Author Topic: Turbo Charged CB550 Landspeed Project  (Read 37388 times)
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: Turbo Charged CB550 Landspeed Project
« Reply #325 on: July 21, 2025, 12:25:11 PM »
I enjoy following this thread BM650....
Thanks for reading my landspeed blog 😅
30,000+ views i was shocked
Over 31,000 views now, I'm not shocked, it's the most interesting project on the forum right now!
Most guys dont reply, but they are viewing...
Aww, you really think so? All the heavy lifting was done years ago!  Its just refinements now.
When this bike goes on public display.  The people are drawn in by the wild wrap color twist.  Then they see the stance, then the pipes.  Some people realize theres a turbo hidden in there.
But the common denominator is people sleeping on this gem of pizza box engineering.
Rear suspension.  Obviously people see the huge rear shock, but they move on quick.
Its my favorite part of the build, personally.  It took so much effort to make the rear fork and gusset the frame for an offset shock.  Then turning out the bits to fit a ninja rear wheel and brake
Sure the header was a ton of pipe fitting. But the rear end of this bike is what took everything I got to accomplish.
  • Holy Cow! I'm a
« Reply #326 on: July 21, 2025, 07:12:12 PM »
This is not an aerodynamic aid.
Old corrie plastic repurposed to an inner fender lining
« Reply #327 on: July 21, 2025, 08:44:01 PM »
How does it run with the new turbo? That's what I've been waiting for! ;D
  • Holy Cow! I'm a
« Reply #328 on: July 21, 2025, 09:52:17 PM »
It should idle okay.  And soon - Next weekend.  Put fresh lucas oil in it today
Found out the local renegade dealer doesn't stock the ratman pails.  They do have an alternative that would work.
On the fence about dyno tuning at sea level.
Won't be able to really run it until Wendover
Tidied the wiring harness.  Lubed fhe throttle cables.  Gotta set up the fuel lines and firesleeve.
Decide how to finish the new inner-fender. Need to trim a few fasteners and grease the others.
And put the gate and pipes back on.
Gate needs a gasket.  Handy as i just received more gasket making stuff.
Wrapped the air scoop.  Really burning at both ends here.
Have a little special feature on order to livery things up a bit.
Online newday777
« Reply #329 on: July 22, 2025, 05:13:38 AM »
I'm still occasionally following on from a distance and being amazed at your leaps and bounds, but you do have to make hay while the sun shines to get there on time. Well done.
Stu
My current rides
Prior bikes....
« Reply #330 on: July 22, 2025, 09:40:57 AM »
If it won't run right at sea level, it won't run right at 4500'. Besides, you have a turbo to compensate for altitude; that's why they started using them on airplanes in the first place. ;)
  • Holy Cow! I'm a
« Reply #331 on: July 22, 2025, 07:07:45 PM »
Airplanes! 😎
Last season, the other 550four racers got flooded out by lack of lean jetting.
I have changed a bit about the carburetor.  The pilot and mains are the same.  But i've ditched the alkyhaul needle in favor of the richest gas needle available.  Which should smooth the transition above 3/4 throttle.
The Difference in airflow from the new intakes and compression however.
Between the thunderjet and the boost control i should be able to make more record runs.
Im most concerned about my manifold seals.  Need to make those backup spares.
  • Holy Cow! I'm a
« Reply #332 on: July 27, 2025, 11:14:00 PM »
Ugh, the gremlins got me good today.
But, it will run.
With a new battery and a new switch.  (The handlebar button is a dime a dozen on alibaba so fml)
Bypassed the switch to keep working.  Was cranking and firing up when the battery just nope'd out of the equation.
Hard to tell if the pilot is too little or too much from how brief things were.  A little parts cleaner in the scooper helped.  Carb float needs love too.  Might have been the angle of the carb reaching overflow heights.
