Author Topic: Project "Low Brow"  (Read 43341 times)
Project "Low Brow"
« on: October 25, 2009, 11:46:12 AM »
not really the name of the bike , more a theme to the build .... i'm thinking , tough looking ... i want people to see it and instantly know it get ridden alot ...  i'm thinking "bobber inspired cafe 2 seater"
i won't be doing any animal print (really sick of all my friends askin that) .. most of the details are still up in the air
but here is whats gonna happen for sure
130x16" rear wheel
white walls
hand made metal side covers
polished top tree
either satin, or low gloss black frame
some sort of dark blue satin tank and side covers
drag bars
twin front brakes w/drilled rotors
vented rear hub
650 cam (if i can find one)
light porting (just smooth out the passages, not really remove any meat)
but main thing for this build is to take as many stock parts and turn them into something else
like the tail being a stock fender all cut up ... and so on
.... i like to let the pics do the talkin  soooo...
this is what happens when you don't prep good before you do a tank liner
this tank was REALLY dented up and had alot of bondo ....ALOT ... i was trying to cut off as much as i could, but in the end i had a lil hammering to do to get it straight
when using sheet metal , alway make templates first
make sure you mark them
don't forget to mark the pieces too
stop and check, stop and check, stop and check, stop and check, ... metal can be pretty unforgiving sometimes
on to the tail
support bracket removed
a chunk of stock rear fender welded on , and hammered to accept the seat
round bar i had layin around
a lil somthin like this
more later .... see ya
« Last Edit: October 25, 2009, 11:50:59 AM by Spikeybike »
Re: Project "Low Brow"
« Reply #1 on: October 25, 2009, 12:00:36 PM »
   so i ran out of bondo long ago ... but i still have alot of spot putty... and tons of J.B. weld  sooooo
i'm filling the holes with JB weld and then finishing it all off with spot putty ... not the best way to do it ... but affective none the less  ;D ;D ;D
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« Reply #2 on: October 25, 2009, 12:30:31 PM »
awesome. I like the fender
Offline kerryb
  • Not a very
« Reply #3 on: October 25, 2009, 02:04:20 PM »
Cool!   I like the theme!
Tell me more about welding on the tank panels.  Is it tricky?
« Reply #4 on: October 25, 2009, 02:35:07 PM »
as far as welding sheet goes .. just take your time , stop and take a step back and look at it ALOT  (like, after every tack)
mine was done with a MIG running flux core wire ... NEVER EVER EVER EVER again will i do this without a tig welder (lost my job, so i don't have access to one anymore)
it's totally do-able ,  just plan on it taking FOREVER
« Reply #5 on: October 25, 2009, 06:58:22 PM »
my lil helper  ;D ;D
« Last Edit: October 26, 2009, 12:51:15 AM by Spikeybike »
« Reply #6 on: October 25, 2009, 07:25:42 PM »
Having a lil helper is the best. I was one and my brother and I are working on cars and bikes together to this day. I still remember every trip to the junkyard and racetrack. My lil helpers are girls. One drives my dragster now and goes zero to 180 in 7.5 seconds. She's way better on the starting line than me and most people I know.
 The bike looks good keep it going.
« Reply #7 on: October 25, 2009, 07:30:37 PM »
it really is man ... doesn't get any better then that for me
i just noticed we're even wearing the same outfit  ;D right down to the bandana in the back pocket
« Reply #8 on: October 26, 2009, 12:54:21 AM »
 gauge bracket tabs? ...   what gauge bracket tabs?
polishings obviously not done
ok it's 3 i'm going to bed now
« Last Edit: October 26, 2009, 12:58:25 AM by Spikeybike »
Offline Toxic
« Reply #9 on: October 26, 2009, 05:35:26 AM »
Wow. Love the rear fender.
I'm going to watch this build closely.
Great work
Offline Really?
« Reply #10 on: October 26, 2009, 07:51:33 AM »
Tagging along.  I want to watch this one.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline mkramer1121
« Reply #11 on: October 26, 2009, 09:22:44 AM »
must be nice to get a free bike... ;D
Offline Really?
