Author Topic: "INSPIRATION GALLERY "  (Read 2388756 times)
Offline crazypj
  • I'm brill, me
Re: "INSPIRATION GALLERY "
« Reply #9250 on: July 03, 2013, 01:06:27 AM »
Never seen a V-twin with curve like that before, impressive as Phoenix is around 6,00ft
 Should make a fair bit more at sea level
Not very practical power curve for any sort of street bike though, really needs to be turning 5k before it runs right?
« Reply #9251 on: July 03, 2013, 01:11:19 AM »
I bet its not on pump gas either....
Offline Slow M
« Reply #9252 on: July 03, 2013, 04:43:52 AM »
Pump gas, street ridden on weekends when the rider doesn't broil in the Phoenix heat, Power on a 5,000.
Best,
B
Offline crazypj
  • I'm brill, me
« Reply #9253 on: July 03, 2013, 11:51:14 AM »
Must make life pretty 'interesting', every red light a drag race  ;D
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
« Reply #9254 on: July 03, 2013, 12:16:06 PM »
One step closer.
Just waiting on my bore gauge and Mitutoyo digital calipers to measure for crank bearings, then I can finally start making progress on the engine.
« Reply #9255 on: July 03, 2013, 12:16:35 PM »
Cb550 gulf thread of dimitri
Offline Godffery
  • Godffery's Garage
« Reply #9256 on: July 03, 2013, 04:30:22 PM »
Now THAT'S one BEEFY 550 swingarm Dude!
Online Tintop
« Reply #9257 on: July 03, 2013, 05:05:59 PM »
+1 just hope that chain clearence was checked.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline Slow M
« Reply #9258 on: July 04, 2013, 08:54:26 AM »
Sorry, misunderstood your question. No, if you look at the chart, you'll see that it produces roughly 80 lb/ft @ 3,500. I'd say that's a nice mid-range starting point. It's likely not as 'peaky' as you'd expect it to be. One of the exercises has been to increase the area under the curve,
Best,
B.
« Reply #9259 on: July 04, 2013, 09:12:08 AM »
I dont care what anyone likes/dislikes on here, but 90 HP per litre of pushrod motor sounds good to me..
Offline crazypj
  • I'm brill, me
« Reply #9260 on: July 04, 2013, 05:05:37 PM »
...........particularly one that isn't spinning at 9 grand, huffing NOS or compressor of some sort
« Reply #9261 on: July 04, 2013, 06:15:09 PM »
I have never hear of an MJP dyno. It would be interesting to compare that figure to what is achieved on a Dynojet 200 or 250 (the industry standard)
Offline crazypj
  • I'm brill, me
« Reply #9262 on: July 04, 2013, 06:55:50 PM »
Offline Dimitri13
  • 1974 CB550K
« Reply #9263 on: July 04, 2013, 10:32:30 PM »
One step closer.
Whoa thanks for the plug Frankenstuff!
The brace clears everything. The shop did a local SOHC4 member, boogiedude's, first, as the test mule. No clearance issues whatsoever and he's been running it for over a month.
Offline Slow M
« Reply #9264 on: July 05, 2013, 11:32:27 PM »
Post removed.
Apologies, on a personal level, for assholish behavior, and to the group, for sullying an otherwise excellent thread.
Best,
B.
« Last Edit: July 06, 2013, 06:32:43 PM by Slow M »
Offline Ollies930
« Reply #9265 on: July 06, 2013, 12:44:41 AM »
This particular MJP dyno reads exately the same as a Dynojet 200/250 models using SAE correction factor with smoothing set on 3. The owner of this MJP dyno ran a bike on his MJP and then went down the street and ran the bike on several Dynojets at MMI and the MJP read out right where the Dynojets were. FWIW
Oliver
« Last Edit: July 06, 2013, 12:48:04 AM by Ollies930 »
« Reply #9266 on: July 06, 2013, 09:01:15 AM »
Oliver
Thanks...that's the info I was looking for.
« Reply #9267 on: July 06, 2013, 02:10:13 PM »
i was waiting for you to say that ,mike  ....     ;D ;D ;D
ok boys ... stop ...  now .... not one more #$%*ing post
     not ... one .. more
you all have made your point , info has been shared
  #$%*ing let it go and move on
« Last Edit: July 06, 2013, 02:28:17 PM by Spikeybike »
« Reply #9268 on: July 07, 2013, 04:04:01 AM »
« Reply #9269 on: July 07, 2013, 04:08:15 AM »
Offline Godffery
  • Godffery's Garage
« Reply #9271 on: July 07, 2013, 08:13:59 AM »
Thanks Super Frank'n Dude, that's much more Inspirational then beating dead horse banter!
« Reply #9272 on: July 07, 2013, 08:59:22 AM »
 ;D ;D ;D hey i still have that jacket ...somewhere  ;D
Offline Viktor.J
  • Breaking in the forum
« Reply #9273 on: July 07, 2013, 12:33:00 PM »
During a trip to Wrenchmonkeys in Copenhagen Denmark, some online friends found this CX500 - believe its called GL500 !?! in the US ?
I think it's really sweet except the tires and maybe (IMO) the low bars.
Please ! Take a look and give me feedback in my project thread, its much needed :)
http://forums.sohc4.net/index.php?topic=112745.0
Honda CB750 K2
« Reply #9274 on: July 07, 2013, 06:45:34 PM »
I think those might be CX500C models, the Custom version that was modified rather than the CX500 or CX500 Deluxe models.
The tank on the Custom is more teardrop shaped than the Deluxe which is what a lot of cafe racers like with the mild knee dents from factory.
Here's some photos of CX500 (Std and Deluxe), Some CX500 Deluxe or Std cafe bikes, CX650Turbos, and CX500 Custom
