Author Topic: CB750 Motor rebuild... for dummies  (Read 256877 times)
Re: CB750 Motor rebuild... for dummies
« Reply #25 on: January 01, 2008, 03:06:21 PM »
Hey Steve, dont forget the 2 screws under the breather cover (the little triangle cover on top of the engine in the center) - take cover off and remove the 2 screws before removing the valve cover.
Looking good,
Andy
legendary
« Reply #26 on: January 01, 2008, 03:29:58 PM »
Answers ;
jsaab2748-  "Good Screwdrivers" are in the eyes of the beholder. I stood in SEARS today and ultimately
                  decided that I probably wasn't looking at any "Good Screwdrivers".  Whose do you like?
Terry - Your parts list made me smile. That is the kind of help I need....Specific!
          Gasket set- is no where near as useful as "Get the Cycle X gasket set!" Thank you!
Gordon- Probably good advice on the studs... but I am going to wait until the engine is apart that far and
             weigh the options. If I replace them we are going to chat a lot more!  If I needed that I would be
             willing to send that job out.
754-  There are several decent machine shops near me- any idea what a tapered bore check should cost?
         Valve job?  I'd like to cross that bridge when I get to it. When I post a pic showing the valves point them out.
          Yes- I am serious! ;D
jevfro- Follow along and try to learn from our mistakes... that is what this thread is here for. If you need a
         specific pic let me know.
All- Great discussion on removing studs- and I will refer back to it. I am soaking this up like a sponge.
      I am focusing on what is on my plate at the moment... I can see there are differing schools of thought
      hopefully the engines internals will make it clear which way we need to go.
Offline Patrick
« Reply #27 on: January 01, 2008, 03:40:08 PM »
A tool I find useful during teardowns is a rubber mallet or dead blow hammer. It can be real helpful to break loose old gaskets.
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
jsaab2748
« Reply #28 on: January 01, 2008, 03:49:36 PM »
Once you get the valve cover off, things will get interesting. Just as a suggestion, keep everything organized as sub assemblies in a way that illustrates how all the parts go together when you are ready to re assemble. Mark things as right/left or front /rear if it helps. Keep associated bolts in thier respective holes of sub assemblies that you have taken out along the way. When it's time to clean sub assemblies, work with one thing at a time and set it back aside in order. It keeps things from getting lost and is a lot easier than trying to figure out which bolt goes where, while sorting thru a coffee can full of bolts. ??? You'll have your own style I'm sure,
I only suggest this cause' I'm remembering my first 750 top end
rebuild in '74 when I was 17.  ;D It actually ran when I got done,
AND I didn't even have any "extra" parts left over. P.S. The best screwdrivers are mac, snap on, cornwell, S&K etc. Others like craftsman are ok I think. Problem is the cheepies don't have hardened tips and will deform both themselves and the screws.
Please note MHO..
« Last Edit: January 01, 2008, 03:56:08 PM by jsaab2748 »
legendary
« Reply #29 on: January 01, 2008, 03:51:21 PM »
Andy750,
               check these out:
The offending screws
Handled....valve cover off. No noticeable gasket adhesion issue ...with all the screws removed. :-)
This is why I always ask before applying force.
This is my valve train...looks nice and clean. Cam chain isn't sloppy. Pleased with this... looks good so far.
That was probably 15 minutes from asked- answered, valve cover off. Took longer to load up the pics. ;D
legendary
« Reply #30 on: January 01, 2008, 04:27:10 PM »
"Once you get the valve cover off, things will get interesting."
jsaab,
         this has me thinking.... have you ever seen a plastic tray made specifically for keeping v8 engine internals organized during a rebuild.  Might be nice to have on of those for a CB750......hmmmmm.
Appreciate the advice on keeping the parts organized and on the screwdrivers. As you'll see from my last post I am at the valve train. I am working 12 hr shifts the next 4 days so next progress will be Sunday.
New Question for Sunday: Any advice on removing the cam chain master-link or is it pretty self-explanatory??
Offline scunny
  • don't call me expert
« Reply #31 on: January 01, 2008, 04:33:56 PM »
the chain wont have a link. just undo the 2 cam sprocket bolts then you can pull the cam away from the sprocket. make sure to tie something to the cam chain cause you don't want to drop it down the tunnel
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline jreich
« Reply #32 on: January 01, 2008, 04:51:33 PM »
Someone quite awhile back had mentioned a good method for keeping bolts/nuts organized as to where they should go upon rebuild. Draw out on cardboard each section that you are working on. Then poke the bolts through the cardboard in their respective positions. If then needed, screw the nut on the other side.
