignition plate replaces the original cam with this aluminum disk, with magnets in it, about 90* apart. The installation instructions indicated that the two magnets should be at 3 o’clock and 6 o’clock with the cylinder 1-4 mark at 12 o’clock, if that makes sense.
I think I’ve got that right, so maybe the timing is advanced or retarded too much?
Offline Scramps
« Reply #104 on: May 11, 2018, 03:32:50 PM »
No play on #1, just a slight bit on #4
Offline Scramps
« Reply #105 on: May 12, 2018, 07:48:22 AM »
Ok I figured out the problem, I had the petcock switched to ‘off’ instead of ‘reserve’
That’ll get em every time
Offline theDQG
« Reply #106 on: May 12, 2018, 08:28:00 AM »
Happens to a lot of smart people. A lot more than you think...
'83 xv920
'76 xs650
cb750 k4 (2)
'81 R100RS
DQG = The Dumb Question Guy. I ask dumb questions all the time. Bike over ego.
Offline Scramps
« Reply #107 on: May 12, 2018, 09:12:29 AM »
I’ve made a video for this occasion:
You couldn’t knock the smile off of my face with a friggin sledgehammer right now
« Last Edit: May 12, 2018, 09:19:08 AM by Scramps »
Re: 71 CB500 Restomod - She's a runner! :D
« Reply #108 on: May 12, 2018, 09:56:33 AM »
Well done!!  But let's be honest, that was NOT the "first" startup after 30+/- years.  No way.  Fuel was already cycled and it fired like you had been running it a short time before.   ::)
Offline Scramps
« Reply #109 on: May 12, 2018, 10:23:04 AM »
yeah but "2nd startup after 30+/- years" doesn't sound as impressive :P
I had run it for maybe 20-30 seconds before I stopped to setup and record the video
Edit: I have given the video a more appropriate title
« Last Edit: May 12, 2018, 10:28:23 AM by Scramps »
« Reply #110 on: May 12, 2018, 11:29:01 AM »
Agreed!!
Still awesome!!
Offline DurangoCB
« Reply #111 on: May 12, 2018, 02:13:33 PM »
Momentous!  Congratulations, Scramps.
1971 CB500 Four- current project http://forums.sohc4.net/index.php/topic,170622.0.html
1978 CX500- next in line
Offline Scramps
« Reply #112 on: May 13, 2018, 08:11:22 AM »
Around the time that I started this project, I bought 4 vacuum gauges to make a carb synchronizer, so I think I’ll work on building that.
I’m going to make one sort of in the style of Dino’s from Hack a Week. His 750 build was one of my favorite pieces of recorded media ever, as a side note.
Speaking of YouTube videos, the Saturday Sessions build from Bike Exif is also very good, nice editing, funky music, and a surprisingly thorough examination of the process. The guys in the videos do a lot of things that drew criticism, but overall, a pretty good watch
https://www.youtube.com/playlist?list=PLBeUeF9iBQ0Dzh00hEnTRW6YMGo7Wlq11
« Reply #113 on: May 13, 2018, 08:40:01 AM »
Yeah, gotta love watching a nice original bike get ruined and then seeing it smoke like a 2 stroke at the end.
« Reply #114 on: May 13, 2018, 08:51:50 AM »
Maybe check out this channel, mostly Kawasaki's and they don't get super in depth tech wise, but they really do beautiful, non-invasive work
https://www.youtube.com/results?search_query=johnny%27s+vintage+motorcycles
Offline Scramps
« Reply #115 on: May 13, 2018, 11:49:45 AM »
I had a kz750 spectre briefly last fall, bought it and doubled my money on it, but I do wish I had kept it.
Offline Flanker08
« Reply #116 on: May 13, 2018, 06:46:53 PM »
Awesome job!
Offline Scramps
« Reply #117 on: May 14, 2018, 12:55:50 PM »
Thank you, flanker and Durango, I appreciate the compliments! I’m trying to be less of a wiener about taking compliments, which is a real problem that I have.
« Reply #118 on: May 14, 2018, 05:40:06 PM »
Clean bike!
« Reply #119 on: May 14, 2018, 06:49:54 PM »
Clean bike!
yeah, pretty quick too!...here is my Kawasaki ugly duckling
KIMG0232 by Sean Barney, on Flickr
Offline Scramps
« Reply #120 on: May 14, 2018, 08:07:50 PM »
Very nice. Maybe one day I’ll track down another one
Offline DurangoCB
« Reply #121 on: May 14, 2018, 08:49:50 PM »
That's a common fault.  Your use of the word "wiener" on the other hand...  unforgivable.  LOL
Allow the compliments to make you feel good.  Don't forget that that's the ONLY reason to be working on these old bikes.  It won't make you rich.  It won't make you cool.  Women couldn't care less.  Long hours in the shop don't do much for your health or your physique.  The only reason to do it is because it's fun.  If it isn't fun... figure out how to make it fun!
Offline Scramps
« Reply #122 on: May 15, 2018, 05:07:05 PM »
Well said, thank you again.
Back to bike stuff!
In the absence of stock headlight brackets, what’s a good way to seal up the top side of some stock gators?
« Reply #123 on: May 16, 2018, 09:24:24 PM »
Happy birthday belatedly wished. Congrats on getting the bike going. I think I have a good rear rim, but it is currently on the bike, a 550. Unfortunately, I cannot be as generous as Calj as I can't give it away given I bought a replacement.  Rim is pretty good, the spokes on the rim not so good...figure you just want a good rim, right?
Presuming your requests on the forum didn't net another...or you didn't hit up Bill's batcave yet.
David
Offline Scramps
« Reply #124 on: May 17, 2018, 07:01:43 AM »
Oh yeah, I’ve got the rim situation resolved. Thanks for the offer, and for the birthday wishes!
