Author Topic: Main fuse blown  (Read 2477 times)
andy1976
Main fuse blown
« on: July 09, 2009, 01:37:22 PM »
Help I'm in the s*!t big time. I've been checking my bike over prior to this weekends trip away. Everything seemed fine until electrics went dead. I checked the main fuse, fine,connector blocks etc, fine, it turned out to be loose ground wire on the battery.
The trouble I'm having now is that when the bike starts and the rev's hit 2000+ rpms, it's blowing the main fuse, it doesn't do it when on tickover.
I don't know what to look for and I'm supposed to be going away tomorrow morning  :(
The bike ran fine until now.  ???
Thanks
Andy
Offline razor02097
  • Not a fool, just an
  • Yes its a Honda You got an F'in problem with that?
Re: Main fuse blown
« Reply #1 on: July 09, 2009, 02:07:59 PM »
whats "tickover"?
Check your battery with a multimeter to see if you are charging the battery and that its not hitting high voltages.
Also check under the front fuse panel to see if anything is up there too.
Project Rina
That is an inconceivably egregious transgression against my rudimentary concordance of socially shunned individuals.
andy1976
Re: Main fuse blown
« Reply #2 on: July 09, 2009, 02:13:42 PM »
Hi
I meant to say when the bike is running at idle (1000rpm).
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
Re: Main fuse blown
« Reply #3 on: July 09, 2009, 02:17:30 PM »
Had a similar problem on the KZ650. The bolt to the leads to the coil we're barely apart, and the damned thing would arc once you got a bit more juice headed up there, and it would short, and blow the main fuse.
Not saying it's the coils, but it's likely something shorting out that needs a little more juice going through to blow the main fuse.
No.
Offline 750goes
  • it will live
Re: Main fuse blown
« Reply #4 on: July 09, 2009, 04:07:09 PM »
do you have the correctly rated fuse in the fuse holder ???
andy1976
Re: Main fuse blown
« Reply #5 on: July 09, 2009, 04:10:03 PM »
The fuse I've been replacing is rated 15amps
Offline razor02097
Re: Main fuse blown
« Reply #6 on: July 09, 2009, 04:20:03 PM »
Isn't the main fuse 30A?  The others are 10A
Project Rina
Re: Main fuse blown
« Reply #7 on: July 09, 2009, 04:27:56 PM »
No! The main fuse is 15A (CB750, CB550).
Offline Patrick
Re: Main fuse blown
« Reply #8 on: July 09, 2009, 04:33:16 PM »
And the others are 7 amp.
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline razor02097
Re: Main fuse blown
« Reply #9 on: July 09, 2009, 04:42:46 PM »
Woah ok ok... didn't see model of bike...  mine has 30A main and 10A at handlebar fuse panel thats why I asked  :P
Project Rina
andy1976
Re: Main fuse blown
« Reply #10 on: July 09, 2009, 05:33:57 PM »
I forgot to put which model my bike is in my first post (oops!), it's a '76 CB750F1.
One of the guy's on the UK site reckons my regulator is faulty, How do you test it using a multi meter? I've not done this before.
Thanks
Re: Main fuse blown
« Reply #11 on: July 09, 2009, 05:46:25 PM »
Eh...and which bike would that be  ::)
Offline razor02097
Re: Main fuse blown
« Reply #12 on: July 09, 2009, 06:53:18 PM »
I was talking about the 30 amp fuse element on the starter solenoid.  I thought that to be the main fuse he was talking about... Jesus...
Project Rina
Re: Main fuse blown
« Reply #13 on: July 09, 2009, 08:52:35 PM »
You have lost me....what 30amp fuse on the starter solenoid? I asked a simple question -which bike are YOU referring to??
And my name isnt Jesus..its Andy  ::)
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
Re: Main fuse blown
« Reply #14 on: July 09, 2009, 09:37:53 PM »
Hi Jesus.
No.
Offline the technological J
  • deliciouso!
Re: Main fuse blown
« Reply #15 on: July 09, 2009, 09:52:51 PM »
if u end up in a pinch for a new regulator... theres a thread about one for a ford truck or another one from radio shack.. for a fraction of the price...and might be more readily available
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline razor02097
Re: Main fuse blown
« Reply #16 on: July 10, 2009, 04:13:22 AM »
Andy I have a 650 I wasn't calling you Jesus I was saying that at then end with a defiant tone.
« Last Edit: July 10, 2009, 06:35:22 AM by razor02097 »
Project Rina
Re: Main fuse blown
« Reply #17 on: July 10, 2009, 04:31:37 AM »
You need to check voltage at battery under all conditions before condeming anything. It could be just something vibrating into a ground contact when reved.
Generator voltage would have to be way high to blow fuse cos of overcharge BUT the resistor on the reg could be shorting as it switches in, Never had one do that but nothing is impossible with age