I know that on my first bike tear down, I labeled zip-lock bags for my bolts/nuts, and even then didn't get everything in the right hole the first time around.
Offline dustyc
  • I don't know why anyone would call me an
  • 1977 CB750K
« Reply #33 on: January 01, 2008, 04:54:36 PM »
When I take something apart, I grid a piece of cardboard with 1" squares, then poke holes at all the line intersections and write front on one edge.  Then as I disassemble whatever it is, I put the screws in the cardboard in a way that makes sense.  If it has washers or nuts, I put them on the front or back as called for.  It makes putting things back together exactly the way they came apart very easy.
I do it because some screws end up with a burr that will only match the hole it came from and will be a pain to put in a different hole or worse, damage it.  Just my observation and how I do it.  I have hundreds of cardboard grids of various sizes with holes that I tend to reuse.  Typical size is under a foot square, so they can fit in a gallon ziplock.
jreich posted as I was typing.  I'm glad to see someone else has a similar madness.
« Last Edit: January 01, 2008, 05:26:31 PM by dustyc »
1977 CB750
Offline jreich
« Reply #34 on: January 01, 2008, 05:17:08 PM »
Dusty,
You're probably who I originally got the idea from!
Cheers
JD
« Reply #35 on: January 01, 2008, 06:24:01 PM »
Measuring cylinders..
IMO, it pretty tough to measure these yourself. Even when I was selling pistons but not boring, I usually sent customers to the engine shop to get them checked with a bore guage.. and guess where it will go if it needs boring?
The problem is accurate measurement is time consuming with a telescoping guage and mike, and a bit much for trhem not used to it. Checking for taper & out of round.
I am not much for honing it when it is wore over limit and spending the price of a gasket set and rings, plus all the labour to do 1/2 a job that wont last a long time.. Or lapping valves when they really neeed cutting and valves ground..keep in mind there is a bit of power to bew picked up in a good muti-angle valve job..
Just my thoughts.. for all the time and cash involved, lets do it right..
jsaab2748
« Reply #36 on: January 01, 2008, 07:38:49 PM »
+1 on dustyc's last post. I've done/still do use that method when donig automotive engine work. I rebuilt a 302 Ford engine(reassemb.
led) six months AFTER I took it apart. But I digress...I'll quit rambling and let others post now :)
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #37 on: January 01, 2008, 10:32:29 PM »
i have a few rebuilds in progress: a cb750 stock, cb550 stock, a cb550/650/750 718cc combo, and a cb350T. i'll take as many pics as possible and contribute if it won't be cluttering the original topic makers' progress. if so, i'll start a separate thread if it will help people.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline smack doogle
« Reply #38 on: January 02, 2008, 12:17:38 PM »
Okay, sorry for the delay in getting pictures to you all.  After I got the engine out I took the valve cover off.  Like it was said above, be sure to remove the breather cover and loosen the two screws under that.  That's all of them.  Mine were on tight but not to bad.  No heads were stripped but I don't plan on using these again anyways.  I'll be going to ebay for the nice stainless hex head bolts.  After I got the cover off I read and re-read numerous times (in the manual provided here of course) how to remove the rockers and cam shaft.  One discrepency in the manual is the number of bolts it says are holding the rockers to the big pin.  The manual says one but I found there were three for each rocker.  Good thing I took out the bolts before I started driving out the rocker pin.  I was very careful just to tap the pin out and once I got it to move a little it slid out on the oil that was still in there.  Very simple but once again I took my time and did it nice and slow.  Once I got the rockers off I went to work on the camshaft.
You quickly realize the camshaft isn't going to come right off even with the cam chain adjuster off so I read the manual and searched here.  I found you must remove the sprocket and the chain will come off.  Low and behold the chain came right off as soon as the sprocket was off.  The camshaft slide right out and it shows no wear on the lobes at all.  I put the sprocket back on the camshaft and put that away for safe keeping along with the rockers which I reassembled and put in labeled zip lock bags for safe keeping, all hardware included in each bag.
What's my problem?  I'm from Wisconsin, that's what my problem is.