Went through the boost control lines and found a leak.  In the wastegate.  While the gauge and leakdown regulator correlate fine, and i was able to adjust the pressure switch for ignition retard.  The loss through the gates valve stem is significant.  40-50%.
Also ran into an issue with the turbos banjo bolt.  The one i had worked up to start with let me down.  Its not getting a good crush on the copper seals.  So i was swapping for rubber core when the threads let go.  Dug through the bins and found a bolt i could make work.  But ordered another feed line banjo kit for posterity.
New everything is on the way.  It was an expensive day off.  And i didn't even leave the house!
Managed to check off a lot of smalls from the list.  Aside from hooking up electrical and finding its not weathered well.  I also made some aluminum gaskets for the intake, should the need arise.  Calibrated the wideband to whatever my shop is.  Setup fuel lines and fire sleeves.  Shortened the seat bolt and painted all the weld nuts with anti-seize.  And got the oil caps safety wired again.  Fixed a few more zip ties in various places to keep things tidy.
Next weekend is gonna be a doozy.
  • Holy Cow! I'm a
« Reply #333 on: July 27, 2025, 11:15:19 PM »
At least the bike looks good with the pipe and tank fitted
Online newday777
« Reply #334 on: July 28, 2025, 03:41:46 AM »
Yes that pipe is cool looking.
Stu
My current rides
Prior bikes....
  • Holy Cow! I'm a
« Reply #335 on: July 28, 2025, 08:41:34 AM »
Spent last night going through shorai troubleshooting.
And learned that ...
BMS voltage protection activated.
When cranking down to whatever specified voltage.  System initiates a bypass.  Dropping to zero vdc.
Of course the shorai special charger has a feature to reset the bms.  They also explain how to fix it with a pair of jumper cables.
So, dug out the surplus battery strap and grabbed my old fjr battery (also shorai) and linked the two batteries together pos-pos and neg-neg - within a few seconds the volt meter came on and stayed on.  12.3
So the race bike battery is back, sitting on the trickle charger for now.  The replacement is already on the delivery truck.
Ugh.  At least i have a few week(ends) to sort this stuff out.
The little time that i was able to run the engine i saw some pretty happy vacuum numbers.  Gotta get the idle jet and accelerator pump dialed in.
Pic of home made aluminum gasket.  One set dimpled, another set flat.  Havent fully carved out the flat gaskets yet.
« Last Edit: July 28, 2025, 08:46:52 AM by BomberMann650 »
« Reply #336 on: July 28, 2025, 11:43:52 AM »
Ahhh, the old DeWalt "dead" battery trick. Works great if a battery still has "potential" but "dead". Good job!
  • Holy Cow! I'm a
« Reply #337 on: July 30, 2025, 08:27:45 AM »
Got some super fast delivery of the replacement waste gate.
The company knew their product would end up on somebodies sh!tb0x project build.  And made it using the same bolt pattern as the cheap imitation part.
Then they stuff 17 pounds of 8 inch long springs inside the cap with 1/2 inch screws.  Like the worlds worst jack in the box.  They recommend using a clamp during assembly and disassembly.  But with the part in sitiu, where to clamp is a problem.
My solution is a pair of long screws
  • Holy Cow! I'm a
« Reply #338 on: August 03, 2025, 10:34:16 AM »
The moment you've all be waiting for.
Running on choke - drying the pipes
Fighting the float and finding the accelerator pump in the old bowl is a goner.
13.7 on the charging system - just the ignition for now.  Will load the afr meter and check again.
Pipes heated evenly and it would idle down.  Starts easy with a 30 pilot jet
Still more to do before the day is done.
But what a joyful noise
https://youtube.com/shorts/zjbj_xscHmI?si=QodAfUo833hFUfw2
« Last Edit: August 03, 2025, 10:36:21 AM by BomberMann650 »
Offline denward17
« Reply #339 on: August 03, 2025, 11:39:41 AM »
Nice to hear it run!
  • Holy Cow! I'm a
« Reply #340 on: August 04, 2025, 08:24:53 PM »
Anyone else wanna complain about the price for gas?
