Author Topic: my new toy s90 content  (Read 18873 times)
Offline vanaman
Re: my new toy s90 content
« Reply #25 on: April 27, 2010, 07:58:45 PM »
got the keys and battery to it today.
ive got no spark.  The points are getting 6v. the points look okay and are working now.
but ive got no spark.
where is the coil and how can i test it?
78 cb750f
97 VW Jetta GLX
98 Cabrio 1.8t
Offline TomC
« Reply #26 on: April 28, 2010, 03:28:28 PM »
Hi Vanaman
     You have 6 volts on the point that moves when the points are open. Do you have 0 volts on the point that moves when the points are closed? If so all is well with the primary side of the coil.
     To test the secondary side of the coil you need an ohm meter. With the ignition turned off and the points closed the resistance between some were on the engine, say the points plate, and the contact on the inside of the spark plug cap were the spark plug cap grips the end of the spark plug should be about 15K ohms. This is about 10K ohms in the coil and about 5K in the spark plug cap. This is not a precise number. Much under 10K ohms I would start to worry. I expect you may find well over 15K ohms. If so unscrew the spark plug cap and check the resistance of the spark plug cap and the resistance between the end of the wire and the engine. Some times just cutting a small amount off the end of the wire from the coil and screwing the spark plug cap back in will fix the problem.
     I find that the problem with Super 90 electrics is mostly in the connections. Not in the actual components.
     The coil and capacitor are mounted on the top of the engine. You would have to drop the engine to get to them.
     PM me if you have more questions.
          TomC about 60 miles from Westerville
TomC in Ohio
76 CB750 F1 Daily Rider
76 CB550 stalled project
76 CB400F Injured Reserve
Offline vanaman
« Reply #27 on: April 28, 2010, 06:17:02 PM »
hmm ok.
ill take my meter to all that next time im out at the bike.
steve
78 cb750f
97 VW Jetta GLX
98 Cabrio 1.8t
Offline TomC
« Reply #28 on: April 30, 2010, 04:53:09 AM »
Hi Steve
     I thought of one more test that you might do. If you meter can measure amps. I would check the current going through the coil. There should be about a 3 amp current through the coil. To measure this set the points open and turn on the ignition. With your meter set to measure amps put plus lead to the point that moves and the negative lead to the point plate.
     Let us know what you find.
         TomC in Ohio
TomC in Ohio
Offline Old Scrambler
« Reply #29 on: April 30, 2010, 06:47:55 AM »
Your model appears to be a '65.......the off-set carb and the slope of the exhaust port changed during '65........also some S90 bikes were made for Arizona with different specs because of a 5HP rule. All of the motors with your exhaust port angle are said to have a little more power at road speeds. The silver paint color is the same as used on numerous other models in those years........match case covers and fork legs, then match fenders to other fenders....
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline tbpmusic
« Reply #30 on: April 30, 2010, 08:15:23 AM »
Get your Title straightened out before you put a dime into it.
You could be throwing good money after bad............
Bill Lane
Offline Carbine
« Reply #31 on: May 04, 2010, 02:09:37 PM »
All the S90's I ever saw were either black or red. Until one day, one if the older guys in Grade 12 in our high school showed up on a blue one. No, it wasn't a CL, it was an S.
I remember it being almost new, and blue. Only one we ever saw. We still wonder about it, all these years later.... ;)
'76 750 K6 Candy Antares Red
'75 750 F0 Candy Sapphire Blue
'74 750 K4 Boss Maroon Metallic
'73 750 K3 Maxim Brown Metallic
'72 750 K2 Flake Sunrise Orange
Offline HondanutRider
« Reply #32 on: May 05, 2010, 04:49:32 AM »
According to the Honda sales brochure for this model at the time, blue was a colour that was available.
Offline Carbine
« Reply #33 on: May 05, 2010, 02:08:42 PM »
Wow, thanks for posting that brochure HNR!
Sure enough, bottom right, there it is listed.
