Author Topic: 03' gsxr fork swap/ stem damaged?  (Read 1407 times)
Offline Shtonecb500
    • Youtube profile
« on: March 04, 2018, 11:27:07 AM »
This is damage or a mod, right?
that cant be stock.
73/74'' CB500/550 resto-mod - sold
75' 750f 91' cbr f2 swap cafe - mock up
74' 750 chopper hardtail - complete - sold
74' CB750/836kit - Black mix & match - daily rider - always tweaking
71' cb500 K0 survivor - complete
71' K1 - CANDY GOLD/BROWN Winton kit - in process
Re: 03' gsxr fork swap/ stem damaged?
« Reply #1 on: March 04, 2018, 11:45:56 AM »
It's not right, needs a replacement.
 Not sure what happened to it, maybe corrosion? ..strange.
Offline strynboen
« Reply #2 on: March 04, 2018, 12:03:53 PM »
vater can give strong korosion..specily if rustfree steel and aluminium are araund..is there still solid metall to hold..look a bit unsafe..
i hate all this v-w.... vords
« Reply #3 on: March 04, 2018, 12:06:14 PM »
That doesn't look like mere corrosion.  Whatever the cause, that stem needs to be replaced.
Offline Shtonecb500
    • Youtube profile
« Reply #4 on: March 04, 2018, 12:35:11 PM »
Ok thanks guys. Luckily I have another front end to use, I'll source another stem.
Offline Shtonecb500
    • Youtube profile
« Reply #5 on: March 04, 2018, 05:04:09 PM »
i have a 98' front end that I can steal the stem from, or I could just use the 98' set up...Anyone know of the pro and cons of using the older fork or should I just swap the stem to the newer set up
« Reply #6 on: March 05, 2018, 08:41:21 AM »
It's difficult to provide more advice, because we don't know which model GSXR donor and which model CB recipient.
It you are installing onto a 550/500/650 front, the stock GSXR stem can be used.  If you are installing onto a 750, you will need a longer stem.
It is likely that a 1998 GSXR front will have conventional forks -- as opposed to the 2003 Upside-Down forks.  The 98 forks might be lighter (an advantage), but the 2003 will be slightly advanced -- though both front ends will be a leap ahead of the stock CB front.
It does not appear that you are concerned with the decreased offset (distance between the fork tubes and steering stem) of a modern front versus the stock offset of the CB.  Although a modern front will be an improvement to handling and braking, a smaller offset (35mm for the GSXR from the stock CB500/550 45mm or more for a CB750) will make the bike a bit more twitchy.  It will cost more, but you should think about triple trees to restore the offset.  Your bike, your skin/bones, so that's up to you.
Offline Shtonecb500
    • Youtube profile
« Reply #7 on: March 05, 2018, 09:12:40 AM »
Hey Sorry for a lack of information, both set of forks are traditional and not upside down. I guess my question was self explanatory considering the 03 will have newer components and thats that. I will be addressing the offset issue with this swap but only when $$$ permits.
The project bike is a 74' 550. Ill just press out the stem and stick it on the 03 forks.
« Reply #8 on: March 05, 2018, 03:00:41 PM »
Sounds like a solid plan for now. If you feel so inclined, you might re-name the subject and make this your build thread, so we can follow along and you can post questions, etc. as issues come up.
Welcome!
