Author Topic: CB750 Cafe/Endurance Project  (Read 45895 times)
Offline HedNut
  • Underwater Basket Weaving
Re: CB750 Cafe/Endurance Project
« Reply #25 on: August 18, 2010, 05:06:16 AM »
Looking Great man! This bike is Unique! Love it!  Watching intently I am!
Offline MasterChief750
  • Detonation
« Reply #26 on: August 18, 2010, 06:59:28 AM »
the tank and seat look exelent. i may have to try this on my tank next year.
1976 CB750 K - Drag Bike
I AM THE STIG
Sam is THE STIG
he said i can be STIG3 tho
Offline beveldrive
« Reply #27 on: August 18, 2010, 12:05:52 PM »
Yes, I'm in the UK. Got the fuel cap from:
http://www.vintagebike.co.uk/Spares/Fuel/Filler%20Caps/Filler%20Caps.htm
I've fitted a 2.5".
I removed the flap and, using a thin disc cutter, cut out the lower tray (and through the overflow tube). This cutting needs to be straight-sided as possible, and as close to the edge as possible. You see what I mean when you look inside the flap - it will all become clear!
Weld up the overflow on the underside of the tank. Then de-burr the new rectangular hole with a file, and remove all paint 10mm around the edge, in preparation for MIG welding. Make a card (or stiff paper) pattern to fit the hole your gonna fill. Do this by laying card over hole and rubbing round with dirty finger ;D. Then cut out pattern, check it fits, no gaps. Check it again, cos you only want to cut this steel filler plate once!!
With a scriber, transfer the shape to some clean mild steel sheet (I used 1.6mm). De-burr, check the fit again. Then, using I smooth faced hammer and metal block underneath, I dished the filler sheet to match the flow of the tank top, as near as possible. It dont have to be prfect, cos you'll be able to tap it down once you start tack welding it in place. Last of all, cut the filler neck hole. When all fits well and is prepped for MIG, get it welded. But beleive me, I'm no hot-shot welder. This sucker needed some dressing, grinding and filling, before I got anywhere near the shape you see now.
Good Luck!
Offline BrianAdair
  • Oh, so this is where you type the text...
« Reply #28 on: August 18, 2010, 05:57:59 PM »
Thanks for the info man!
Now I just need to see if that company will ship to the U.S......
Offline Flying J
« Reply #29 on: August 18, 2010, 06:17:06 PM »
any pics on how you installed the filler cap? Did you just weld in a plate add filler and sand smooth?
Is it a 2"  or bigger size?
« Last Edit: August 18, 2010, 06:24:42 PM by ffjmoore »
Offline beveldrive
« Reply #30 on: August 19, 2010, 10:05:13 AM »
See above for details. Have no pics, but it's a pretty straightforward process.
To mount the cap I welded in a filler neck and will bond the cap to this after paint.
Offline beveldrive
« Reply #31 on: August 22, 2010, 07:57:32 AM »
Firstly, here’s a pic of the fuel stub that the Monza cap will be bonded to:
I’ve now reached the stage where I need to get the motor fired-up and get it running properly. So with that in mind I’m working toward getting the exhaust fitted. This will be about as far from standard as it’s possible to be, I guess. The pipe is a Marving 4 into 1, which is actually for a DOHC motor. But I bought it anyway, even knowing this, as it looked like a nice pipe! It’s new, but old stock.
I’ve decided to ditch the standard finned collars, in place of flanges and studs - more in keeping with the off-road/endurance/scrambler theme that I’m now going with. Anyway, after originally intending to have some local machine shop make up some billet flanges, I had a change of plan and decided to take the ‘homemade’ route. I had some 6mm duralumin (dural) plate in my shed, and with a pillar drill, cobalt burr, file and scothbrite – well how hard can it be!
Here’s a few pics of the process.
Chain-drilling the centre hole is tedious, but I had no hole saw man-enough to cut the dural (tough stuff). After a quick tickle with the burr and a wipe with the file and scothbrite, they look like this. I may give them a further ‘finishing’ as they are right up front and need to look good. Note the detailed 'engineering' drawing!
