Author Topic: Hondaman gave me an idea... Velocipods(c)(tm)?  (Read 6126 times)
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« on: September 18, 2007, 01:47:17 PM »
So, Hondaman was saying how velocity stacks really smooth out intake flow, and cut down on turbulence at certain velocities. which of course, helps smoothness and performance.
He was also saying how bad velocity stacks are for your rings, as you tend to pull in a fair amount of dirt.
He also mentioned that K&N used to make filters that would attach to some form or other of velocity stacks.
Haven't seen em around.
So, got me thinking, why not design my own and have 'em machined?
So here's what I'm thinking:
The flange at the carb throat side is expanded to allow a nice rubber sheathing, keeping a smooth airflow from stack to throat. The edges are cutaways to
allow hose clamp or the like to secure the velocipod(c)(tm) to the carb.
Note the single crossbar inside the velocity stack to keep the foam from being sucked in.
A nice, elegant 'screen' that secures with 2 tiny nuts and bolts to keep the foam in.
Best of both worlds?
Maybe.
What do you think? Would you buy these?
« Last Edit: September 18, 2007, 01:49:21 PM by mlinder »
No.
Offline DarkRider
Re: Hondaman gave me an idea... Velocipods(c)(tm)?
« Reply #1 on: September 18, 2007, 02:37:26 PM »
So they are essentially Velocity stacks with filters in them?...I would like to see how this turns out..
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #2 on: September 18, 2007, 02:39:48 PM »
Not even essentially. Just plain are, with a couple of small mods to make sure the foam doesn't go anywhere. Also, a bit different on the carb side than most velocity stacks, but for a good reason.
No.
Offline Dougy Dougy Dune Buggy
  • Wrenchin Mofo
« Reply #3 on: September 18, 2007, 03:35:24 PM »
Nice Drawing MLinder,
you using Solid-Works??
I've yet to fully PLAY with mine yet, nice looking design
are you going to make a plastic model?
Keep us posted, i'm sure there is MUCH interest in this thread
Thanks,
DWYJ
I'm going to Cafe it
ONE DAY
ha ha
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #4 on: September 18, 2007, 03:53:14 PM »
Rhino3d 2.0
Well, dunno, may as well have em machined outta aluminum if I'm going to have anything made at all.
No.
Offline sparty
  • I just play one on TV
    • Gallery
« Reply #5 on: September 18, 2007, 04:58:39 PM »
I was reading about my K&N pods, it says that they have a built in velocity stack, however, it doesn't look quite like what you would imagine.
1972 CB750 K2 Cafe' Style
« Reply #6 on: September 18, 2007, 05:50:27 PM »
Looks hot, be very interested to see how they work out. There must be am optimum length which will take some tinkering to figure out.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #7 on: September 18, 2007, 05:56:38 PM »
Correct, though from what I gather, optimum length depends on what kind of RPM you plan to make most of your power in.
No.
Offline 333
  • Time for change
« Reply #8 on: September 18, 2007, 08:55:49 PM »
A great idea, but a small problem.  The foam you picture is too thick.  It will put too much restriction on the airflow.  So maybe use a single layer of the same media K&N uses, dome shaped over the end.  Or maybe a flat wavey piece.  Wavey would give a larger filter surface promoting faster flow and better filtering at the same time.
Then patent the idea, and sell it to K&N.  Let them build it.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #9 on: September 18, 2007, 10:13:43 PM »
I like the work.  You have obviously put some time and thought in to this. “Cool program you are working with”.
I'm not an engineer, or even 1/2 as clever as lots of people here, but I would think the "smoothness" as you called it as a preferable intake for air would be completely dissipated by the thick foam filter.  The air would now not "flow" over the bowl cleanly.
On the other hand, many people have talked about their difficulties in getting their bikes working with pods..."I love mine" ;D  This design of yours may be an easier alternative to EMGO's or others as the air would be much less a severe increase as free flowing.
Again, just my thoughts at 10:00 after a couple of beers ;D
Keep it comng :)
Offline mrbreeze
  • Not your average
« Reply #10 on: September 18, 2007, 10:27:46 PM »
Maybe.
You build it........they will come!!!!!!!!!!
MEMBER # 257
Offline mrbreeze
  • Not your average
« Reply #11 on: September 18, 2007, 10:35:56 PM »
Better yet....ya know how Supertrapp exhausts have the extra disks on the end of the muffler............How about velocity stack filters of different thicknesses to control the amount of air intake while still providing air filtration? I don't like the idea of a daily driver running wide open air intake....save that sh!t for the drag strip.
MEMBER # 257
eldar
« Reply #12 on: September 19, 2007, 06:44:18 AM »
this looks interesting. If I may throw a couple ideas out. Instead of a filter dome, make it go inside the stack which may help pull in more air. The little cage piece that goes over the foam, use it to help hold the foam in place. Then my final idea would be to have a tube about mid-way on the stacks that links the stacks. This would ,at least in my idea, help provide smooth and consistent airflow between all the carbs.  Kinda like and h-pipe exhaust system.
Offline DarkRider
« Reply #13 on: September 19, 2007, 08:35:59 AM »
What about having two of the crosshair pieces or even just a piece of mesh on the outside sandwiching a section of the same media as the K&Ns? so apperance wise it appears to be a wide open stack you look down the bore you see the protective mesh.
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #14 on: September 19, 2007, 10:11:03 AM »
With your thoughts, I've revised the design.
Though more complicated, I think it addresses the pertinent issues, flow and turbulence.
No.
« Reply #15 on: September 19, 2007, 10:57:21 AM »
Okay, here is an engineering theory perspective.  (There, that should stop 80% of the readers so they can continue to the next post.)