« Reply #39 on: January 02, 2008, 12:27:05 PM »
Next up was the head.  I was very curious as to what the pistons looked like so I read and re-read the manual once again and it seemed pretty easy.  Just be careful to loosen according to the manual.  I didn't need pry and beat it up to get it to move once all the nuts were off the studs.  I just bear hugged the engine, lifted the whole thing off the stand and wiggled and shimmyed and slowly but surely it slid off the studs.  I don't plan on replacing the studs.  It sounds like a lot of work and big chances made if not done correctly.  The head off the cylinders look pretty dirty.  Not to bad I guess but I haven't seen enough in my life to really tell good from bad.  All I know is that there aren't any holes in them so that's a plus.  Them I took a peak at the valves.  WOW, those look horrible!!!
So, I read and re-read the manual on valve removal.  That doesn't look easy, it seems they use a big C-clamp in the manual to compress the spring.  I might need to study hard and take a minute before I tackle the valves.  Next step, either split the case (seems pretty simple, just lots of bolts to loosen) or the valves.  Don't know yet.  This was enough for one day.
Heres the pistons
« Reply #40 on: January 02, 2008, 12:33:55 PM »
Heres the valves
#1
#2
#3
#4
Not to pretty
« Reply #41 on: January 02, 2008, 12:38:47 PM »
I think I'm gonna take a break on engine work the next few days and switch it over to sanding down the frame and swingarm.  My head hurts and sanding isn't to mentally taxing.  If anyone in Mass. needs some sandblasting done Hanscom AFB skill center has a sand blaster, DIY for $5/hour.  Just throwing it out there, oh, I can get you on base if that's a problem.
How you coming Legendary?
Offline markb
  • When I finish my current project I might be a
« Reply #42 on: January 02, 2008, 01:47:31 PM »
I picked up a valve spring compressor at Sears for about $20 that works just fine.  They've got a couple for about $80 that didn't look like they would work any better if you decide you want to pull the valves out yourself.
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Offline Honda?
  • Made in the Midwest
  • BEER!
« Reply #43 on: January 02, 2008, 02:25:58 PM »
Why didn't you seperate the head from the cylinders? The HG comes with the Cycle X gasket kit anyways.
Oh and I'm lovin this thread! I'm rebuilding my engine too but I won't be splitting the case.
My progress to this point...
I have a 1970 CB350 SS, 1988 NT650(Hawk GT), 2004 BMW R1100S
« Reply #44 on: January 02, 2008, 02:31:24 PM »
Ha ha, I guess SD hasn't noticed that the cam towers have to come off to remove the 6 rubber "pucks" that hide the four 6mm bolts that secure the head to the cylinder block! No biggie mate, and don't start pulling out valves until you get back to us, you may not need to! Cheers, Terry. ;D
« Reply #45 on: January 02, 2008, 02:47:51 PM »
 :o  You mean there's screws under those rubber thingies?  I'm gonna go check that out.  That would make sense and valve removal and stuff a WHOLE LOT EASIER.  See, that's why me and Legendary came here and decided to put our rebuild together.  Already I feel warm inside with knowledge.  The warmth might be from the few bloody marries I've had this afternoon  ;D
Thanks guys.  I'll post once I investigate this and have some more pictures.
Offline Honda?
  • BEER!
« Reply #46 on: January 02, 2008, 03:03:33 PM »
Haha this is my first rebuild too but I had to find those pucks because one of em was the cause of the oil leak I was looking for.
Just cross your fingers and hope you dont find anything like this anywhere!... :(
« Reply #47 on: January 02, 2008, 03:19:25 PM »
Ooo-er that's scary, and brings back memories best forgotten.......................... ;D
Offline Honda?
  • BEER!
« Reply #48 on: January 02, 2008, 03:43:41 PM »
So since this is an engine rebuild thread lets get a noob question of mine out of the way.
Why do you have to hone a cylinder and replace piston rings? What happens if you dont?
Good source to buy rings? and maybe a DIY honing page? (I'm sorta at this point in my engine rebuild.)
And while I'm here.
« Reply #49 on: January 02, 2008, 04:33:31 PM »
Here you go mate:
http://cgi.ebay.com/ebaymotors/FOUR-New-Honda-Piston-Ring-Sets-CB750-CB-750-Std-Rings_W0QQitemZ170182540057QQihZ007QQcategoryZ35594QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I bought a set, and they look fine. Your pistons though, are looking close to "bin quality". Before you buy any rings, you need to measure the "piston to bore" gap with a set of feeler guages, if you've got more than about .004 gap, don't spend any money on rings, take it to a shop and get them to measure the cylinder bore to see what's worn out. (pistons wear on the "thrust faces", and cylinders "oval" with wear) If it is, you'll need to get them bored to 1st over size and buy new pistons and rings. Cheers, Terry. ;D
