Author Topic: Disassembly of gauges  (Read 74575 times)
Re: Disassembly of gauges
« Reply #25 on: October 06, 2009, 07:38:42 PM »
One of the sets I have from a 71 - 750 are original but are more blue than green. All else is the same and they are original...
Any ideas why they may be different?
bc
I've got the same problem, one green and one blue. Would like to make both the same color, don't really care which on this F2. Maybe a pair of Yamiya faces, so they match?  ???
Offline Otto
« Reply #26 on: October 07, 2009, 05:16:35 AM »
Mark,
Maybe we can swap... What's Green, the Tach or the Speedo?
Email me a couple of pix. You have my email...
Bob
Otto
1971 HONDA CB750K1- Valley Green Metallic
2007 Triumph Bonneville - Silver/Black Carburetted
Offline CBGBs
    • Ride or Rot vintage motorcycle event in FTW
« Reply #27 on: October 11, 2009, 03:26:39 PM »
I've used flat black with good results. I was always intimidated by opening the chrome ring until I saw a jewlers tool a fellow Honda nut was using, and thats when I thought of the paint can opener. Cheap, easy and plentiful. Pretty painless too. You can have the ring off in about 20 minutes. I'm opening a gauge tonite that I've been into once before. I'll try to time it.
« Last Edit: October 21, 2009, 05:31:41 PM by CBGBs »
'66 CB77 Superhawk  '73 CB350G Cafe  '75 CB400F '65 S90  '78 CB750 SS
« Reply #28 on: October 20, 2009, 08:14:09 PM »
My bike (K0) had wrecked gauges inside chrome covers that fit over the plastic housing. One was so bad they cut it up to make the case fit into the cover. I am now working on some decent gauges to put inside the chrome. I don't think I even put the metal band back on, the chrome cup held it together. ;)
« Reply #29 on: October 20, 2009, 08:29:13 PM »
Mark,
Bob
I owe you some pictures, Bob: been working long hours (that's good!) lately, haven't had much bike time this week. I'll post them here...
Offline Otto
« Reply #30 on: October 21, 2009, 05:15:44 AM »
Mark,
Didn't hear from you, figured you were all set....The gauges are gone to Italy! Someone there reponded to one of my posts and bought em.
Bob
Otto
Offline CBGBs
« Reply #31 on: October 21, 2009, 05:35:12 PM »
I had to repair my tach on a CB77. It was spinning wildly round and round. The spring had snapped and was wrapped around the shaft. Grrr! I tried to reset it. Its all back together now. I hope it works. The spring will never look like new but it seems to have tension similar to that of the speedo.
Offline Kframe
  • Life is good!
« Reply #32 on: October 21, 2009, 10:08:34 PM »
Where are you guys buying new faces from, I mean the insert with the numbers and dashes and such?
Or can you make your own?  Is there special paper or vinyl or something that you can print a design on?
Thanks, -K
2007 Triumph Bonneville T100, ARK'd, Pods, TOR's, Napoleon's, Innovate G5 Air/Fuel Gauge, Ignition Relocation by D9, Stebel Nautilus, Avon Roadriders
1984 Honda Shadow VT700c, Stock
1974 Honda CB550K, In rehab
1986 Honda Helix
Offline CBGBs
« Reply #33 on: October 22, 2009, 01:04:00 PM »
Didn't work. Grrr!
Offline HedNut
  • Underwater Basket Weaving
« Reply #34 on: November 06, 2009, 01:07:14 PM »
Here's a pic of a set of gauge faces i drew up in AutoCAD....
I'm planning on getting them printed at a local sign printing company on RED vinyl...not too thick...in hopes that the light will glow through the red digits.
I made a few different designs....but these are my favourites...and what I will be using.
cheers!
Offline HedNut
« Reply #35 on: November 06, 2009, 01:19:51 PM »
Some Radio-Active Lookers....
Offline HedNut
« Reply #36 on: November 06, 2009, 01:21:00 PM »
Some other one's to throw out there...
Offline HedNut
« Reply #37 on: November 06, 2009, 01:22:05 PM »
These are pretty much just stock layout...but black and red instead of green & white...
