Author Topic: Honda CB 750 Front fork brace  (Read 11908 times)
Andy Downes
« on: February 14, 2010, 12:38:15 AM »
Hi can someone help, is there available a front fork brace to fit  CB 750 K2 on the bottom fork sliders, not on the fork tubes, thank you.
Offline voxonda
Re: Honda CB 750 Front fork brace
« Reply #1 on: February 14, 2010, 12:48:29 AM »
Hi Andy,
I know there are braces for the K2. At least here in Europe. If you wamt can look into that.
Cheers, Rob
Offline turboguzzi
Andy Downes
« Reply #3 on: February 14, 2010, 04:53:16 AM »
Hi thank you everyone, if it would not be to much trouble Rob yes please, I am going to the Biker,s Classic at Spa in June if you are going again I can arrange to pick it up from you, but I will have paid for it long before then, once again many thanks, Andy.
Offline cavebear
« Reply #4 on: February 14, 2010, 05:30:02 AM »
I have almost identical forged three piece fork braces. All I need to know are the leg diameters and the center line distance.
$35 shipped.  ;D ;D. Sorry  I can't include include photos but photobucket seems to be taking the morning off. The photo on the web site is the same as they look.
                                             Cavebear
1975 MotoMartin 836cc
1976 Rickman 1150cc Turbo
1977 Seeley 890cc + 1/4 stroke
3 parts bikes,1970K0 to 1978ss
Get paid to do it,it's work; pay to do it,it's a hobby
Offline lordmember1969
« Reply #5 on: February 14, 2010, 10:08:18 AM »
How much for one shipped to Norway for 76 ss? :)
1977 CB 750 SS Cafe
1977 CB 750 Basket case
1971 Mustang Grande
1928 Model A Pheathon Hot Rod
1977 Harley Custom FXE
http://forums.sohc4.net/index.php?topic=70333.0
« Reply #6 on: February 14, 2010, 02:46:19 PM »
Hi Andy,
Cheers, Rob
A brace for the K2 does exist, or has existed. BGFootball had one from Telefix that was special ordered from telefix Europe. I tried to get one using the same source and they told me no more. His bike does not have a front fender. I can't tell but from the pictures I don't think it will allow the stock fender.
The problem with CB750-K2 is that the top of the fork leg is lower than the top of the tire. It is the only motorcycle in the entire world like this. The telefix brace has a really high arching bridge to clear the tire, can be seen on BGFootballs Cafe Racer bike if you search for his pictures.
So NO brace marked as K3 or later will work as they are straight across bridges type braces. After K3, the fork leg was higher than the tire, and a traditional bridge type brace could then be used.
There have been some other braces made as a loop to the front and rear, but they interfere with fenders and dual discs.  Since the application is just for CB750 thru K2 its not a high priority item.
It is not a simple issue. For example, none of those listed in TurboGuzzi's link will work.
I have a "tweak bar" style fork brace which the origianal poster doesn't want. I will also be having a machine shop make me a telefix high arch style, but with an 18" tire, so not as high as for the 19"tire. It will also have a different fender mount built in.
« Last Edit: February 14, 2010, 02:52:33 PM by MCRider »
« Reply #7 on: February 14, 2010, 03:00:38 PM »
PS: I may be off base on this, wouldn't be the first time. So sorry if so.
But I tried to get one and failed. If someone does know for sure, source and part number, I'd sure like to know too.
« Reply #8 on: February 14, 2010, 03:22:13 PM »
High forks started in 77/78 on the 750, except 76 auto had them first.
 MC if you or anyone else wants a telefix type made , I could make some, I will try to keep the cost reasonable, and will do it if I can sell a few units..
Andy Downes
« Reply #9 on: February 14, 2010, 11:49:04 PM »
Once again thank you to everyone who is helping, 754 I will take 2 if you are going to make some, regards Andy.
Offline voxonda
« Reply #10 on: February 14, 2010, 11:57:17 PM »
@754: am interested in what you would make of it.
@Andy: Telefix has them for the F1/K7. They would fit though. As my memory serves me right.
