Author Topic: Rebirth of paulages' cb735  (Read 129765 times)
Offline Doctor_D
Re: Rebirth of paulages' cb735
« Reply #350 on: July 01, 2010, 10:07:19 PM »
I keep trying to remind myself to subscribe to this thread... which I've now done.
Good luck Paul, we're all rooting for your build.
Take care,
David
1978 CX500
1971 Norton Commando
Offline Raef
« Reply #351 on: July 02, 2010, 01:59:11 AM »
That sucks.......I think If I had to trim such a thing I think I would sandwich it between a couple pcs of ply wood with the right size hole and gently use a drum sander, dremal or drill press...
But  with all that you have going on, with this awesome build, I would be looking for them to send me the right one
Mark
traveler
« Reply #352 on: July 02, 2010, 06:46:40 AM »
Seems damn near impossible to get people to do what they say they will these days.
Body men are the worst...followed by engine guys.
~Joe
Offline Little_Horse
    • My cafe build
« Reply #353 on: July 02, 2010, 07:39:07 AM »
~Joe
followed be welders, those guys are scum  ;)
"Little Horse Cycles" facebook page: http://www.facebook.com/pages/Little-Horse-Cycles/185809474769493
LHC is my start up cafe racer shop specializing in custom parts, bikes, restoration and recreation
The 500 builds http://forums.sohc4.net/index.php?topic=64250.0
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #354 on: July 02, 2010, 12:01:46 PM »
Cometic have a new one on the way, and suggested I use a dremel atop the bores to try cutting the old one. This makes me a little norvous, so I'll likely try something else.
Ring gaps have all been filed to .010"-.012". Gonna start putting it back together this afternoon!
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline paulages
  • 1976 cb735
« Reply #355 on: July 02, 2010, 04:42:34 PM »
I know how you guys like pictures and all, so I'll spice up the thread a little after all that boring math and whining...  ;D
head gasket cut to 66mm holes, re-annealed, and coated with copper gasket spray:
ready for assembly...
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline paulages
  • 1976 cb735
« Reply #356 on: July 02, 2010, 04:58:38 PM »
the goods:
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
traveler
« Reply #357 on: July 02, 2010, 06:20:19 PM »
Paul, in all seriousness....I think it will be fine.  Go ahead and put it together.  it'll hold together just fine.  Your attention to detail is so far above others, that you won't have a problem.  Go ahead and run her with the 750 carbs.
just my .02
~Joe
Offline paulages
  • 1976 cb735
« Reply #358 on: July 02, 2010, 06:27:25 PM »
just my .02
~Joe
thanks, joe. it's going together already.. pistons and cylinders are installed. found TDC and attached the timing wheel. i had to disassemble the valves on the #1 cylinder to remove clay from when i was checking clearances, and the exhaust valve spring retainer flew across the room. i only have a half hour or so left to work tonight, so i guess the head isn't going on tonight. tomorrow, i hope...
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline paulages
  • 1976 cb735
« Reply #359 on: July 02, 2010, 07:08:03 PM »
got the head torqued. hope to button it up and start it tomorrow! fingers crossed...
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
traveler
« Reply #360 on: July 02, 2010, 07:55:33 PM »
It's gonna rip!
~Joe
Offline KB02
« Reply #361 on: July 03, 2010, 04:37:25 AM »
There will be video, yes?
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline paulages
  • 1976 cb735
« Reply #362 on: July 03, 2010, 07:18:29 AM »
sure... why not?
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline Soos
« Reply #363 on: July 03, 2010, 08:36:03 AM »
Hoping all goes well!
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline Ecosse
  • Member #4139
    • My 550 walk around video
« Reply #364 on: July 03, 2010, 02:01:49 PM »
best of luck paul!
1974 CB550K
                                  Your 1%er name
Offline paulages
  • 1976 cb735
« Reply #365 on: July 05, 2010, 02:39:51 AM »
It's been a busy weekend and I haven't had much time to work on the bike, but I finally got the cam timed, valve lash adjusted, and everything else assembled and put the engine in the bike. All i need is oil, pipes, and a couple nitpicky things and i'lll be back on the road. tomorrow hopefully!
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline Zaipai
    • My Home page
« Reply #366 on: July 05, 2010, 08:17:50 PM »
Gonna be a video Paul? Hope so.. That is once you have it done.
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline paulages
  • 1976 cb735
« Reply #367 on: July 05, 2010, 10:43:09 PM »
I have it back together and started, though it was a bit anticlimactic. It started right up, but was stumbling a little bit. I checked the timing, which was a little retarded. still it was running a little poorly... at first I thought this was possibly due to poor carb sync since the cylinder vacuums will be different now than before, but then I discovered that cylinders 2 and 4 were cold. Kinda sucks I did my first heat cycle with two dead cylinders, but what am I gonna do? At least they got lots of compression?
Hopefully I'll have time to sort it out tomorrow.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline paulages
  • 1976 cb735
« Reply #368 on: July 07, 2010, 10:07:27 AM »
Well, the good news is it is running beautifully and the engine is broken in. The bad news is that the head gasket leaking. Cometic has the new one en route, so I'll just have to swap them out when it gets here. A little frustrating, but at least it's running, and well. I had some fault signal on the Dyna 2000 and it wasn't working, but it mysteriously started working again.
Oh, and Cadaver has agreed to work out a deal for his CR29's he bought but hasn't installed.  ;D
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
« Reply #369 on: July 07, 2010, 10:20:35 AM »
Maybe you should wait until some planets are aligned or something before you replace that gasket!
I'm sure you layered up several coats of copper spray? I'm not sure what difference the new gasket will offer, but I wish you luck getting the buggar to seal next time.
Glad it runs well.
Offline paulages
  • 1976 cb735
« Reply #370 on: July 07, 2010, 11:18:49 AM »
Glad it runs well.
yes, I used plenty of copper spray. I imagine I just didn't get it flat enough after cutting the holes, though that seems difficult to do since the copper is so soft... you'd think any irregularities would get flattened out when the head was torqued.
the frustrating thing? I just left the shop for 15 minutes and UPS tried to deliver the new one.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline Ecosse
  • Member #4139
« Reply #371 on: July 07, 2010, 07:19:01 PM »
bugger!
1974 CB550K
                                  Your 1%er name
Offline paulages
  • 1976 cb735
« Reply #372 on: July 07, 2010, 09:14:28 PM »
bugger!
I left again and he came back, but there was someone else there this time. hope to have it swapped out tomorrow!
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline paulages
  • 1976 cb735
« Reply #373 on: July 09, 2010, 12:28:45 PM »
Last night was a good night. I pulled the head off, and the leaking part of the gasket was obvious right away. the strange thing is... several bolts were loose, though I know for a fact that they were all torqued properly. anyway, i have the new gasket on hand and will be on the road here in a couple hours.
When I left the shop, I stopped for a nice bottle of wine on the way home. When I got there, I asked my girlfriend to leave, and spent an intimate evening with these guys instead:
 ;D
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
« Reply #374 on: July 09, 2010, 01:41:03 PM »
You're losing it Paul buddy, you should have made it a threesome.  ;)
