Author Topic: Is it normal to have to adjust your idle as she warms up?  (Read 13386 times)
Offline Gordon
  • 750K1, 550K2
Re: Is it normal to have to adjust your idle as she warms up?
« Reply #25 on: May 14, 2009, 08:45:27 AM »
high idle cam on the choke..?
Yup.  If you have carbs with the fast idle cam on the choke and it's adjusted correctly.
Offline cb750fbomb
  • is by no means a
  • "No hope? See, that's what gives me guts!"
« Reply #26 on: May 14, 2009, 08:55:51 AM »
Where the heck is this? I've got a set of PD42A's in front of me and don't see how the mechanism would speed the idle
'77 CB750F2
“The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at or repair.”
Offline Gordon
  • 750K1, 550K2
« Reply #27 on: May 14, 2009, 08:58:10 AM »
If it's on there, you should see a cam lobe on the choke assembly arm that opens the throttle slightly when the choke is in the closed position.
Offline cb750fbomb
  • is by no means a
« Reply #28 on: May 14, 2009, 09:08:52 AM »
I see it and how it works. AWESOME more stuff not working as it should  :-\
'77 CB750F2
Offline martino1972
  • and still a expert welder,period...
« Reply #29 on: May 14, 2009, 09:16:25 AM »
 :D :D :D   Don't you just love those old hondas..... ;D ;D
Marti, I want you to know, I like you an awful lot, but guys have said far less and left wearing their drinks on their shirts.
http://forums.sohc4.net/index.php?topic=36933.0  (my bobber)
Offline cb750fbomb
  • is by no means a
« Reply #30 on: May 14, 2009, 09:34:38 AM »
It's not in front of me, but I remember seeing the same lobe on the 41B's on the bike. I wondered what that was for.
'77 CB750F2
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #31 on: May 14, 2009, 09:47:52 AM »
As long as we're confessing, not only do I IdleFiddle.  I also ChokeKnobKnock AND.... <deep breath> KickStart even though I have a perfectly good starter!
I need another shower!
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline cb750fbomb
  • is by no means a
« Reply #32 on: May 14, 2009, 09:49:11 AM »
What a pervdog  :o
'77 CB750F2
Offline heyjones
« Reply #33 on: May 14, 2009, 01:42:16 PM »
I had this idea to attach a rod to the adjustment knob so I could turn it easier... probably a horrible idea! I actually haven't had to mess with it in a while since the mornings have warmed up a bit, kind of found the sweet spot.
1976 CB750K
My Build Thread
Offline Frankencake
  • Yesssssss,
  • "I like the old junk"
« Reply #34 on: May 14, 2009, 01:54:06 PM »
Last winter I was at a junk chinese tool flea market thing.  I ended up buying a bendable ratchet extension mad from a spring.  With the correct screw welded to the end, it could stick out the side of the bike for easy access.  I have seen remote idle screws on other bikes.  I think it was a 360T.  They might work.  I just can't remember.
333:  Think "Shakeweight".
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« Reply #35 on: May 14, 2009, 02:03:29 PM »
sometimes I'm too lazy to fiddle with my idle and I'll sit at a light, lightly burping the throttle when it slows down too much.... probably makes me look like a tool.
« Last Edit: May 14, 2009, 02:08:38 PM by Industrial Cafe »
Offline Johnny5
    • CB350F build thread
« Reply #36 on: May 14, 2009, 02:12:40 PM »
It makes you look like a badass. Just make sure you snarl when you do it though, because if you're smiling or sitting there with some goofy grin, you will look like a tool.
;D
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
Offline Scrubs
« Reply #37 on: May 14, 2009, 02:15:32 PM »
I used to have the same problem as you constantly fiddling. Best way I found was to take her for a nice long ride
to get up to 'full' temp - then set the idle. I have never touched it since. syncing the carbs helped things too.
  • Like a well oiled
    • Undead Asphalt
« Reply #38 on: May 14, 2009, 02:18:30 PM »
quiet you!  ;D
  • Like a well oiled
    • Undead Asphalt
« Reply #39 on: May 14, 2009, 02:21:33 PM »
denial...
we're in a 7 step program here mister.
Offline Scrubs
« Reply #40 on: May 14, 2009, 02:36:51 PM »
Sorry.. It's difficult you know. I just had to take one day at a time - If I thought of stopping fiddling as a whole it
seemed overwhelming. I just got through by breaking it into smaller moments 'I will not fiddle today' I had
a relapse in '96 and beat myself up pretty hard - but now it's made me as strong as ever. Hang in there guys!
It can and will get better - I am living proof.
'Et Lux in Tenebris Lucet'
 John 1:5
 ;D
Offline Hush
« Reply #41 on: May 14, 2009, 03:07:33 PM »
When I stop to fiddle everyone stares! so I give them my "what are you look'n at" glare and they all pretend not to see me....
Offline Damfino
« Reply #42 on: May 14, 2009, 03:26:38 PM »
Thank GOD for this post!! As a relative newcummer to the CB750, I was afraid I was alone in the world of idlefiddlin'. I confess - the gentle warmups in the garage late at night - ever so lightly rotating my knob er, I mean screw, DAMN!! I mean thingy.....Oh what the hell, sign me on for a lifetime membership!
Your Message Here!
1976 CB 750
2014 CB 1100DLX
Charles Manson
Offline alltherightpills
« Reply #43 on: May 14, 2009, 04:14:13 PM »
Gents, I hereby confess to my gratuitous idle fiddling, kick starting, and throttle massaging.  Why say no when it feels so good to say yes.
78 550K
77 550K (in pieces)
71 500K0 (in pieces)
Offline MJL
  • Don't listen to me, I'm no
« Reply #44 on: May 14, 2009, 04:54:14 PM »
I kickstart,too! Makes me feel like more of a bad ass. I don't idle fiddle.  It was hard enough to get the idle just right, it's either too high or too low.
Offline Scrubs
« Reply #45 on: May 14, 2009, 07:07:17 PM »
I am undeniably guilty of that  :D
  • Like a well oiled
    • Undead Asphalt
« Reply #46 on: May 14, 2009, 07:09:20 PM »
i don't kickstart....
sorry guys, it goes eet-BWOOOM! and I like that.
Offline Gordon
  • 750K1, 550K2
« Reply #47 on: May 14, 2009, 07:23:00 PM »
It's okay.  Everyone has their drawbacks... :D :D ;)
Offline Skonnie Boy
    • What I do for a "living":
« Reply #48 on: May 16, 2009, 11:01:47 AM »
Testify, brother.  My starter started grinding gears a bit, so I just kick it all the time.  Somebody on here clued me in to the *throttle open/ignition off/two kicks* priming method, and it kickstarts even in the 30º range.  Plus, like idlefiddling, its another form of badassery.  Maybe.
Yee and/or Haw.
  • Like a well oiled
    • Undead Asphalt
« Reply #49 on: May 16, 2009, 11:15:13 AM »
We welcome you fiddlers and kickers here with open arms.
  If you've been lurking on the thread, and haven't posted the fact that you're an IdleFiddler or a a KickStarter, don't be afraid, were all friends here.
go ahead, it'll be liberating to admit to it.
