Author Topic: Early Sandcast Found......  (Read 148823 times)
Offline BenelliSEI
  • 1969 cb750
Re: Early Sandcast Found......
« Reply #600 on: February 17, 2022, 10:50:56 AM »
Built switches into new bars today.
Terry...... If you read this, thanks for sending the switches back. Did you ever look at them? I just opened your package today and to my surprise, the LHS switch was a slightly later style. The correct switch was still on my shelves!!! I sent you the wrong one...... what an idiot I am.
Offline BenelliSEI
  • 1969 cb750
« Reply #601 on: February 17, 2022, 10:52:41 AM »
I'm thinking 4 or 44 means 1969, Honda was numbering for short term ID in their factory. They weren't expecting us to care in 2022.
Just curious! Thanks.
Offline BenelliSEI
  • 1969 cb750
« Reply #602 on: February 17, 2022, 11:09:40 AM »
Bars are done. The single cable throttle tube needs some sanding before the grip goes on.
I put the grips in a pot of boiling water for a few minutes. Pull them out hot and leave them wet. They slide on very easily. A few minutes later, totally dry, they shrink back to size, well secured.
Offline BenelliSEI
  • 1969 cb750
« Reply #603 on: February 18, 2022, 12:42:10 PM »
Another 5-6” of snow last night, so spent half the day plowing and shovelling. Living +1200 feet UP from the road has it’s advantages and not. No complaints, the entire Family has another down hill ski day planned for Sunday. Sunshine and blue skies for the next few days.
Got in the shop for a bit this afternoon. Cleaned, polished, lubricated and mounted the brake pivot/bracket. Under a bit of crud, the original finish was perfect. Even the pin slid out easily. This bike was never left outside..... Front fender is on and installed the new handle bars. I wonder how many pieces make up a cb750? Amazing how little difference a dozen makes! No pics.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #604 on: February 19, 2022, 07:46:36 AM »
I read somewhere the part count is around 2000
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline BenelliSEI
  • 1969 cb750
« Reply #605 on: February 19, 2022, 11:00:15 AM »
Sounds reasonable....... the problem is I have to do everything 3-4 times to get it right!
Offline BenelliSEI
  • 1969 cb750
« Reply #606 on: February 19, 2022, 02:31:05 PM »
Small progress today.....
« Reply #607 on: February 20, 2022, 12:57:10 AM »
That bike look like new! ;D
Who can say no to a 69? ;D
Offline BenelliSEI
  • 1969 cb750
« Reply #608 on: February 20, 2022, 05:28:37 AM »
Thanks Per. Determined to enjoy this one and take it slow. Wasting lots of time cleaning and polishing hardware and small bits, but I want this bike to be “99%” original. Spotted this one yesterday and hope mine will look like this:
« Reply #609 on: February 20, 2022, 05:59:32 AM »
That one look like a really fresh old bike!
Sun bleached tank and sidecovers could be something for Yamiya :)
Offline BenelliSEI
  • 1969 cb750
« Reply #610 on: February 20, 2022, 06:04:11 AM »
I was comparing the bike to photos from “day one”. A few parts have moved on..... The points cover that was on the S/C ended up on the Chopper, that is now in Indianapolis!
« Last Edit: February 20, 2022, 06:05:53 AM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
« Reply #611 on: February 20, 2022, 06:07:20 AM »
That’s what I have. The right side of my headlight is more silver than red!
« Reply #612 on: February 20, 2022, 06:34:55 AM »
Patina might increase the price on this old bike as Frank wrote earlier.
That will show an original part, not new or NOS.
My K6 has also that kind of ignition cover.  Look good on a modified bike.
Honda stock ignition covers cost crazy money today!
Offline BenelliSEI
  • 1969 cb750
« Reply #613 on: February 20, 2022, 06:59:37 AM »
When Don mentioned the prices of those covers, I realized I was using one as an astray! It’s cleaned up, and put away....
I miss Frank bugging me about not restoring this bike. He pestered me non stop.
Yesterday, I cleaned up the brake caliper swivel bracket. I was going to blow some paint on it, but it looked fine. In deference to him, I bolted it on. It looks great. The original “scarred with history” paintwork is dedicated to him. Never met him, but wish I had.
« Last Edit: February 20, 2022, 07:06:47 AM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
« Reply #614 on: February 21, 2022, 01:24:09 PM »
Mounting the front fender stays and discovered a small problem. The slash cut ends were slightly flared out. Maybe the chrome shop handled it a bit too much when plating and polishing? Made up a small clamp with plastic covered ends and slightly pressed the two edges at both ends. Got both stays cleaned and prepped and it all went together smoothly. The last little screw I tightened cracked one of the tiny black spacers on the bottom stay (between the stay and fender).
Pissed me off, so I dropped the tools and went up to the house. I have a bag of extras somewhere!
Offline BenelliSEI
  • 1969 cb750
« Reply #615 on: February 22, 2022, 06:05:56 PM »
More rain and then freezing rain today. Slid (literally) into the shop for an hour, I like doing a little bit, every day. Replaced the cracked spacer (see above) and while searching for a spare, stumbled on a “throttle drag thumb turn screw thingy”  that was missing on this bike. Cleaned up nicely and that shortcoming is fixed. Original speedo cable is in excellent shape, so cleaned, lubed and installed. Tested all the lamps in the speedo before assembly and screwed it all together and on the bike. Both instruments just came back from cb750Faces and look fantastic. Photos after the tach gets done.