Cheers, Rob
« Reply #11 on: February 15, 2010, 01:04:12 AM »
Cheers, Rob
Rob: i could be wrong about this, but i don't think so. The F1/K7 have the taller lower legs that clear the tire, allowing for a straight across bridge type fok brace. Such a brace will not work on the earlier models (K2) where the top of the fork leg is substantially below the top of the tire.
Offline voxonda
« Reply #12 on: February 15, 2010, 01:51:05 AM »
Thanks Ron,
This is where my memory failed. Knew there was something with the lenght of the sliders. This must be it.
Sorry Andy! ;)
cheers, Rob
« Reply #13 on: February 15, 2010, 01:54:23 AM »
Thanks for the offer. I'm wanting to integrate the brace with a mount for a different fender. I think the machinist will need to have everything in house to get the spacing right. So I'll be hauling my rolling chassis to the machinist.
« Reply #14 on: February 15, 2010, 08:31:02 AM »
The cost of a one-off will likely be higher, than if several were made, or continued to be made.
 I realize that a crucial part of the design is to clear the stock fender, if this is done right, it can also be used to mount a light fender, attached to the cross brace.
 I have made a KZ version before..
 I dont really want to go thru all the work, only to have someone else make the same piece and water down sales.., or worse, copy my design..
« Reply #15 on: February 16, 2010, 07:52:19 AM »
I forgot one other twist. The early fork leg tops were smaller diameter than the later ones, thus splitting the already small market into two pieces. The enlargement was to accept a larger fork seal. That split came between K1/K2? Maybe K3/K4.
That was the reason I couldn't use the Telefix that BGFootball had found. It had the high arch to clear the tire, but also had the large clamps for the larger leg tops. Mine has the smaller tops.
I also think Telefix may have run out of them.
So many performance guys are using the GL front ends, pretty beefy brace available for them.
And I could be wrong here as well, this stuff gets foggy with the passage of time.
« Reply #16 on: February 16, 2010, 08:24:03 AM »
a couple things..
 If I make a brace, I can make it for gaiters, or push in seal covers (like 77/78 F). I think the gaiters will look more scrunched.
 The other thing, is, sounds like there is a difference from K1 to K4, which means 2 sizes, maybe..
 Start miking the tops of your forks...
Hinomaru
« Reply #17 on: February 17, 2010, 08:42:55 PM »
Note the fork brace style on this K1 which was recently on ebay.UK
Aside from the questionable appearance, I wonder how well would it perform?
(Scroll deep down into the listing to see the full size images)
http://cgi.ebay.co.uk/Rare-1971-Honda-CB750-K1-SOHC-US-Restoration-project_W0QQitemZ220553988372QQcmdZViewItemQQptZUK_Motorcycles?hash=item335a0ac914
« Reply #18 on: February 18, 2010, 07:59:27 AM »
Wow, nice clean bike, I like that colour.. How much USD is 3150 pounds Sterling? I would leave it as is and ride it
 That forkbrace is probably Circle Industies or similar, used a lot on dirt bikes..
Offline Scottyboy
« Reply #19 on: May 27, 2017, 11:30:27 PM »
Hey guys I've been looking all over for a fork brace for my CB750K2 with the older style fork lowers. I've seen Tarozzi makes one that may fit (detentions look right) but I want to see if anyone has tried already since that could be a pricey experiment on a blind buy. Anyway telefix no longer makes or sells for this model either.
« Reply #20 on: May 28, 2017, 05:52:27 AM »
This guy was making them for a while, don't know about now.
http://tkat.com/forkbrace.html
About 1min 10sec into this video you can see the one I had made at a machine shop. Used a fork brace I bot off ebay to cannibalize the parts that clamp around the leg. Then the bridge also came from a sacrificed fork brace. These were cheap to come by. The shop cut the clamps in half, welded the stand ups, etc.
tkats is more thought out, having done several of them.
« Reply #21 on: May 29, 2017, 02:52:11 PM »
Tarozzi will work but you may have some fitment issues with your front fender, if you are using the older lowers.
Tkat's brace is extremely well made -- maybe over-engineered -- and maybe a little too bulky for some tastes.
