Author Topic: Battery Installation TWEAK.  (Read 3611 times)
Online BenelliSEI
  • 1969 cb750
« on: August 03, 2023, 11:26:10 AM »
My new batteries came with nice plastic caps protecting the terminal posts. Instead of throwing them away, I carefully cut the tops off and slid them back into place. Perfect for holding the little square nuts in exactly the right spot!
« Last Edit: August 03, 2023, 05:24:24 PM by BenelliSEI »
Online PeWe
Re: Battery Installation
« Reply #1 on: August 03, 2023, 01:04:50 PM »
Good idea! ;)
Offline denward17
« Reply #2 on: August 03, 2023, 01:27:16 PM »
I like that, I put it in the memory bank.
Offline bek1966
« Reply #3 on: August 03, 2023, 01:36:52 PM »
Fantastic idea.  Thanks for sharing it!
1971 CB750 K1 - Candy Gold
1971 CB500 K0 - Star Light Gold
1974 CB350 F1 - Glory Blue Black
1975 CB550 F0 - Someday "ProtoSport"
Pleasant Prairie, Wisconsin
Online BenelliSEI
  • 1969 cb750
« Reply #4 on: August 03, 2023, 05:23:32 PM »
Thanks. Installed it in the K3 and was a treat. No worries about losing the little buggers!
Offline Kelly E
  • Geriatric Hooligan
Re: Battery Installation TWEAK.
« Reply #5 on: August 03, 2023, 06:05:37 PM »
Great idea! 8)
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #6 on: August 04, 2023, 04:14:52 AM »
you better patent that idea?the battery companies will see it and suddenly have"now with static nut technology"?
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #7 on: August 04, 2023, 07:47:03 AM »
Brilliant!
1973 CB 750 K3
10/72 build Z1 Kawasaki
Online BenelliSEI
  • 1969 cb750
« Reply #8 on: August 04, 2023, 08:51:05 AM »
Offline kerryb
  • Not a very
« Reply #9 on: August 04, 2023, 12:09:42 PM »
I'd like to add a detail to this procedure...a small piece of closed cell foam cut to fit under that nut to always hold it up to the top of the housing.  Makes putting the screw in much easier.  Been doing it for years, can't find a down side..
Online BenelliSEI
  • 1969 cb750
« Reply #10 on: August 04, 2023, 12:14:26 PM »
Yes! I used 1/2 and ear plug….. This battery actually has a deeper nut.
Offline robvangulik
  • Honda Fourever
« Reply #11 on: August 04, 2023, 01:42:51 PM »
I've been using small pieces of tubing (that comes with acid batteries) for just that for years.
« Reply #12 on: August 04, 2023, 04:59:27 PM »
this is great!  I remember the frustration trying to install a battery in my first motorcycle...certainly contributed to me initially giving up on old bikes.  Luckily, I did get back to them.
« Reply #13 on: August 08, 2023, 02:11:42 AM »
My batteries have threaded posts, no need to mess with a square nut.   I use Mottobats, the one Scorpion I had died way too early to my liking.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #14 on: August 08, 2023, 07:56:23 AM »
It's stuff like this that makes this forum great.
1973 CB 750 K3
Online BenelliSEI
  • 1969 cb750
« Reply #15 on: August 09, 2023, 04:47:00 PM »
Steve…. All good  in your area? Some crappy fire news on TV a tonight…..
Offline ofreen
« Reply #16 on: August 10, 2023, 06:46:22 AM »
I keep a box of popsickle sticks in the shop that come in handy for a lot of things.  I put a dab of RTV on a chunk of popsickle stick and slide it in below the nut.  Stays put for the life of the battery.
Greg
'75 CB750F
« Reply #17 on: August 10, 2023, 07:25:43 AM »
Where an inexpensive source for Motobatts?
Online PeWe
« Reply #18 on: August 10, 2023, 08:45:57 AM »
Another good one to keep nut in place and avoid getting nuts! ;)
Online BenelliSEI
  • 1969 cb750
« Reply #19 on: August 10, 2023, 09:19:27 AM »
Great idea. It’s surprising none of the manufacturers supply a simple solution.
« Reply #20 on: August 11, 2023, 12:52:22 AM »
simple solution?its gotta be patented then marketed?research and testing?
Online BenelliSEI
  • 1969 cb750
« Reply #21 on: August 11, 2023, 05:19:50 AM »
So true. And no one there has actually installed a battery!
Offline Erny
« Reply #22 on: August 11, 2023, 11:23:24 PM »
Great and simple solution! Just pity that new Yuasa is not coming with such plastic cups. These square nut are making me crazy each time I work on battery
CB750K K7 USA model (1977)
CB550K1 USA model (1975)
Offline Deltarider
« Reply #23 on: August 12, 2023, 01:27:58 AM »
On mine I have the conventional Yuasa (6 1/2 years old now) and I don't know what you guys are blabbing about.  ;)
CB500K2-ED Excel black
« Reply #24 on: August 12, 2023, 04:54:09 AM »
Delta for the Karen comment, as typical