  • Holy Cow! I'm a
« Reply #341 on: August 07, 2025, 08:00:21 AM »
Small issues during the heat cycles.
Noted the bowl fill slowing down.  Opened the clasp on the tank cap and heard it rush with air.  So i filed some better vents into the thing.
The oddball turbo and its oil feed fitting continues to cause some grief.  Not even sure what tap they used on the iron casting, but it wasn't the same as the Mercedes benz rhf4 thread.  One of my cheap threading dies manages to carve a banjo to fit and fasten.  Sealed with aluminum crush washer.  Only problem now is the oil flow.  Cb650's big pump sends too much oil up there.  An Inline restrictor is on order. An4 insert type.  A scoche under 1mm.  Hope it works.
  • Holy Cow! I'm a
« Reply #342 on: August 07, 2025, 08:13:11 AM »
Additional fun with heat cycles.
As anticipated - the vacuum pressure between turbo and carburetor was enough to collapse the silicone elbow.  Caused some whacky flow dynamics and may have contributed to the hanging idle.  The available aluminum elbow tubing was 45mm od.  Silicone 45mm i.d.  not enough room to place four clamps and two sleeves under the hood.  So with a little lube, stuffed the alloy tube inside the silocone.  No more collapsible intake duct.
Another thing on the list is the accelerator pump.  In spite of its actual new genuine replacement - the plunger likes to stick in the down position.  Is there not enough lubricity in the race gas?
Is the spring wearing out?  Will find out on the next episode.
Gotta knuckle down and get the last pieces of the cycle trailer assembled.  The tri-fold ramp will help this solo act safely disembark.  And it lives in a home made alloy holster that now has pins to secure it all.  But those pins need something to secure them as well.
  • Holy Cow! I'm a
« Reply #343 on: August 11, 2025, 07:20:42 PM »
More AC welding today.  Making a shield for the trailer
Every inch of aluminum welding i do gets better.  Yet there is the occasional moment where i wonder if the part is fully penetrated   in spire of being a nice shiny smooth even weld.
Tinkering with the welders settings helped some.  But it went from extra frosty (cleaning) to melting fhe electrode.  So it ended up somewhere in the middle again.
Its also time to adjust the high frequency start on the welder.  One more thing on the list haha
  • Holy Cow! I'm a
« Reply #344 on: August 11, 2025, 07:23:09 PM »
This detailed photo of the intake setup 👍🏻
Offline richmagee7
« Reply #345 on: August 13, 2025, 04:43:50 AM »
Can't wait to see it in person Bombermann.
Rich
« Reply #346 on: August 15, 2025, 08:06:38 PM »
 I was reading back a few pages, I run the hi frequency on constant when I'm welding aluminum. It takes a lot of heat to get the puddle started, doesn't it?
  If you cut more silicone tube, try rolling up some heavy brown paper into a tube and then unroll the inside until it's bigger inside the silicone.
« Last Edit: August 15, 2025, 08:26:55 PM by Don R »
  • Holy Cow! I'm a
« Reply #347 on: August 15, 2025, 08:13:41 PM »
I run the hi frequency on constant when I'm welding aluminum. It takes a lot of heat to get the puddle started.
Right - i was just cussing at the torch cause i was basically having to scratch start the rig.
Primeweld has one page of the manual dedicated to maintenance.  It reads "see dealership for assistance"
« Reply #348 on: August 15, 2025, 08:29:41 PM »
  L0L. I had a farm store mig with no phone number, Email, or address in the manual. I replaced the plastic liner with a metal one made for a better welder.
  A couple friends got the YESS welders, they seem to be pretty good.
  • Holy Cow! I'm a
« Reply #349 on: August 16, 2025, 06:08:50 AM »
had the yes welder on my watchlist before i begin following 'the fabrication series' on youtube.
His classroom and channel all relied on the primeweld.
