Author Topic: What's the worst/dumbest thing a PO did to your bike?  (Read 77360 times)
Offline nitsua93
Re: What's the worst/dumbest thing a PO did to your bike?
« Reply #225 on: November 16, 2012, 08:21:35 PM »
PO of the bike did some very crazy wire splicing in the '70s. He did something around the starter solenoid that I couldn't understand, he replaced one of the fuses with a A PIECE OF COPPER TUBING. He put a Honda Shadow faring on it and did some horrendous splicing in the original headlight housing, which he left behind the faring. Also welded together a very ugly cargo box holder.
PO of the engine decided to weld the case closed where the chain had rubbed a hole into it. That really pissed me off. I used a freaking saline torch to open the thing.
« Reply #226 on: November 16, 2012, 08:40:53 PM »
Found this inside the front hub on my CJ360T.
Looks like the PO used JB weld to glue the pad to the shoe.
Looks like he used some tie wraps to hold it until the glue set.
That's pretty amazing mate, did it work? Cheers, Terry. ;D
Offline CycleRanger
  • No comment about being an
« Reply #227 on: November 16, 2012, 08:59:11 PM »
Well, yes, I have to admit it did appear to be working ok but I replaced the shoes anyway. ;)
« Reply #228 on: November 16, 2012, 09:07:47 PM »
Good idea mate, as much as JB weld is just about the best thing that a bike enthusiast could ask for, I don't think I'd use it for bonding brake shoes, ha ha! ;D
Offline Bailgang
  • Scott
  • Indiana
« Reply #229 on: November 16, 2012, 09:28:12 PM »
This isn't bike related but it's still epic none the less. Many of you probably already know about the poor mans posi trick where you weld up the spider gears on a stock differential, well lets just say the dude in the link didn't research the topic very well before struck an arc. One of the comments in that thread said "might want to go over the welds some more, looks like there are a few missed spots" absolutely cracked me up.
http://www.pirate4x4.com/forum/general-chit-chat/763645-welded-dif-what-hell.html
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
« Reply #230 on: November 16, 2012, 09:42:12 PM »
Ha ha, now that's funny! ;D
Offline Cabilao
  • Diving and Driving
    • Sea-Explorers Watersport
« Reply #231 on: November 18, 2012, 03:53:39 AM »
i have the carb intake of #1 cylinder welded to the head for whatever reason. plus some funny screws to hold the float bowels. and lot of mighty gasket on every cover.  guess there is more to follow since i just started to put the bike in pieces.
« Last Edit: November 19, 2012, 01:53:49 AM by Cabilao »
before:
Kreidler RMC(50cc)
CB400N(first bike)
RD350LC(more than one)
XS850(great bike)
CB900F(wish i still have it)
FZR1000(too fast)
Rickman CR900(sold for a good price)
now:
Rusi 125
CB 125 CL(just for fun)
Yamaha XTZ 125
CB750P7(mystery bike)
77/78 cool 2 member
Offline Mainerider
  • '04 VFR 800, '96 VFR750, 2001 SV650
« Reply #232 on: November 18, 2012, 01:03:23 PM »
Had one in the shop the other day, the current owner couldn't be bothered with finding even a correctly oriented pair of clapped-out 30year-old oem rear shocks. No, Mensa Man finds a a POS pair with a clevis  foot lower mount; unfortunately, his frame also had clevis foot shock mounts.  Hmmmm.... clevis shock, clevis  frame mount.... what to do...wait! I'll simply bash one of the two frame 's clevis feet inward on each side of the bike, then drop the shock clevis over the now-deformed frame clevis mounts. Then, I will attach them with the wrong pitch bolts, screwed in at a cockeyed angle... Can't teach stupid...
« Reply #233 on: November 18, 2012, 03:34:43 PM »
Guess this qualifies: the guy I bought engine fork and wheels from took apart running 78 CB750F to have a frame to build electrical scooter.
« Reply #234 on: November 18, 2012, 04:06:45 PM »
The PO of my red 550 failed to connect the three wires to the voltage regulator upon reassembly. The bike was not charging, and it was about the most simple repair I have ever done.
Offline 750K
« Reply #235 on: November 18, 2012, 05:16:12 PM »
PO of my bike is a good friend of mine, the worst thing he really did was cross thread the #2 spark plug and the only maintenance he did for the 3+ years he owned it was oil changes and plugs. He didnt lube or adjust the chain for 3 years, haha.
His biggest mistake was actually selling it to me and buying a 68 BSA chopper that now has a cracked bottom case somewhere, you pour oil in and it just dumps it right out again. He shoulda kept the 750 and done the repairs it needed, my gain I guess.
77 Cb750, 78 Kz1000
Offline harisuluv
« Reply #236 on: November 18, 2012, 05:20:55 PM »
Hmmm... I think some things are missing here??  Notice "ignition" switch that was rigged.  I later discovered that those "handlebars" are actually a very very heavy steel pipe >.<
This is ONE way to do risers...
Hacked off signals.
Fog lamp?  Headlight?  You decide.
