Author Topic: 1975 Supersport, performance cafe  (Read 145934 times)
Re: 1975 Supersport, performance cafe
« Reply #450 on: October 12, 2013, 07:29:53 PM »
The FT caliper uses pads common to other models, and the pistons and seals look to be the same as well. (The pistons are 27mm if I recall correctly) The caliper mounting bracket and hose routing appear to be the main difference between models. The FT rotor has less offset than a CB 750K rotor; about 14mm compared to about 21mm.
