Author Topic: What's with the damn oil leak? SOLVED!  (Read 3865 times)
Offline grumpy
  • ..... '73 750K3 .....
« on: July 15, 2009, 08:13:32 PM »
I changed the oil on the K3. New filter & gaskets, too. Same as always.
Put it back together revved it a few times & noticed oil dripping from the filter housing.
Checked the oil filter bolt for tightness, wiped off the oil, & revved again.
Same damn drip.
Drained the pan, pulled the filter, cleaned it all out - checked for debris that would interfere w/ the seal - nothing. Replaced gaskets (again) with another new set.
Same damn leak!!!!!!
It's oozing out from where the filter cover meets the crank case.
WTF!??!??!
What's the torque spec on the filter bolt?
« Last Edit: July 16, 2009, 07:14:23 PM by grumpy »
Offline Johnny5
    • CB350F build thread
Re: What's with the damn oil leak???!!
« Reply #1 on: July 15, 2009, 08:16:40 PM »
I hate oil leaks.
Is the spring in tact? New rubber oring?
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
Offline grumpy
« Reply #2 on: July 15, 2009, 09:12:21 PM »
Yep. Spring is fine. The infamous washer is there.
O-rings replaced & re-replaced.
It's a significant friggin leak.
What the smurf did I jack up just changing the friggin oil??!?!?
Offline Johnie
« Reply #3 on: July 15, 2009, 09:16:00 PM »
Try putting in your old filter gasket and see if it still leaks.  Are you using OEM or aftermarket filter and gasket?  There is a post on here in the last couple weeks about an aftermarket gasket leaking on the filter housing.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline grumpy
« Reply #4 on: July 15, 2009, 09:28:49 PM »
You might have seen my earlier post from a few days ago when I first noticed the leak. Today was the first chance I had to try & fix it.
The O-ring that got replaced was a K&N and it was fine (but it went out with the garbage yesterday).
The first replacement O-ring came w/ the K&N oil filter.
The re-replacement that's in there now I got from North City Honda today. I think it's an Emgo.
I measured all the O-rings I have here K&N, Emgo, & the one that's on there now. They're all spec thickness: 4.5mm
Offline Johnie
« Reply #5 on: July 16, 2009, 05:38:21 AM »
There must be something different from the one you took off and the one you put on.  The sizing might be there, but is the rubber consistancy there?  I mean does it crush the same?  If the new gasket consistancy is lighter, oil may be able to leak past under pressure.  If it was me, I would buy a OEM Honda filter gasket and give it a try to be able to at least eliminate that idea.  Heck, if I had saved my used one I would sent it to you.  Like you, I toss them.  I hope you get it sorted soon.
Oshkosh, WI  USA
Offline Johnny5
« Reply #6 on: July 16, 2009, 06:11:38 AM »
Maybe there's two of those little rubber gaskets stuck together when the last filter was installed?
1971 CB350
1973 CB350F
Offline grumpy
« Reply #7 on: July 16, 2009, 06:55:13 AM »
Yeah - I thought of that, too.
I'm gonna call the Honda dealer today & see if they have some.
No but I thought of doing that myself. Don't think I could jam 2 into the slot, though.
grrr...  >:(
This is REALLY annoying.
« Last Edit: July 16, 2009, 07:01:07 AM by grumpy »
Offline the technological J
  • deliciouso!
« Reply #8 on: July 16, 2009, 07:07:07 AM »
i got some kinda high temp copper sealant that i used on my intake manifolds and it holds up well... got it an advanced auto or something... id put that on it tighten her up and let it sit till the next day... it should hold up to temp as well as the rubber... at least u should know its sealed... good luck
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline grumpy
« Reply #9 on: July 16, 2009, 09:49:07 AM »
I thought about trying a sealant but I don't want to change it getting into the oil & then into the engine. After seeing that clogged oil screen I don't think I'll ever use any kind of sealant ever again!
Offline 1974CB750rider
  • 1974 CB750K4 46000 miles
« Reply #10 on: July 16, 2009, 03:06:33 PM »
I ordered a Fram filter through Autozone and it works fine plus its only 4.99. I change my oil real often and change the filter everytime despite what the Honda manual says.
People with closed minds cannot learn new things.
Offline 75750SS
  • 75 750F, 2010 Concours ABS
« Reply #11 on: July 16, 2009, 03:55:59 PM »
I had the same problem with the EMGO filter.  Switched to a FRAM CH6009.  The o-ring is a tiny bit thicker with the FRAM and hasn't leaked for the last 4 oil changes.
Offline Johnie
« Reply #12 on: July 16, 2009, 05:48:19 PM »
Geez...am I like the only guy here that uses the Honda OEM filters?  ;D
Oshkosh, WI  USA
Offline scubes
« Reply #13 on: July 16, 2009, 06:06:17 PM »
I can definately vouch for OEM Honda filters. Change em at least once a year on both my bikes and yet to have a leak.
1981 CB750C
1974 CB550
1979 CB750F
1982 CBX
« Reply #14 on: July 16, 2009, 06:23:17 PM »
I used to use FRAM and EMGO all the time....then the dreaded filter housing oil leak due to crappy O-rings.....now only Honda OEM...quality is far superior!
cheers
Andy
Offline grumpy
« Reply #15 on: July 16, 2009, 07:13:53 PM »
Went to the Honda dealer and got an OEM ring.
It was visibly thicker than the K&N. Much softer, too.
It measured out to 4.5mm thick versus the 4.2mm Emgo.
No more leak!
 ;D
Cripes. Do parts mfgrs really have to be that cheesy to where we have to go OEM for the simplest things?! Can't they get anything right?
« Last Edit: July 16, 2009, 07:16:06 PM by grumpy »
Offline Johnie
« Reply #16 on: July 16, 2009, 07:34:56 PM »
No more leak!
 ;D
Not that they can't get it right, they just have to try to do it cheaper I guess.  You have just solidified my continual use of OEM parts.  Glad you got it taken care of.  A lot of dinking around that you should not have had to go through.
Oshkosh, WI  USA