Velocity stacks provide at least two benefits.
1 -  They keep the airflow laminar and reduce turbulence eddies than can alter the pressure at the fuel exit points in the carb throat.
2 - The ramming effect at high air speeds, provides a bit of compression on the air mass (large cross section narrowing to small cross section), which makes more oxygen available during combustion.  A slight supercharging effect.
Air filters of any type, introduce turbulence as the air passes through it.  Placing it at the entrance of the V stack largely negates benefit number one.
Filter media at the bell mouth actually reduces the cross sectional area of the bell, thereby negating benefit number two.
Passing large amounts of air through a small restriction increases the pressure differential on either side of the restriction.  With the pressure differential, comes resistance in the form of drag on the air mass.  To reduce the drag effect from the air filter, the media should be as large as possible and many times the cross sectional area of the carb throat.  The tiny holes in the filter media don't flow as well as a large one, because of circumferential boundary layer drag effects.  However, providing millions of small holes, allows each to flow at very slow rate.  This is rather the equivalent of have one person lift 300 lbs. or 100 persons lifting 3 lbs. each.
At the risk of sounding like a stock purist, which I am not.  I will point out some features often over looked on the SOHC4.  Using the CB550 for example, you will find a large chamber where air enters and is met with a large surface area filter.  This area is far larger than the venturi cross sectional area of the carbs.  After filtration, the air moves to a plenum chamber with exits to the 4 carbs,  Each, plenum to carb coupler is formed out of rubber in the shape of...
a short velocity stack.  This stack is really too short to provide much compression effect of number two benefit above.  But, it does provide some laminar flow benefits of number one.
You may not like the stock arrangement looks.  But, you can't deny that Honda got the engineering right, a large filter before the carb entrance and flow straighteners at the carb entrance.
Honda was trying to offer best performance with engine longevity.  This is a trade off proposition.  Racers trade off longevity with power gains for the short haul.  Because they go fast, racer bikes have the eye allure.  If you have a racers budget to replace engines or engine components, use velocity stacks.
One last point about the filter-at-the-vstack bell.  As filters block dirt, they become more restrictive.  A small area filter will need more frequent maintenance than a large area filter flowing the the same volume of air, because blocking the particles further restrict air flow.  This will, of course, depend on an equivalent air particulate density provided to each filter type, large area or small.
Having said all that.  I will support what Fred Said.
Since there are so few real engineers in the bike building arena, the cool factor is what will sell.  Just don't provide any test data.  Show them a cool bike with your shiny stacks gleaming in prominence. (Polished aluminum on an all flat black cafe bike, for example.)  With proper photography, you'll sell a bunch of them.
P.S. I wish I had your solid modeling skills! :o
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #16 on: September 19, 2007, 11:05:23 AM »
Good info, and yes, most of them were in the back of my mind already.
I had another, more practical idea (actually, a couple), but they aren't as 'cool looking'.
Think I'll CAD em up anyway, see what I see.
No.
Offline Jonesy
  • Shop Rat
« Reply #17 on: September 19, 2007, 11:47:36 AM »
Didn't Honda sort of already provide the best of both worlds with the CB750's airbox design? You have a very large area filter in the lower case, with rubber velocity stacks on the carbs in the upper case...
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #18 on: September 19, 2007, 11:55:13 AM »
Yes, yes, I'm well aware of the virtues of the stock airbox. I'm just looking to improve it a bit.
Next design going up is based on the stock airbox, but with improvements.
So maybe the honda stock box is "really good of both worlds", but I think we can do a little better...
No.
Offline DarkRider
« Reply #19 on: September 19, 2007, 12:26:05 PM »
Now...heres me just throwing a random idea in here...mostly from after looking at the 83 Interceptor my roomate just picked up (Yes this is now a 3 Interceptor home lol two are mine and the 83 is my roomates) i seen how the carbs are laid out in it since the airbox is off at the moment...now couldnt someone modify the air box on the CBs to allow the use of Vstacks on the carbs but place the filters at the intakes of the box? So now you wind up with a pressureized airbox with filters at the intakes of the box plus gain the benifits of the Vstacks feeding them clean air in the process.
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #20 on: September 19, 2007, 12:45:39 PM »
Thats what I am currently working on, but with a ram air system as well.
« Last Edit: September 19, 2007, 12:51:50 PM by mlinder »
No.
Offline dusterdude
« Reply #21 on: September 19, 2007, 12:50:03 PM »
damn,this is cool
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline tsflstb
« Reply #22 on: September 19, 2007, 01:09:09 PM »
I've wished somebody would make more of these "breadbox" type filters.  You get the advantages of a large filter and still get rid of the stock airbox for the racy look.  There were some better looking versions than in this picture, but the same basic idea.
This looks like where you're headed.  You could probably design it to use one of those flat cartridge type filters (or K&N equivalent) from a modern motorcycle.
Cool designs.  You can really whip those out quick.  I like the idea of pressurizing the box somehow.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #23 on: September 19, 2007, 01:20:32 PM »
Well, I figure if you are going to have an equalizing airbox, you may as well find a way to pressurize it...
No.
eldar
« Reply #24 on: September 19, 2007, 01:44:41 PM »
If you connect the stacks with hollow tubes, that will equalize it as well. As for pressurising it I am not sure that you can make enough pressure in the small space without a turbo on it. At least not without other modifications to the layout of the bike. You could swap in a smaller oil tank and relocate it thus freeing more space. Another concern is air temp. You want cool air,not air off the engine. Otherwise you will not gain much  since warm air is not as dense. Now maybe you could extend the stacks into the open space and have them terminate into an airbox that could maybe be hidden  by the sidecovers?