Bike lowering: You're doing it wrong.
Looks solid.
Ugly.
This was my favorite: Fishing line brake light switch.
*shrug*
This is a new Carpy prototype.
I'm confused too.
Looks pretty industrial, huh?
Honda OEM?
Offline madScientist
« Reply #237 on: November 18, 2012, 06:06:42 PM »
Glued the bowls to the carburetor. I wouldn't have figured it out if I hadn't seen the excess on the side of number 3...
Scariest application of heat I've ever done...
You CAN do great things...with enough beer.
78 cb750f
http://forums.sohc4.net/index.php?topic=113293.0
70 CL350 Street Tracker / Cafe
http://forums.sohc4.net/index.php?topic=125641.0
83 KZ1100ltd
76 GL1000
71 Kaw H2 (to be built)
77 cb750A (sold)
74 cb125s (sold)
« Reply #238 on: November 18, 2012, 06:45:40 PM »
Haris - you just buy that?  Unbelievable.
Offline harisuluv
« Reply #239 on: November 18, 2012, 07:41:20 PM »
Nah that was my first 550 I bought for $150.  I had a build thread for it but I haven't updated it in a looooong time.  Just need a seat and paint, it's pretty nice now!
Offline DustyRags
  • I'm not skilled, I'm just a
  • Just try it and see what happens
« Reply #240 on: November 18, 2012, 08:31:23 PM »
A PO put a too-thin washer under the lock nut for the cam chain tensioner on a '76 CB550. No biggie, except s/he then couldn't lock the adjust because the nut was biting the end of the threads on the tensioner lock screw, rather than locking against the cylinders. In an attempt to hold the lock screw in place while cranking that nut down, s/he broke the slot at the end of the screw, and then stripped out the lock in the tensioner.
Then my friend bought it, rode it for three years or so with the cam chain tensioner unlocked, and passed it to me. I tried to adjust the cam chain, and ended up doing a top-end rebuild.
When it was done, I couldn't get the stupid tensioner to lock in place. It felt like I was fighting myself... tossed a second washer under it, and boom, problem solved. If the PO had done that instead of forcing it, he could have saved me a top-end rebuild and saved that poor bike a lot of pain.
1976 CB550K- sold
2005 Kawasaki Vulcan 500- sold
2000 CB750 Nighthawk - sold
1975 XL350 - crashed
2004 Suzuki Vstrom 650 - sold
« Reply #241 on: November 18, 2012, 10:45:42 PM »
When I was 10 years old, I had a "Paper round" which I did on my bicycle. I'd deliver a couple hundred newspapers two nights a week after school, all for the princely sum of 2 bucks a week. One day I rode past a house and stopped to watch a heap of Aboriginal kids pushing each other around on a Honda QA50 "Amigo" mini bike.
I asked them what was wrong with their minibike and they said "It doesn't go, we think it's buggered", so I said "wanna swap me for my bicycle?" They said "yep", and as I'd finished my round we did the trade and I pushed the little Honda home, wondering to myself what my folks were gonna say when they found out I'd given my bicycle away.
As I'm pushing it along the road, I noticed that there was a wire hanging off the ignition coil, so I reconnected it, gave it a kick, and if fired right up. I rode it home, but my folks still weren't happy that I'd traded my bicycle without their permission. "What the hell" I thought to myself as I listened to my dad lecturing me, "you can't please all the people, all the time"............ ;D
Offline shinyribs
« Reply #242 on: November 18, 2012, 11:10:28 PM »
Not my bike,but the PO of this bike was complaining of a slipping clutch and clutch chatter  :o   simply appalling...
The darn fool didn't know it couldn't be done...so he went ahead and did it anyway.
My Hackjob build- http://forums.sohc4.net/index.php?topic=106103.0
Offline CycleRanger
« Reply #243 on: November 19, 2012, 06:43:02 AM »
My god!  I'll bet he never changed the oil either....
Offline thenewbie
  • Tits migee
« Reply #244 on: November 20, 2012, 02:29:16 PM »
Hose clamps to install the mounting bracket for a vetter fairing... unless thats a common practice idk... i thought it looked sketchy
1976 cb550f, 1995 xr250l
« Reply #245 on: November 20, 2012, 04:15:22 PM »
many threads here recently about trying to remove that spigot and stripping all the threads out of the head. There is no need to remove it.  Welding it back in is a fix, JBWeld or appropriate epoxy might be more elegant.
Offline WhyNot2
  • I'm finally an
« Reply #246 on: November 20, 2012, 04:22:39 PM »
Plastic Exhaust Hangers;
Wonder how long they would have lasted::::::::::::::::::::
« Reply #247 on: November 20, 2012, 06:35:59 PM »
5 min max!
Offline DustyRags
« Reply #248 on: November 21, 2012, 08:10:02 AM »
Lasts forever as long as you don't ride and/or that cylinder never fires ;D
1976 CB550K- sold
« Reply #249 on: November 21, 2012, 08:20:58 AM »
he could have at least used a SS zip tie FFS   ::)