The original horn has slightly pitted chrome, but when tested, just about blew me out of the shop. Thinking it probably hasn’t made a sound since 1977-78, I polished it up and hung it in place. It stays.
Waiting for the rear hub and brake backing plate to return. Guy down the road polishes “big rigs” and does small bits for me. Dug up some new bearings from parts bins getting set to build a rear wheel next. My buddy Gary is coming for a shop day tomorrow. He’s taken on cleaning the major crud off the engine, before I pull off top end. I’m in debt to Covid Boredom, much appreciated! Picture is “inspirational”.
« Last Edit: February 22, 2022, 06:13:53 PM by BenelliSEI »
« Reply #616 on: February 24, 2022, 08:01:05 PM »
Good looking patina bike.
Offline BenelliSEI
  • 1969 cb750
« Reply #617 on: February 27, 2022, 04:36:46 PM »
Interesting look. The rest of the bike looks totally restored. I like it.
« Reply #618 on: February 28, 2022, 03:37:23 AM »
A good looking patina bike is probably hard to find, except for those parked in a dry garage or store room so it never rusted during all years.
But such bike has a story to tell when the use is visible enough to know it's all original.
Another thing that the owner never rebuilt the bike that was a must back then. Original 4-4 and paint not good.
Now completely different. A stock CB is very beautiful when clean and polished.
Offline BenelliSEI
  • 1969 cb750
« Reply #619 on: February 28, 2022, 07:09:47 AM »
Polisher just called, rear hub and backing plate are done. Rear wheel building time, after new bearings. Will pick it up later in the week.
Spent some time mounting the tach, front brake light switch tee, and used my grease gun to “pop” the piston out of the caliper housing. The piston was absolutely spotless, but I did find the usual amount of crusty crap under the seal! Will need to find my dental pick and get some new ends for my Dremel. Dismantled the seat latch bracket and blasted it clean, prepping for black paint. Into the “endless tasks” portion of the restoration. No point in making any work lists yet!
GOOD SHOP PRACTICE: I learned this years ago, from a very experienced guy who rented a space in our race shop: Any job that is not 100% complete and torqued down gets a small yellow zip tie attached. When the job is done, remove it.
« Last Edit: February 28, 2022, 04:38:25 PM by BenelliSEI »
« Reply #620 on: March 01, 2022, 08:44:30 PM »
I used to see guys in the plumbing trade test fit, and then forget to glue or solder the joint. They could have used a yellow zip tie.
Offline BenelliSEI
  • 1969 cb750
« Reply #621 on: March 02, 2022, 02:21:42 PM »
Wheel building today. Very pleasant!
Offline BenelliSEI
  • 1969 cb750
« Reply #622 on: March 02, 2022, 02:23:05 PM »
In addition to starting the rear wheel, “clocks” and fender stays in place. Caliper swivel too.
Offline BenelliSEI
  • 1969 cb750
« Reply #623 on: March 02, 2022, 02:25:35 PM »
Jumped around a bit today, scraping out front caliper.....
« Reply #624 on: March 03, 2022, 03:32:21 AM »
“Snow Tires” arrived today! FortNine had excellent prices for Dunlop K70’s and arrived in 3-4 days.
What is that stuff you call snow, gonna have to look that up on the world wide web...
We had 88F temps here this afternoon, this year is likely gonna suck if it is getting this gmhot and it isn't even May when we normally" start our daily highs or will have hit 90 with constant regularity .
May have to take plenty of rides up to SummerHaven this year on My Lemmon and explore the higher altitudes where it is cooler as well as get the VStrom in some offroading where it is allowed up there. Wondering if * can take the road at end of Marshall Gulch all the way down. I think you can go up a fire road on the NE back side of I am reading the Google Maps correctly. The SW-Motech skid plate and other stuff might get some use then.
Decided To put some amber fogs on the crash bars or fit a cet below the beak where they will survive a drop...
An advertise bike I saw in traffic late today had an integrated set of super bright Amber LED front lamps and they stood out so well in daytime that it is worth it to make the bike that much more visible. Putting some amber Eagle Eyes along the bike to light up the bike at night pointed down toward the motor, fenders, etc...&:other stuff ...Saw a bike that used waterproof LED strips on this way and it really made a difference on side view where someone might broadside you... It makes your visual signature greater without violating any laws.
CanAm made a version of one of their 3 wheelers and it came from the factory with blue lighting underneath painted towards the ground. Know some who ordered that model that featured it. After she got stopped and cited (ticket) a second time she made CanAm dealer change out the color lighting at their expense. In most states it is illegal to have blue or red lighting on the vehicle unless you are an emergency vehicle...even if it is underbody lights...
Tiresvlooj good John...just visited the thread and had to go back a page or so as Terry was talking about his long balls... Just TMI Terry!
Let's keep that info to yourself...we really don't wanna know about that...
Fell after I got home late last night and gonna have to get my right hand x-rayed today...may have only hyper extended the last two fingers of hand. This was after my key broke off in the lock after I inserted it in the door. Flush with outside. Back door key I discovered after gaining access to the screened porch by disassembling some stuff so I could access the rear door, only to discover my backup keys I thought I had in my wallet were all for the front door. Backup key ring is locked in house in my bedroom...
Ugh. Have to get key from landlord after it is a decent hour and he has woken, sent him a text message a few hours ago. Now traffic leaving for work with early hours or long commutes has been picking up since around 4 am...
Sleep might not come... Guess I will use the noise canceling headset to drown out traffic with either silence or some soft  music...
« Last Edit: March 03, 2022, 03:43:33 AM by RAFster122s »