Offline HedNut
« Reply #38 on: November 06, 2009, 01:25:53 PM »
another...
Offline HedNut
« Reply #39 on: November 06, 2009, 01:27:52 PM »
and another...
I just realized...I should've probably put these in another post or something...my appologies.
Once the gauges are apart...these could come in handy though!
Cheers!
Offline rustrocket92
  • Mad Fabricator
  • Buster is in the Lab!
« Reply #40 on: November 06, 2009, 05:27:41 PM »
Here are mine. I cut the ring with a dremal tool. Jb welded back together. Then installed chrome bezels so it didn't matter that I cut them.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline Ecosse
  • Member #4139
    • My 550 walk around video
« Reply #41 on: November 08, 2009, 01:24:02 PM »
Any tips on flattening the faces on gauges,I have a couple that look like the face was sun heated and the face sagged down..
someone on the forum posted a tip for this by using a clothing iron.
http://forums.sohc4.net/index.php?topic=57699.50
« Last Edit: November 08, 2009, 01:28:46 PM by Ecosse »
1974 CB550K
                                  Your 1%er name
Offline sbparks
    • My Hobby...
Re: Disassembly of gauges... Great stuff
« Reply #42 on: November 21, 2009, 08:37:19 AM »
Hi Folks,
 This thread is exactly the info that I was searching for.
 I have my tach / speedo apart (two halfs are split).  I used the paint can opener from Home Depot with very good results (only complaint is the number of times I stabbed my hands / fingers with the tool during the process!).
 My question now is that I need to paint the outer black rings.  Do I just need to remove the rubber seal to have the inner green ring and lense come out?  I think I need all of that out before I can properly sand and paint.
 I gotta flatten the speedo face place (I'll try the iron).  Then I need the stock looking decals for the plates.
 Thanks for the great post and any help with my final dissassembly!
Scott
Offline Johnie
« Reply #43 on: November 23, 2009, 03:45:35 PM »
Not sure about the iron, but I heard of guys putting that face on a flat pan in the oven at low temp. Not sure of the temp but do a search and you may find it. Or someone here maybe recalls the temp.
« Last Edit: November 23, 2009, 07:19:41 PM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline sangyo soichiro
  • Tuck
  • ☢ the atomic playboy ☠
« Reply #44 on: November 23, 2009, 04:19:24 PM »
Those are some nice looking custom gauge faces hednut.  I especially like the radioactive one.  Any chance you can make them in miles per hour and post them?
1974 CB 750
1971 CL 350 Scrambler
1966 Black Bomber
Too many others to name…
Offline Brown Bomber
« Reply #45 on: November 23, 2009, 04:25:54 PM »
Thanks, -K
I got mine from nokrome.  They are Aluminum, and I'm very pleased with them. Don't know if he has more though.
Keep the Shiny side up!
1987 ZG1000 "King Crimson"
1972 CB750K2 "Stout"
1976 CB500T "Witch's Promise"
1973 CL450K5 Cafe Project
        Vito Corleone
Offline HedNut
« Reply #46 on: November 24, 2009, 04:58:46 AM »
Soichiro ...Glad you like em'! I live up here in Canada, so all the bikes I know have the metric gauge faces.  But if somebody could Scan their American faces into a JPG...and send it to me I could scale & post a la MPH.
Cheers!
  • Tuck
« Reply #47 on: December 09, 2009, 09:47:56 AM »
Cheers!
Sorry for the late reply.  I don't have a pic of my gauge faces, but would any of these do the trick?
http://www.cb750cafe.com/parts.php?id=5
1974 CB 750
1966 Black Bomber
Offline HedNut
« Reply #48 on: December 09, 2009, 12:12:32 PM »
Yeah, I can work with that...
Cheers!
« Last Edit: December 09, 2009, 12:18:38 PM by HedNut »
  • Tuck
« Reply #49 on: December 09, 2009, 01:34:30 PM »
Wow!  That was fast!  Thank you.  They look great!
1974 CB 750
1966 Black Bomber