« Reply #12 on: October 26, 2009, 09:38:02 AM »
I was stuck on these two pics for bit wondering what you were doing.  It finally came to me.  Your hand is inside the tank - you cut the sides of the tank out.  Kewl.
« Reply #13 on: October 26, 2009, 04:00:18 PM »
 ;D ;D ;D ;D it is .... it really is
thanx again man
Offline mystic_1
  • 1970 CB750K
« Reply #14 on: October 26, 2009, 04:35:06 PM »
Tank looks great!
What did you cut it with?
Can't you run gas in your MIG?  Way less painful than fluxcore imho.
mystic_1
- John Augustus Shedd
« Reply #15 on: October 26, 2009, 05:40:48 PM »
yes i could ... i got the wire , i got the hoses somewhere ... i don't got the regulator ... or a bottle
$50 vs $200  ...  50 won  ;D ;D ;D
and it was cut with two cut-off wheels  one 4" and one 2 1/2 " except the parts where the bondo is really thick was cut with a jigsaw (wheel didn't reach the bottom of the dents :o )
Offline mystic_1
  • 1970 CB750K
« Reply #16 on: October 26, 2009, 07:50:53 PM »
You are a wizard with metal that's for sure.  I tip my virtual hat to you.
BTW, JB Weld has gotta be the world's most expensive body filler, but it'll never shrink or fall off lol!  :)
mystic_1
« Reply #17 on: October 27, 2009, 12:27:12 AM »
i thank you sir , and not only is JB more expensive but man that stuff takes forever to sand
did a lil more work tonight .. but not really .. mostly just staring at it ,
even tho the seat is very similar to my last one, it's a two seater so i gotta mount it totally diffurrt
.......it's a thinker
  • Like a well oiled
    • Undead Asphalt
« Reply #18 on: October 27, 2009, 03:29:44 AM »
attach the seat to a pan with hinges or welded-in bolts and stick the pan to the bike?
Offline kerryb
  • Not a very
« Reply #19 on: October 27, 2009, 04:19:25 AM »
Seat pan idea...  Make the pan out of metal, let the four "corners" extend out the sides and wrap around the frame rails like spring clips.
benefit...no protruding hinge or latch hardware
Offline KB02
« Reply #20 on: October 27, 2009, 04:40:45 AM »
Another project from Spikeybike. I'm in!
I like what you've got so far.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline MacM2010
  • Nobody Special
« Reply #21 on: October 27, 2009, 09:50:14 AM »
Really like the seat idea - a 2-up cafe-style seat is something I'd like to figure out, eventually.  Keep up the good work.
One day, I will put up a signature.
Offline Really?
« Reply #22 on: October 27, 2009, 10:07:24 AM »
my lil helper  ;D ;D
And I thought my balls were big!  That's kewl that you have that much trust in your boy at that age (even though you were standing right there).
« Reply #23 on: October 27, 2009, 11:05:18 AM »
thats what i did for my seat on the Phoenix i used the bolts as pegs (check the "before the fire" thread in my sig), .. but for this i need the rear to be more secure , i've already made the pan, thats a no brainer. attaching it securely in the front and rear with everything hidden . is gonna be a little bit of a pain
i was thinking maybe bolts , with wingnuts from the bottom .. but .. that just seems kinda half assed
thats not his first time by far my man , he would come to my work with his mom, waiting for me to get off ..and chill at the end of my table with an auto shield on just watching , he just started actually welding about 5 or 6 months ago (right around his 5th b'day) .. he can do lil 1/4" beads (they're so f'n cute, cracks me up) soon enough he'll be buildin some crazy #$%*  ;D  you should see some of his lego creations  ;)
« Last Edit: October 27, 2009, 11:15:44 AM by Spikeybike »
« Reply #24 on: October 27, 2009, 11:19:58 AM »
he begged me .. actually begged , to help with some of the grinding .. that had me a lil nervous at first, but he was totally comfortable with it.. (don't worry he had ear plugs and a full face shield )