So, here we are all studded and flanged-up, ready to hang the pipes:
Having to cut the header pipes to slide the flanges on would normally be out of the question, with a new manifold. But as I have to ‘modify’ it anyhow in order to get it to fit the slightly different port spacing of the DOHC, it really doesn’t matter. Here’s a couple of pipes temporarily in position:
Next thing is to tighten the downpipes into the head and tackweld the collector/main pipe back together before MIG welding. And generally ‘jiggle’ the fit to get it sitting up close to the underside. The pipe will then take a turn out and up, to bring the ‘Arrow’ race can somewhere around number plate level.  Bit like this:
I'll be busy with the MIG, next few days!
Steve
Offline mazingerzeca
« Reply #32 on: August 22, 2010, 08:57:00 AM »
Nice seat.
I would like to find done like this for my cafe project. I've been looking through the web for Single GRP seat Yamaha SRX but I couldn't find it. Any clue to make the search? Year, model bike?
Thank you.
Offline cbsrawesome
« Reply #34 on: August 22, 2010, 12:47:01 PM »
love the tank. the whole thing looks real smooth.  will be following this string!
« Reply #35 on: August 22, 2010, 03:26:37 PM »
Thanks for the info. I will go for it.
Offline beveldrive
« Reply #36 on: August 24, 2010, 10:34:52 PM »
Looks like my gamble on the DOHC headers paid off. Here they are bolted (and taped) into place, just to check 'the look'.
Just need to align and weld the pipes back together. Not sure at this stage what colour to paint them -may even consider a wrap.
Offline Flying J
« Reply #37 on: August 24, 2010, 10:42:57 PM »
I say ceramic coat them silver/ chrome
Offline beveldrive
« Reply #38 on: August 24, 2010, 10:59:16 PM »
Wow! hadn't considered a coating, looks very cool. 8)
I'll check it out.
Offline beveldrive
« Reply #39 on: September 14, 2010, 10:46:12 AM »
Finally finished the pipe.
Now need to get the carbs on, ignition sorted and get the oil up.
Can't wait to hear it run ;D
Offline B.O.X.N.I.F.E.
  • The Stumped
« Reply #40 on: September 14, 2010, 11:06:57 AM »
excellent job
1974 CB550
Forever West
Offline goaarongo
  • zen and the art of angle grinding
« Reply #41 on: September 14, 2010, 11:58:10 AM »
Looks killer... can't wait to see more...
Offline HedNut
« Reply #42 on: September 15, 2010, 06:00:27 AM »
Hat's off on the Pipe job!! Excellent work! I Love the C.F. Slip-ons... had a Leo-Vince on my 750 Kawk... it sounded AWESOME  Throaty and DANGEROUS.... 8)
Cheers!
Offline beveldrive
« Reply #43 on: September 19, 2010, 08:09:18 AM »
As the weather here in the 'ol UK is beginning to turn cold, I thought I'd take advantage of this sunny weekend and get the paint done on panels, seat and tank. Still don't have a mudguard yet, but I've mixed enough paint to complete the job.
Decided on the tangerine and silver to keep the retro/competition theme going.
Also fabricating some 'enduro style' footrests, which I'll post as soon as their finished.
Cheers
Steve
Offline Flying J
« Reply #44 on: September 19, 2010, 09:04:45 AM »
Very nice work!
Offline beveldrive
« Reply #45 on: September 20, 2010, 11:27:36 AM »
Here's a pic of the tank and seat on the bike:
Now I really must get on with etting the motor ready for first start-up ;D
Offline Flying J
« Reply #46 on: September 20, 2010, 03:44:16 PM »
Are you  sticking with those handle bars? I think a set of riser bars would look good. Like what they put on the dirt tracker bikes.
« Reply #47 on: September 20, 2010, 05:47:21 PM »
Very nice paint mate....subscribed.
Offline putnaja1
  • '77 CB 550k -Was gonna cafe, but looks cool stock!
    • Jason's Wacky Website
« Reply #48 on: September 20, 2010, 05:50:35 PM »
Man-oh-man!!  That exhaust (and color scheme) look incredible!  Excellent work!
Jason
Play Pinball!
My Gallery!
"The world is divided into people who do things, people who get the credit and people who continually criticize.  Try, if you can, to belong to the first class of people.  There's far less competition"
Offline hapakev
  • Your Standard
« Reply #49 on: September 20, 2010, 06:52:33 PM »
Oh thats a sweet looking ride man.
Smoking Jack
1978 CB750F(ish)
