Author Topic: OPERATION BIRTH KONTROL  (Read 27840 times)
Offline rustrocket92
  • Mad Fabricator
  • Buster is in the Lab!
Re: OPERATION BIRTH KONTROL
« Reply #125 on: October 02, 2009, 02:48:06 PM »
I have been planning on get the whole seat covered but for right now it is going to be just foam. I figured I could get it covered this winter. Probaly a black or dark grey snap on cover with red stiching.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
  • Mad Fabricator
« Reply #126 on: October 03, 2009, 10:14:34 PM »
Put my Dyna ignition today and thought I followed the instructions pretty good and went to start it and it backfired thru carb #1. So I reversed the blue and yellow wires and it ran. So I started messing with the timing and It wouldn't run for CRAP! ( only spelled with 4 other letters ). So I look back at the carbs and found #1 cylinder was choked all time. I had to loosen the choke lever to get my Sync adapters to go in and had loosened it to much. So I tore the top loose enough to get the cap off and repair the choke plate. Then I found it would run. But only on #1 and #4 pipes 2-3 were cold. I had power to the coil but plugs 2-3 were fouled. I replaced all plugs and it fired right up. So tommorrow will be timing light and carb sync.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
  • Mad Fabricator
« Reply #127 on: October 15, 2009, 10:53:45 PM »
Timed and synced. Bike is pretty much ridable.So I pretty much ate nachos and drank beer on sunday. Hopefully get it off the rear stand tommorrow to do some burnouts. I still have to finish the kickstand but i think I have that covered.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline Zaipai
    • My Home page
« Reply #128 on: October 16, 2009, 08:49:20 PM »
That's awesome.. However where are the photos of the whole bike? Get some and post em before she gets dirty! It's very cool how the helmet matches the bike and just an awesome job all the way around! Good work!
Its my Avatar..
75 CB550F  |
  • Mad Fabricator
« Reply #129 on: October 16, 2009, 11:08:16 PM »
Thanks for the comments! I am going to try to get the bike off the stand tommorrow so I can a couple lil rides in this weekend and get the kickstand finished and painted. I called a friend of mine who is into photography and we are trying to find a good location to take some real pictures. But for now I am just hoping for a couple outside pics and mabye a burnout video.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
  • Mad Fabricator
« Reply #130 on: October 24, 2009, 06:04:03 PM »
The bikes off the stand, kickstand is on. I took it out of the garage and fired it up just to find the clutch was misadjusted. Pushed it back in adjusted clutch then backed out the door into the alley and fired it up again. Took a quick run down the alley and it seems front brake is draggin. So back to the garage. Got the front brake adjusted and back outside for test run. I went down thru town to the local tattoo shop and up and down a couple back streets. The bike seems to run and ride fine so far except for a couple minor set backs. Hopefully tommorrow we will run it up the highway.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
  • Mad Fabricator
« Reply #131 on: October 24, 2009, 06:10:07 PM »
« Last Edit: October 24, 2009, 06:15:58 PM by rustrocket92 »
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline Alan F.
« Reply #132 on: October 24, 2009, 06:24:05 PM »
Looks damn good out in the daylight, how's it sound?   Still planning that burnout video?
Cheers.
-Alan
  • Mad Fabricator
« Reply #133 on: October 24, 2009, 07:28:13 PM »
Thanks man. It's pretty loud. As far as the burn out vid I don't know now that I have gotten to ride it a couple times I am afraid I will break something.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline Alan F.
« Reply #134 on: October 24, 2009, 08:23:08 PM »
It's good to know I'm not the only one who felt like that. I'm a squid at heart though... I wonder if some of IndustrialCafe's baffles would do the trick?
-Alan
Offline KB02
« Reply #135 on: October 25, 2009, 06:20:42 AM »
The bike looks awesome, but aren't those pipes going to reduce your lean angles in turns?
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
  • Mad Fabricator
« Reply #136 on: October 25, 2009, 09:41:00 AM »
As far as the pipes go yes I have already scraped one on the ground. I have several sets of pipes laying around so I am probaly going to make another set of pipes for it this winter.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline Beans
  • I play with grease every day.
  • 1975 cb550f
    • bean's place.
« Reply #137 on: October 25, 2009, 09:52:48 AM »
Bike look killer man.   love the colors and the pips look good too.   looks like they sound good. should make a vid so we can hear it run.
Keep it shinny side up.
Offline Zaipai
    • My Home page
« Reply #138 on: October 25, 2009, 12:42:07 PM »
Dang, you must be proud of that bike its killer man.. Good work.
Its my Avatar..
75 CB550F  |
  • Mad Fabricator
« Reply #139 on: October 25, 2009, 03:32:33 PM »
Thanks guys!
« Last Edit: October 25, 2009, 03:35:19 PM by rustrocket92 »
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline HedNut
  • Underwater Basket Weaving
« Reply #140 on: October 26, 2009, 06:56:18 AM »
GORGEOUS!  The whole package is killer... a BOTM for sure!
Offline j-conn
  • Federico Fabrizi
« Reply #141 on: October 26, 2009, 10:55:10 AM »
i kno u must have a little kids grin from ear to ear behind that helmet no matter how bad ass you look.  ;D ;D
1976 CB550
Member #7772
  • Mad Fabricator
« Reply #142 on: October 26, 2009, 01:32:34 PM »
Definetly have a smile on my face! ;D
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline Thor's Hammer!
« Reply #143 on: October 27, 2009, 04:34:18 AM »
Awesome build man!  I like how you laid out the harness to test it...I may barrow that trick when I do mine.
1978 Honda CB750F : 2005 Kawasaki ZRX1200
  • Mad Fabricator
« Reply #144 on: October 27, 2009, 09:18:51 AM »
Go ahead man it wasn't my idea. I read a post somewhere about laying out a wiring harness out like that so you could mark how long everything was to make a new one.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline Alan F.
« Reply #145 on: October 27, 2009, 12:35:00 PM »
I've worked for companies that manufactured wiring harnesses using that method.  It's nice and repeatable.
-Alan
Offline honda_jason
  • I have no idea what I'm doing
  • 1971 CB500
« Reply #146 on: October 27, 2009, 02:00:50 PM »
this bike is killer! i love it the more and more i look at it. awesome job!
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« Reply #147 on: October 27, 2009, 02:16:54 PM »
you could pick up one of those marvelous replica yoshi's Carpy is peddling for 400 bones.
« Last Edit: October 27, 2009, 02:19:23 PM by Industrial Cafe »
Offline sangyo soichiro
  • Tuck
  • ☢ the atomic playboy ☠
« Reply #148 on: October 27, 2009, 02:34:01 PM »
Nice job Rustr.
1974 CB 750
1971 CL 350 Scrambler
1966 Black Bomber
Too many others to name…
  • Mad Fabricator
« Reply #149 on: October 27, 2009, 03:45:25 PM »
Thanks guys! I still have to get the seat covered and a couple small things. But the bike is rideable and I like it!
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
