Author Topic: CB750K4 - new update 28 June 2025- tachometer troubles  (Read 136003 times)
Re: CB750K4 - new updates 21 Apr 2025 - autopsy -non-charging bike
« Reply #300 on: April 21, 2025, 03:18:08 PM »
Anders replied with this:
"The blue wire with a red tracer is the ground side of the oil warning light."
« Reply #301 on: April 21, 2025, 07:18:41 PM »
So if I replace the stator what do I do with the OEM plug? Do I need to re-sleeve it with the new stator?
And what is the blue/red wire you see in the photo? Is that going into the OEM connector?? What’s it for?
Andy, isn't that wire actually green/red?? It's for the neutral switch under the motor, probably why it was included in the protective sleeve with the new stator wires. Since you will probably have to cut the new stator wires to fit the rubber block, you might as well splice the new wires to the old ones where Anders did before.
« Reply #302 on: May 02, 2025, 05:12:35 AM »
Thanks Scottly for the above message - there is a green/red wire that goes to the neutral switch under the motor - removed that with no issue but there is also that blue/red wire that came from the alternator area and I think its the ground for the oil switch. Either way as you suggested will splice the wires where Anders had done so to fit the new stator. Ricks Motorsports in NH is helping me as they sell replacement stators and have offered to fit it for me. Will update when I get it back on the bike.
« Reply #303 on: May 20, 2025, 03:01:09 PM »
Update!! Just received the rewound stator from Ricks Motorsports - with all new wiring, rubber connector and OEM connector - really impressed!
Now just to fit it
Rocks tested the reg/rectifier and that was not the problem
Offline newday777
« Reply #304 on: May 20, 2025, 03:04:53 PM »
Did Rick's say it was the stator failed??
Stu
My current rides
Prior bikes....
« Reply #305 on: May 20, 2025, 03:12:10 PM »
Yes they did
« Reply #306 on: May 20, 2025, 03:13:21 PM »
Mike called it
« Reply #307 on: May 21, 2025, 10:15:06 AM »
Looks good Andy.  Mind if we ask how much?
« Reply #308 on: May 21, 2025, 11:50:23 AM »
Yes of course! I shipped them the stator/alt cover and wiring and they
1. Rewound the stator by hand as the one on it was different than the R6 stator that they sell.
2 used new/spare grommets .
3. engineering dept ran the old regulator on test dyno for an hour and it held up just fine, no issues.
4. installed the whole thing in the cover with new wiring and connectors
Total price = $188
« Reply #309 on: May 22, 2025, 06:30:13 AM »
Total price = $188
That sounds fair, Andy.  I've never had one fail but good to know we have options.  Thanks
Offline newday777
« Reply #310 on: May 22, 2025, 06:43:21 AM »
Total price = $188
Steve
Do you have one of Anders conversions?
Stu
My current rides
Prior bikes....
« Reply #311 on: May 22, 2025, 07:16:35 AM »
Total price = $188
Steve
No.  But I've read of them with interest....
Offline newday777
« Reply #312 on: May 22, 2025, 07:22:30 AM »
Total price = $188
Steve
Part of the kit is the adapter plate behind the windings to fit the R6 stator to our covers.
« Last Edit: May 22, 2025, 07:24:52 AM by newday777 »
Stu
My current rides
Prior bikes....
Online HondaMan
« Reply #313 on: May 24, 2025, 11:23:18 AM »
Seeing this makes me flash on rewinding CB77 alternators, circa 1970s... ;)
« Reply #314 on: May 24, 2025, 11:55:52 AM »
It will be interesting to see the output. Hopefully we can see a comparison to stock.
« Reply #315 on: May 24, 2025, 07:17:12 PM »
Throws like 14.1 at idle Jerry...the headlight brightness never dips and stop and go traffic doesn't Darin the battery at all. Doesn't require energy to fire up the field coil so all battery power goes to the starter. The system works great.
Ok I installed the stator, connected the blue/red wire, alt cover and trans cover are back on...reg/rectifier all hooked up but...even though I took plenty of photos prior to disassembly back in October I didnt pay careful enough attention to where the 2 green reg/rectifiers hook up to - see photos - is #2 lead going to the neg battery terminal? And #1 lead?
Re-installing airbox tonight as had to remove that to access the wiring....
Thanks
Andy
Ok airbox on (thank you Joe!/Frankenstuff - taken me long enough to install!)….
Wow, nice! Good job Andy and Joe
The other ends of those wires shouldn't have been disturbed; the plug was disconnected from the reg to remove it. Chances are that one goes to battery plus and one goes to ground, as it's a shunt type reg.
So one green wire goes to Battery term + and other to ground such as where?
Thank you!
I have no idea where Anders chose to ground the charging system. ;D It might even be directly at the battery - terminal? In any case, they didn't need to be removed, and in the older pics the plug is visible unplugged and supported by the wires. You should be good to go.  ;)
PS When did Franken-Joe start making air-boxes? 8)
Yes....directly to the negative battery terminal.
Offline CycleRanger
  • No comment about being an
Yeah, that air box looks pretty sweet!