Mystery solved, after all these years. It is a rare color however, of all the hundreds (if not thousands) of S90 bikes that were around here, there was only the one in blue.
And now of course, there are none of any color!
« Last Edit: May 05, 2010, 02:15:11 PM by Carbine »
Offline vanaman
« Reply #34 on: June 19, 2010, 06:19:26 AM »
well i think the coil is bad.  there is infinite reisistance between the block and the plug wire.  plus when i pulled the engine the coil was corroded and nasty.
so now the hunt for a new coil.
would the cheapys from ebay be fine? or is it better to find a used oem coil?
any other hondas use the same coil?
steve
78 cb750f
97 VW Jetta GLX
98 Cabrio 1.8t
Offline vanaman
« Reply #35 on: June 25, 2010, 07:45:09 AM »
okay so i pulled the coil.
i have 22 ohms of resistance between the end of the plug wire and the terminal on the coil with the black wire.  there is infinite between the plug wire and the blue wire.
there is also infinite between the plug wire and the ground.
would that make this a bad coil?
steve
78 cb750f
97 VW Jetta GLX
98 Cabrio 1.8t
Offline vanaman
« Reply #36 on: July 02, 2010, 12:05:56 PM »
would it be possible to swap the cdi off a latter 110cc 3 wheeler or other honda that uses this style engine.
78 cb750f
97 VW Jetta GLX
98 Cabrio 1.8t
Offline vanaman
« Reply #37 on: July 09, 2010, 06:37:50 AM »
78 cb750f
97 VW Jetta GLX
98 Cabrio 1.8t
« Reply #38 on: July 09, 2010, 07:44:49 AM »
That's an interesting ad!  The "Roadster" that is featured, looks to be a customized Cub 90.  I've seen several of the Cub 50's kits to make the "Rally", but never this one.  I'll bet it would be super rare and quite valuable to have one.
Here in Canada, we had several Cub models that I don't believe made it state-side. One was a 55cc variant of the 50cc version, and another was the 65cc Cub that had the same motor as the S65.
Offline crazypj
  • I'm brill, me
« Reply #39 on: July 09, 2010, 10:20:54 PM »
That is a later model. Mine is a 1966 and has a VIN # S904788xx. Also, if you'll note in the black bike's photo, the air cleaner cover on the right side does not have the cut-out for the side-mounted carb's adjustment screw. The early models (I think all 1965 and 1966) had the curved manifold that put the carb at the right side on the airbox as shown in this pic of my all original bike. The 1967 and later ones had the straight manifolds that positioned the carburetor in the middle of the box.
Note my avitar - the S90 is my very first real motorcycle and despite the fact it's shrank over the years (it did I swear it), I'll never forget the fun I had on that first one.
Regards,
Gordon
 Yep, I've had 1965 to 70 models, was going to ask for pic of intake but Gordon beat me to it
Offline vanaman
« Reply #40 on: July 10, 2010, 05:30:27 PM »
I actually just saw a rallye today at mid-ohio.
78 cb750f
97 VW Jetta GLX
98 Cabrio 1.8t
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
« Reply #41 on: August 19, 2011, 07:56:07 PM »
Hello there my fellow S90 brother!! I just started getting mine together.
One of the hardest frigging things to get is that battery door cover...and youve got it. Did you get the paperwork yet?
Offline lucky
« Reply #42 on: September 07, 2011, 06:53:24 PM »
Look on the tail light lens the red part it usually has the year.
Also Many parts from the trail 90 are the same.
I used to race those and we would lighten the rocker arms from 4 oz. to 2.5 ounces. Revs quick then!
We called them super 90's
Offline strynboen
« Reply #43 on: September 08, 2011, 12:53:48 AM »
nice littel honda..in denmark ve got the cd 50/65 models only in blue and red..on cd the ignision are not battery but coil ´/  magenet
« Last Edit: September 08, 2011, 12:56:38 AM by strynboen »
i hate all this v-w.... vords
